Sharp LC-52D62U OPC + Power LEDs on front bezel blink 3x, stop, repeat every 2 or so seconds. It was mentioned in the past that this is either Power board or the Main video board. I have inspected both - see no obvious issues. Could you point at the problematic component reference designator, please. Thanks for your help and expertise. Kind regards,
  • 1 more comment
  • yuryws Aug 22, 2010
    Perhaps CHU3505 would be able to contribute to this - many thanks.
  • yuryws Aug 31, 2010
    Capacitors are fine, and so is the power board. Thank you for your suggestion.
    The problem was the main tuner board - there is a reason as to why Shrap chose to heavily heatsink the three ICs on that board - one or more of them must have "died" as a result of overheating.
    Replaced the main tuner board - all is OK now.
    Kind regards,
    Thanks for all of your comments.
  • 5,138 Answers
Look for Bad Capacityors on power supply board they will be vented,swollen or puffed up on top. 1000uf 16v 220uf 10v 330uf 10v
Posted on Aug 23, 2010
  • 736 Answers
I have the list of problem codes/error type and the repair required in hand. I need to know how many times power blinks on its own independently before there is a pause, and then I need to know the same about opc then I can provide more details.
Posted on Aug 22, 2010
  • 3 more comments
  • Loretta Northcutt
    Loretta Northcutt Aug 22, 2010
    I may as well type the full chart and you'll have it
    power light opc light Errror Type Repair
    -- AC Power failure Loose connection, Power Unit or Main Unit
    1(1/sec) Lamp Failure Loose connection to Inverters, reload firmware
    Inverter Unit or LCD Panel
    2X Power Failure Inverter Unit or LCD Panel
    2X 1X 13V/UR10V failure Power Unit or Main Unit
    2X 2X 3.3V Main Failure Power Unit or Main Unit
    2X 3X UR6V failure Power Unit or Main Unit
    2X 5X Panel 5V failure (1) LCD Control Unit or LCD Panel
    (1) SOF driver shorted on LCD Panel - disconnect one of the LCD Control Unit cables from panel, if TV power on with backlight or a crack is in panel, replace LCD Panel.
    Attempt force power on
    Enter into service mode set Lamp Error to 0
    This is the list for when the television does not turn on. There is a different list for when it is turning on and turning itself right back off with a blink pattern.
    Thanks you for your reply.
    The TV does turn ON and OFF a number of times, this follows by with power and OPC LEDs flashing in the following pattern: 3x in a row power and OPC LED blinking, then the LEDs go off for 2-3 sec, then the pattern repeats.
    The problem appears to be on the Main tuner board (the one with HDMI connectors).
    I swapped the board betweeen a working and a broken TV set - the problem stays with this board. The power supply is OK.
    Anything particular on the Main tuner board that needs to be inspected/repaired?
    Thanks.
  • Loretta Northcutt
    Loretta Northcutt Aug 23, 2010
    It is important to look at the lights separately. Look at power all by itself and see how many times it blinks before it pauses and then look at opc all by itself. If it is really 3X power and 3X opc the error type is communication and the repair is a main unit. Sharp does not point to a specific part of the main unit in particular that needs to be repaired; Sharp recommends replacing the entire main unit. If you notice that it is 3X power and 2X opc the error type is main failure and the repair strategy is replace the main unit or the LCD Control Unit. 3X power and 1X opc is communication error and replace the main unit.
    Do you have any lamp errors? Have you completed an INIT? Make sure you complete a lamp error reset or the tv will go into a coma.
  • yuryws Aug 23, 2010
    I do not beleive lamp error is present. I do have Power and OPC LEDs flash 3x together, not separate. So it looks like the comm error as described in the service manual.
    What is "INIT" you mentioned and will I have to perform a lamp error reset if I were to replace the main board?
    Thanks again
  • Loretta Northcutt
    Loretta Northcutt Aug 31, 2010
    An INIT is in industry initialization. You are literally going through the service menus. That the television is doing what it is doing indicates that when you go into the service menus you will see a number by lamp errors. That number will have to be cleared or the television will not turn on anymore without being forced on. Yes when you replace the main board an INIT including clearing any lamp errors will have to be completed.
    You must unplug the television and hold down the volume - and input button on the television set. Hold down and keep holding them down while plugging the television in. Keep holding them down until the green K appears on the screen. Then When you see the K press and hold down the volume - and channel down buttons on the television set until you get to the service menu. Then with the remote control use the channel down button to scroll down to lamp errors you may have to press the enter button and the <--- or ----> to clear them and them press enter. Then use the down arrow to go to page 2 of the service menu and press the ---> on INIT + cause to turn it on then press the enter button
    When the screen turns green unplug the set for half a minute.
Sharp aquos tv opc and power led flashing
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Jun 01, 2016 | Sharp LC-52D62U 52 in. LCD HDTV
Sharp lc-52d62u with sound and no picture. OPC and power lights blinking.
Sounds like lamp problem. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Oct 01, 2015 | Sharp AQUOS LC-52D62U 52in Widescreen LCD...
Power and opc leds blinkin, two times the power led then power and opc one time, is this a error code?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
May 20, 2015 | Sharp AQUOS LC-52D62U 52in Widescreen LCD...
I have an aquios LC-42D64U which suddenly has the following two lights blinking power & OPC. They both blink, once together, the second blink is only the power, and repeating the sequence. I've...
Sharp LED/LCD EEP cleared Step 1 Remove Mains Plug 2 Press On/Off Switch from LED/LCD Panel 3 Press Ch Down & Input Switch together and plug in mains cord 4 LED/LCD will start 5 "K" will appier on Screen 6 Press Ch Down & Vol Down from LED/LED Panel 7 1/9 Page will appier on Screen 8 Go to 9/10 page by pressing Up & Down arrow of remote 9 Select EEP Cleared 10 Press ok button from remote 11 On Screen dispay EEP running 12 Remove Mains Plug after complete EEP Run 13 Restart LED/LCD
Feb 05, 2011 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
On my lc-52d62u tv. the on light blinks 2 time an the opc light blinks 5 times. over an over. what is this code telling me thats bad in the tv?. what needs replaceing.
Does the set get good air flow in the back, sometimes these sets get too hot and cause this problem, you may have to order service manual
Dec 15, 2010 | Sharp LC-52D62U 52 in. LCD HDTV
I have a Sharp lc-46d62u and it blinking when i power it up the power led and the opc led blink twice a second the the opc led blinks and repeats. I read on this site that it may be the power supply so i...
I had this issue and Sharp sent out a local repair tech to install a new main circuit board, then two weeks later, a new side board (where the side inputs connect into the system)...
Nov 01, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Sharp aquos
you can try resetting the tv by
1. unplugging it
2. pressing channel down and volume up buttons at the same time while plugging tv back in
3. if you here a click, the tv has been reset
May 12, 2008 | Sharp LC-46D64U 46 in. LCD HDTV
Lc-46d64u
How many times per second does the POWER led blink? (dont worry about the OPC).
1x per second (constant, steady blink) = bad inverter/lamps
2x per second = bad power supply
3x per second = bad main board
There isnt really anything you can do to fix it yourself, youd have to call Sharp to locate a local service center.
Mar 23, 2008 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
No POWER
How many times does the POWER led flash per second? (Dont worry about the OPC).
1x (steady constant blink) = Lamps or inverters
2x = Power Supply
3x = Main Unit
If i am reading it correctly, looks like the POWER led is flashing 2x, which means it is a power supply failure. Either way, your TV needs to have a board replaced, there isn't anything you can do to fix it yourself. Try locating your local sharp authorized service center to repair your TV (1-800-237-4277)
Mar 13, 2008 | Sharp AQUOS LC-32D43U 32 in. LCD...
Televison & Video Logo
162 people viewed this question
Top Televison & Video Experts
Electro Med Services...
