Question about Whirlpool Refrigerators
How can I find out how old my Whirlpool Refrig., Model ET14JK is?
2 Suggested Answers
techline
  • 39 Answers
SOURCE: Whirlpool model ED5FHAXSLOO refrig 3 years old very noisy
If it is cooing fine, then the noise is probably your evaporator fan (the one inside your freezer). This can be cause by one of several things. The motor on this fan may be going bad, or, more likely, you may have a build up of ice around the blades that are touching the fan. This may be caused by a defrost circuit that has gone bad, or, the freezer may have been open alot lately and there is an excess of frost that hasn't melted away yet. If you can, manually defrost the freezer and see if it goes away. If it doesn't, it's probably the fan motor. If it does, and then comes back, it's probably the defrost circuit. Hope this helps!
Posted on Dec 06, 2009
Refrig won't cool on either freezer or refrig side. Confirmed manual settings & allowed 24 hrs for cooling. Is there a reset switch somewhere other than manual switches inside refrig?
check that the compressor is working by feeling for motor vibrations at the compressor, hot compressor unit or hot fins or back wall of the fridge
if there is not heat then the compressor is not working
call a technician as it could be a start/run capacitor failed or compressor seized
get a quote as some compressor replacements cost as much as a new fridge
check that the utility power is getting to the fridge/freezer
Jul 10, 2016 | Refrigerators
How do I determine and fix what is wrong with 2008 model whirlpool frig that the freezer I noticed first all food unfrozen then a couple days later refrigerator not cooling can hear running but contin
I ned more information to answer your question. What model do you have? This is very important to give you the correct information you seek. Thanks
Sep 16, 2014 | Whirlpool Refrigerators
We have a Whirlpool with the freezer on top. The freezer is around 5 degrees, but the refrig. won't go below 47 even at the coldest setting. We vacuumed all of the vents and tubes in the lower front
The fan in the freezer may have stopped working. Or it could be the defrost drain tube is stopped up. Remove the rear plate in the freezer to expose the fan motor. With the rear cover off You can see if the freezer box has frozen over the drain. If so unplug refrigerator use a hair dryer to melt the ice. Keep heating the drain area until water runs down through the drain. Fan motors are available by model number on line or at local appliance stores.
Dec 30, 2013 | Whirlpool Refrigerators
I need to purchase a compressor for a Whirlpool side by side refrigerator. Model number on the complressor is EGY90HLP.
What is the model number of the refrig ? The compressor number could have changed , since the refrig was manufactured , to a better , more reliable compressor .
Dec 07, 2009 | Refrigerators
3 month whirlpool refrig. whole system seems to be shutting down.
You most likely have a bad pc board. If I were you I would call Whirlpool and have them send a technician out and fix it under warranty. The number should be on your paper work that came with unit. If not, call 1-800-555-1212 and ask for the number. I could try to help fix but if you mess with it, the warranty will be voided.
Oct 16, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool Model ED5SHAXML12 is freezing food in refrigerator even when dial is at off. Happened from one day to the next.
At the refrig controls , the freezer control , controls how much air goes into the refrigerator section . Open the refrig door , and up at the top left , put your hand over the damper (air vent) . Turn the freezer control from high to low , and feel the difference in the air flow . If you turn your freezer control to a lower setting , less cold air will enter the refrig . Think of it as : the freezer control adjusts the temperature , and the refrig control , tells how long to run the compressor . In actuality , this is how it works . However , with the dial (refrigerator thermostat) in the off position and refrig still running , this indicates a bad thermostat . Pt # 2198202 .
Sep 09, 2009 | Whirlpool Refrigerators
My Whirlpool refrigerator trips the main breaker of 40 Amps
A refrig cannot pull 40 amps in defrost , unless there is a direct short in the defrost system ( timer , heater , bimetal ) . I would use an extention cord ( for test purposes only ) , and try a different plug . Sounds like the circuit breaker is weak . In defrost , the MOST you should get , is 6 amps . This will not throw a 40 amp breaker . If you have an amp meter , remove the back refrig panel behind the refrig , and connect to one of the power cord lines (just not the green ground ) , turn into defrost and check the amps . This will tell you if short is in refrig , or weak breaker .
Sep 06, 2009 | Whirlpool ES5FHAXS Side by Side...
Whirlpool Refrig. stopped cooling with no warning. Freezer is freezing with ice build up on back wall. Thanks, Mike Strickland
Mike, Please send the complete model number so I can help you better. If your refrigerator has a defrost timer this could be the problem. You also can visit my site below and enter model or part number in the search feature. We also offer free help and assistance. , Thanks, Sea Breeze seabreezehvac@yahoo.com
http://servicepartstec.blogspot.com/
Mar 29, 2009 | Whirlpool Refrigerators
Refrigerators Logo
196 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
