Question about Malibu ML600TW - Low Voltage Power Pack - 600 Watt - With Timer and Ground
Where can I buy a new timer? part# is pb912m10 Thanks
I think PB912 is Intermatic series modular timer:
Open following link to help identify timer.
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#PB
Intermatic store sells hard-to-find parts.
http://www.intermaticstore.com/
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on May 26, 2011
Where can I purchase a Model #pb912m10 timer for an intermatic transformer?
The PB912M10 clock module is not sold separately.
Open following links to see available clock modules.
http://waterheatertimer.org/pdf/Intermatic-PB800-PB900-timers.pdf
If power pack transformer still works, it might be easiest to buy cheap plug-in timer, set power pack to override, and plug power pack into cheap timer.
Open following link for power pack resources showing tips and warranties:
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
Take a moment and rate answer:
Aug 29, 2011 | Malibu ML600TW - Low Voltage Power Pack -...
I have to spin the timer by hand to turn the lights on and off.I have the Intermatic ML900TW transformer.It seems to me I just need to replace the timer but they have been discontinued by Malibu Lights and...
PB912 timer module is not available separately.
Following link shows available PB series model numbers:
If clock motor no longer operates, you can set power pack to override and then plug power pack into cheap in-wall timer.
Some people report being able to disassemble clock motor and clean gears and reassemble with a bit of white grease on gears. Other people report they took it apart and forgot to mark the tiny gears and couldn't reassemble the parts. My experience with clock motors and motors in general is once they slow down and overheat, they never work correctly again and are sorely underpowered afterwards. It would be easier to buy a cheap plug-in timer.
Jul 02, 2011 | Intermatic Malibu 900-Watt Power Pack with...
Had to replace a fixture today. when I replugged the lights the lights turn on manually but the clock on the timer does not advance I have 56 watts of light Is the timer broken?
If clock motor does not rotate, then some people report taking it apart and cleaning gears.
The PB912M10 timer clock motor is not sold separately. Aug 2010.
If power pack transformer still works: buy cheap plug-in timer, set power pack to override, and plug power pack into cheap timer.
With receipt, power pack might still be under warranty.
Open following link for power pack tips and resources:
Nov 29, 2010 | Intermatic Malibu 121W Power Pack...
Timer model PB912M10 does not run inside transformer ML300RTW. Can this be replaced. If so wher can it be purchased
I answer questions for free.
I specialize in timers and electrical devices.
I hesitate to answer about Malibu power packs because there are no parts or repairs for a power pack, and the owners of this product are angry that such an expensive item is unrepairable and then they downvote a truthful answer that is provided for free.
Here's what I've done for fixya customers.
For hours, I searched Intermatic Timers, Malibulights.com, and the web looking for parts and solutions for the Malibu power pack. There are no parts or solutions.
I purchased a power pack from Home Depot and examined it and then read the manual from head to toe.
The answer is this: if the power pack is not working for any reason and the receptacle has power, then the power pack is busted and you need another one.
However I can save you money on your next power pack, and that may be worth your trouble coming to fixya:
Your next power pack:
1) Match up wattage of bulbs with wattage of power pack.
15 each - 20 watt bulbs = 300 watts = 300 watt power pack ... if you buy the 500 watt power pack for 300Watts of bulbs, then it will burn up the bulbs and the power pack.
2) Replace bulbs as soon as they burn out or other bulbs will burn out and the power pack will burn out
3) When working on bulbs, unplug power pack or the power pack may burn out
4) Use the link below to help plan your low-voltage lighting
http://www.malibulights.com/guides_support/low_voltage_planning_guide/select_your_power_pack
Purchase a power pack:
Home depot sells Malibu power packs.
Lowes sells a Low-voltage power pack similar to Malibu
Nov 06, 2010 | Malibu Intermatic Inc. ML300RTW 300-Watt...
I need contact points for Intermatic #ML300RTW or more specific contacts for, #PB912M10 clock
ML300 is a Power Pack for outdoor lighting
A search of Intermatic site shows they no longer sell the product
Malibulights.com does not have any parts either
I have searched the web for parts in order to help fixya visitors, and I can't find any trippers or clock repair parts at all.
I bought a new Malibu 330Watt at Home Depot thinking the manual or box would show information>> but the new Power Packs have a digital clock, not the old dial clock with trippers.
Look like you have to buy a new Power Pack to fix the old one.
Oct 26, 2010 | Intermatic & Indoor/Outdoor Rain Tight...
L can manually operate the transformer but my clock does not work
Intermatic makes a PB913 timer module, but does not show PB912. Not even the old model page shows that timer.
Intermatic store does not show PB912
http://store.nexternal.com/intermatic/categories.aspx?Keyword=PB912&x=16&y=12
Open following for Power Pack troubleshoot and resources:
Upvote the help.
Jul 22, 2010 | Malibu ML600TW - Low Voltage Power Pack -...
Gears stripped. can I buy the timer unit
Sep 30, 2009 | Intermatic Malibu 121W Power Pack...
I have a malibu ML121RT timer that just stopped working. Outlet works, new lightbulbs, didn't nick power cords to outdoor lights. What could be the problem?
If transformer no longer works, then it is not repairable.
Jun 16, 2009 | Intermatic Malibu 121W Power Pack...
Where can I get a timer motor for an Malibu low voltage transform
Apr 21, 2009 | Intermatic Malibu 121W Power Pack...
What timer motor fits in Intermatic ML121RT Power Pack ?
Apr 11, 2009 | Intermatic Malibu 121W Power Pack...
Malibu ML600TW - Low Voltage Power Pack - 600 Watt - With Timer and Ground Logo
526 people viewed this question
Top Malibu Hardware & Accessories Experts
Gene Haynes
jdthefixer
 Kenneth
Kenneth
Are you a Malibu Hardware and Accessory Expert? Answer questions, earn points and help others
