Question about Whirlpool Duet GHW9150P Front Load Washer
Why does my front load washer get out of ballance
  • Whirlpool Master
  • 17,130 Answers
It is possible that the dampers on the suspension of the drum is faulty. The dampers can be tested for soft action to confirm.
Check if there is any fault of alignment in the spring assembly,correct if the chassis has a defect as then the drum may move out of centre, specially if the main chassis has a damage.
But check out the dampers.
Posted on Aug 22, 2010
My kenmore elite washer spins off ballance and the front by the door is loosing nylon
the ballance of the washer is can be changed by the knobs that are on the bottom of the washer try turning the knobs untill ur washer spins freely they are what keep the washer off the floor
Jun 10, 2012 | Kenmore Washing Machines
How to fix a shaking washer bosch 100
there is no special ballancing act that they do.... there is only heavy springs that try to keep up holding it straight. maybe one is wore out or you just simply overloaded it
Feb 04, 2012 | Bosch Nexxt 100 Series WFMC1001UC Front...
Counter ballance as broken on a hotpiont aqautic
This can be replaced provided the fixing points are o/k and not broken as some times happens
Jun 16, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
When on final spin it starts to shake very hard
they domake some noise and a mor enoise if they are not ballanced properly. otherwise you have to open the front and check the spring loaded armiture to make sure they havent worn out
May 24, 2010 | Frigidaire ATF6000ES Front Load Washer
The machine doesn't drain 100% of the water out. You can move the tub and hear the water sloshing around in the machine bottom and the moisture is now starting to form mold on the front seal
All the water does not drain. The front tub has ballance ring with water sealed in it to off set off ballance loads. The sump hose on the pumpwill also hold water. You can clean your pumps clean out trap to make sure the pump is working good. Also a drain hose higher than 6 ft off floor will cause pump not to drain all water. Front loaders all have a mold problem. no air gets in when your done washing because you close the door. If you dont use bleach and hot water washes it makes matters worse. Fabric softner is even worse.
You need to clean your washer with bleach in the front seal by hand some times.
Its the price you pay for saving water.
Nov 17, 2009 | Kenmore HE2 Plus Front Load Washer
Making loud noise when in spin cycle
SOUNDS LIKE YOUR WASHING MACHINE COULD BE OFF BALLANCE YOU NEED TO CHECK THIS WITH A SPRIT LEVEL AND AJUST THE LEGS IF NEED BE .
Nov 11, 2009 | Maytag Neptune MAH5500B Front Load Washer
GE front load washer model #WBVH6240FWW leaks when filling at top and drips down side of front ballancer
Check the big rubber seal around the door for any holes or tears. Had the same problem, my husband had a screw in his pocket that torn a hole in the gasket.
Sep 27, 2009 | GE WBVH6240F Front Load Washer
Shacky washer
Try taking the yellow shipping bolts out of the back of the washer that hold the drum in place while shipping. f
Jul 06, 2008 | Frigidaire Affinity ATF7000E Front Load...
Whirlpool Duet GHW9150P Front Load Washer Logo
Dan Webster
Dan Webster
Sal DeAngelo
