Question about Dacor Epicure 30" Double Wall Oven, Stainless Steel - E0230SCH Electric
Where do I find the model number on my Dacor wall oven???
  • 33 Answers
SOURCE: Dacor Gas wall oven
is there tension on the door at the point where it doesnt seal,is the spring broken/missing,when the door opens and closes is there enough travel from point a to point b inside the cabinet on both sides of the hinge area, is the sping loaded mechanism damaged .
Posted on Dec 30, 2007
  • 1314 Answers
SOURCE: Looking for hinges for a Dacor oven
http://www.repairclinic.com/SmartSearch/smartsearch.aspx they they have some here
Posted on Jan 28, 2008
SOURCE: dacor cps130 wall oven f1 error
According to the manual, this is an element relay circuit failure. Call the tech.
Posted on Jun 15, 2008
  • 29 Answers
SOURCE: Dacor ECS230 Epicure Electric Double Oven
You probably tripped a safety thermostat in the back of each oven. If you turn off the breaker and find a way to pull the units out you could probably remove the rear panel and reset the thermostat by pushing in a button on the back of the open thermo. Some thermo's aren't resettable though so you'd have to buy a replacement.
Posted on Sep 22, 2008
SOURCE: Dacor ECS230 Wall Oven Control Panel Time functions not working
Try turning the power off at the breaker for 12 hours.
I had the same problem, tried turning the power off for a few minutes but that did not fix the problem.
Leaving the power off overnight seems to have fixed it.
Posted on Oct 10, 2008
My Dacor oven keeps beeping and flashing PRB. How do I stop the beeping?
Most unwanted beeping on Dacor products are due to a bad touchpad... Use your model # and start looking for a replacement , by touchpad I mean a part something like this one: Dacor Touchpad 62678B
Jul 12, 2016 | Dacor Epicure 30" Double Wall Oven,...
Dacor wall oven MORD230 cont'd beeping,disconnecting power to unit did't work,error code 01 appear on display
Hello. The error means there is a shorted key on the keypad. The part number you will need is 701044-02, called "membrane panel assembly, black". The main board, if needed, is 101991, called LED display module. Hope I helped you!
Aug 21, 2015 | Dacor Ovens
Co1 erroe code distinctive wall oven what is problem
According to your model number this code means Shorted or stuck key. Your keypad needs to be replaced. Good Luck
Aug 07, 2014 | Dacor Distinctive DO130 30" Single...
How to turn fan to oven
First of all, here is the main DACOR ONLINE SUPPORT page for your model:
http://www.dacor.com/Our-Products/Wall-Ovens-Single/Distinctive-Single-Wall-Oven.aspx
And here is a direct link to the ONLINE USER'S MANUAL for that model:
http://www.dacor.com/WorkArea/showcontent.aspx?id=18137
To view the Support Page or the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents.
You can download this free at WWW.ADOBE.COM if necessary.
Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, then follow the onscreen instructions to install the software on your computer.
See page 10 of the manual for detailed instructions on how to use the various cooking modes of your oven including the convection fan feature.
I hope that was helpful to you, good luck.
If you choose to rate this solution using the Thumbs Up scale provided, I thank you very much for your time and consideration.
Joe.
Jun 13, 2011 | Dacor DO130S Oven
How do I find the model number on a dacor double wall oven?
The MODEL Series you already said in your question: EO230SCH
Check and see if it is this model:
Good Luck!
Dec 06, 2010 | Dacor Epicure 30" Double Wall Oven,...
What size is the bottom element in a dacor model w305wc wall convection oven
I'm sure what you are asking. If you need an element, you can order it by your model number, which you have provided. We supply parts and you are welcome to call us at 9728590929 and we will be happy to assist you with your parts orders. We hope this helps!
Aug 14, 2009 | Dacor Epicure 30" Double Wall Oven,...
Our Dacor Millennia wall oven will not heat
There is a manual reset button behind the vent under the touch pad. Turn off the power. Open the door. Remove the vent. Behind the latch is a two wire switch. press the red button on it until it clicks. reassemble and turn on power. It over heated when the power went off by stopping the cooling fan.
Mar 04, 2009 | Dacor MCS130SS Millennia Electric Single...
PCS 130 Keypad
Dacor probably won't cover anything. F1 is either the touch pad or ERC (clock). If it stops beeping when the touch pad is uplugged from the ERC then the touch pad is the problem if not it is the ERC. Call Dacor Customer service to get a price on the parts and to voice your displeasure.
May 22, 2008 | Dacor PCS130 Preference Electric Single...
Oven light
There is a new relay board available that is suppose to fix this problem issued 3/17/05. old part number 82127 new part number 92028 I found this a dacorservice.com. ignored login slected parts at top right of screen them looked up my wall oven model number ECS and read thru the parts list
Link is http://ww1.dacorservice.com/PartsCatalog/docs/ProductModels/522/PM_RSD-101708.pdf
May 17, 2008 | Dacor ECS127 Epicure Stainless Steel...
Dacor cps130 wall oven f1 error
Dec 04, 2007 | Ovens
Ovens Logo
304 people viewed this question
Top Dacor Ovens Experts
Dan Webster
Dan Webster
ashburton
Jaime Hernandez
Are you a Dacor Oven Expert? Answer questions, earn points and help others
