Question about GE ® 3.5 Cu. Ft. King-Size Capacity Washer with Stainless Steel Basket WTRE6260FGG
Making loud noise when spinning (grinding). bearings?
dididsaythat
  • 291 Answers
SOURCE: Washer agitates, but makes horrible grinding noise. Spins okay.
thanks for posting problem solve :0)
Posted on Sep 03, 2007
  • 1314 Answers
SOURCE: loud cliunking noise in beginning of spin then won't spin
get a flashlight and see if a foreign object has fallen down through one of the tub holes and is jamming the tub you have to look real close
Posted on Jan 11, 2008
sdmc73
  • 121 Answers
SOURCE: grinding noise spin cycle jumping around
what brand
Posted on Nov 29, 2008
SOURCE: GE Washer Tub has sunk and is grinding on bottom
I had the same problem and as near as I can tell, we ran a load the was simply too big and the upper chasis "droooped" just enough from the weight to cause the metal to bow. As a result, the bottom of the tub assembly was rubbing against the lower metal chasis, creating a loud grinding noise. Metal filings indicated the wear point. I took a piece of wood that is about 1"x3x height and wedged it in front and slightly to the left of the motor, running straight, up and down. the board stands straight to take out the bowing- lifting the tub about 1/4" more. This was just enough to provide the clearance needed to prevent grinding. If the vertival board is too long, you won't be able to get the front cover back on.
Posted on Jul 26, 2009
  • 27 Answers
SOURCE: GE Profile Washer very loud bearing noise when spinning.
when they leak is when the damage usually occurs... the fact that the sound started afterwards may be a fluke, although damaging it while replacing seal is a definite possibility...
Posted on Sep 24, 2009
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
Washer makes rumbling noise during spin cycle
You have to take the whole drum out and IT IS YOUR BEARING(s). Order all four of them
Oct 22, 2014 | Washing Machines
How do i repair a lg washer that makes a grinding noise when slowing down from spin cycle
It sounds as if the tub bearing on your machine is faulty. To replace this bearing one needs to basically strip down the entire machine.
Not a job for a novice.
Sep 06, 2014 | LG WM2501HWA 4.2 cu. ft. Front Load Steam...
LG direct drive washer makes loud grinding noise
Check presence a stranger subject in drum. Shine the torch and swing the drum.
If rubbish no that necessary to change the bearings.
Nov 12, 2013 | LG Washing Machines
I hear a loud grinding noise when i drive my car
Check front tyres & wheel bearings espesially the R/H/F. Feel tyre for high / low spots on inside & jack up & spin wheel if you get noise while jacked up it is not the tyres but wheel bearing or brake pads but more than likly a crook bearing by the sound of it. It needs to be tended to ASAP
Jun 28, 2012 | 2004 Volkswagen Passat
Loud noise on spin cycle
most common cause for this is pump bearing on water pump. remove belt and attempt to turn pump by hand. if it grinds get a new pump.
Oct 08, 2009 | Maytag PAV2300 Top Load Washer
Maytag washer makes loud grinding noise during the spin cycle
if it's making a noise then either your drain pump bearing is going out or your thrust bearing is going out (assuming the noise happens in both spin and wash). Tip the washer backwards so that you can get underneath of it. Take the belt off and spin the pump pulley on the right side. This should spin effortlessly.
The middle pulley is the trustbearing pulley. Spin this--- one direction it should have a little bit of resistance--- the other should have more resistance
Aug 20, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Grinding Noise
yes you are right the tub bearing has failed
May 21, 2009 | Estate TAWX700JQ Top Load Washer
Loud noise when it spins
Sounds like main drum bearing noise, try turning the drum by hand, if it feels rough or you can hear it grinding or rumbling, then it is the the main bearings that have failed..
You will probably need to call an engineer.
Dec 03, 2008 | Washing Machines
My Capacity Plus Admiral Washer will spin and agitate, but it makes a loud grinding noise.
Well, Sounds to me like the Bearings are going out, but it could make that noise a good while, before it goes completely out.. Replacement would possably be more cost effective, Kinda hard to beleive !!!!!!
Oct 26, 2008 | Washing Machines
GE ® 3.5 Cu. Ft. King-Size Capacity Washer with Stainless Steel Basket WTRE6260FGG Logo
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
