Question about Electrolux EW23CS65SS Stainless Steel Side by Side Refrigerator
The water or ice dispenser is stuck open and either pours water or ice out I filled up a cup of water and it has stuck open not sure if there is a switch in there or what is stuck not sure how to disassemble Electrolux ew23cs65ss
  • matthewsaver Aug 22, 2010
    the ice maker works fine. The door dispenser handle is sticking open so that if the water is selected it pours water out the door spout. If the ice is selected it pours ice out the door
  • 10,515 Answers
Take the ice bucket out and look at the metal bar that runs along the bottom. This bar is the part that changes the unit from crushed to cubed. When' it is lifted up, it will produce cubed ice. Make sure that the bar goes into the plastic stirrup looking device in the back panel when you push the ice bucket back into place. If it slides underneath the stirrup, it will not pull the lever up. If everything checks good and it still won't make cubed ice, you'll need to order and replace the solenoid behind the back wall that pulled the stirrup up.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Aug 22, 2010
GE TFX24E side by side refrigerator, ice maker won't fill with water.
Hi, I have a GE TFX24E refrigerator. The ice maker is not filling with water. I replaced teh water valve with no joy. If I pour a cup of water into the dispenser the ice maker will freeze and harvest the ice. Any ideas? Is there a replaceable water fill sensor?
Sep 03, 2011 | GE WR30X10093 Refrigerator Icemaker Kit
Ice maker doesn't work
Pour about 2/3 cup of water into the ice maker . If it freezes and dumps the cubes , but doesn't fill with water , replace the water inlet valve ( the piece that the wall water line connects to on the fridge ) . Also check to be sure that the fill tube from the back of the freezer to the ice maker , isn't blocked with ice , as this is caused by a seeping bad water valve . If the ice maker doesn't dump the cubes , after freezing , then replace the ice maker . Also check to make sure the coils under the front of the refrig , are clean of dust , lint , pet hair , etc.
Sep 16, 2009 | Refrigerators
No water going in the ice maker but water dispener
Pour about 2/3 cup of water into icemaker . If it freezes and does not dump , replace the icemaker . Check to make sure the coils are clean of dust , lint , pet hair , etc . If it does dump , and does not refill with water , replace the water inlet valve ( piece behind refrig where the wall water line connects to on the fridge ) . Check to make sure the fill tube that fills the icemaker is not blocked with ice , still indicating a bad water inlet valve ( slow seep ) .
Aug 29, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Replace selenoid and water is still not going to ice maker
Did you pour about 2/3 cup of water into the icemaker and did it dump ? If you did pour water into the icemaker , and it did not dump the cubes , then the icemaker is bad . If it did dump , so you replaced the water valve , then the fill tube directly at the icemaker is frozen with ice . It will need to be removed ( fill tube at icemaker ) and the ice cleared out by hot water . On some models , behind the refrig , 2 screws hold the fill tube in place . Remove the tube , and clear the ice . When reinstalling , have someone guide it from inside the freezer , to where it mounts on the icemaker fill cup .
Samsung RS277 ice maker not filling with water but have water through dispenser
Pour about 1/2 cup of water into ice maker . If it dumps , replace the water valve . If doesn't dump , replace the ice maker . Also make sure the coils are clean of dust , lint , etc...
Aug 21, 2009 | Samsung Refrigerators
No ice being made
Pour about 1/2 cup of water into icemaker . If it dumps the cubes but does not fill with water , replace the water valve ( the part that the line from the wall connects to on the fridge ) . If the icemaker does not dump the cubes , replace the icemaker . Be sure the coils are clean of dust , lint , etc... as this will not let the freezer get cold enough for the icemaker to dump .
Aug 20, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool gold ice maker not filling with water to make ice
Aug 16, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice Maker stopped making Water Whirlpool model (ed5phexnq00)
Aug 15, 2009 | Refrigerators
Model MSD2754GR Side-by-side.. it will dispense water but will not fill the ice trays (I have checked all the obvious stuff, water supply lines and ice sensor arm). Don't here the control module "clicking"...
Aug 11, 2009 | Refrigerators
Water dispenser gets stuck
It could be the switch that activates the lever. This happens when you have soda in the glass and then fill your cup with ice. It splashes up to the switch then it becomes sticky.
Jun 06, 2009 | LG Refrigerators
Electrolux EW23CS65SS Stainless Steel Side by Side Refrigerator Logo
59 people viewed this question
Top Electrolux Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
