Question about Troy-Bilt Pony Garden Tiller
I found a HORSE tiller that i re-furbished and got running.. The problem now is, there is a metal port on the engine just beneath the carb that shoots oil out the engine.. Is this for the air filter to keep oil on it? There is no tube coming off of this piece and im not sure what it is.. Any help would be appreciated..
  • 26 Answers
That sounds like the crankcase breather valve. It should have a rubber hose running from it to the air filter mounting plate. But it should not let oil blow out of it, I would replace the breather and hose and that should take care of the problem. The breather is held in with two screws just remove and replace. There is a very small drain hole in the bottom of the breather housing just make sure it is down so the oil will drain back into the crankcase and not run out.
Frank
Posted on Oct 07, 2010
DIY CARUBATOR ADJUSTMENT FORTROY BILT WEEDEATER HORSE
well this is not much of a question. be more specfic.start with why are you trying to adjust the carb to start with. engine idleling rough? blowing black smoke indicating too rich mixture? back fire? no power ? engine has low rpm and making no power? you get the idea
Sep 04, 2014 | Garden
How to troubleshoot a kohler m8 engine
first check for spark then check for fuel try starting fluid does it fire on starting fluid then is carb related
May 22, 2012 | Troy bilt Horse Tiller Hiller Furrower...
My 5 horsepower pony tiller just shuts off with no warning after about 20-30 minutes of tilling and will not restart again until it cools down to the touch I have changed the spark plug, drained and...
I also was having issues with an old 5 horse Troy Built tiller that would fire when gas was in the tank then stop running. If it's a Briggs and Stratton engine like the one I have it's probably you can remove the muffler to gain access to the side of the carb. Remove the four screws and the cover off the fuel pump diphram and check to make sure that the rubber isn't cracked or degraded. I replaced the one I had and it now runs like a champ.
Mar 23, 2011 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
I have a Horse Tiller with no spark. How can i resovle this.
If I were you I would seek professional help. The engine may very well need replacement parts. If you know what a kill switch wire is it would be worth your while to see if it is toughing any where to a metal surface. This condition would be the same as turning the engine off. This could get very technical unless you understand electrical theory, lock-out systems etc.
Feb 20, 2011 | Troy bilt Horse Roto Tiller Parts Manual...
Tiller starts, runs for 2 minutes, then engine slowly sputters and dies. In checking the engine oil, discovered gasoline mixed in with oil. Why would this happen? Solutions?
Other than knowing you have a tiller,sounds like you have a float type carb. and the float did not shut the fuel off and fuel ends up in the crank case with the oil
Your problem sounds like you need to address the carb. area starting with removing the float bowl and inspect the float needle valve and needle valve seat mainly for dirt and functioning freely. If you have a metal float shake it to see if has fuel in it? if it does get a new one. Drain the oil when you fix the problem and put new in
May 09, 2010 | Garden
Engine does not continue to run
Are you laying off the choke at any point? Full choke should only be used when starting a cold engine, it should run with no choke on full throttle. If there is not enough throttle i'd first try adjusting the tiny black screw on the carb beneath your air filter while you have it idling, letting the throttle have a little bit more room. If this doesn't work and you're running it properly than you may need to make some adjustments to the H L settings for your gas/air mix. This is also done while idling mind you and only with a clean air filter.
Apr 02, 2010 | Honda 25cc 4-cycle Mini Tiller
Carb needs rebuilt and I do not know the part # for this engine, Tecumseh HM100 159370P-B
Should be a metal tag somewhere on the tiller that gives all the information, Will give Model #. type and serial #. Your parts dealer can I dentify the carburetor from those nos.
Feb 20, 2010 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
My Mantis Tiller 4cycle engine starts well but when I press the throttle completedly, the tines turn very slowly. This is a brand new tiller, used only twice. The engine is sitting all the way down on the...
I had same issue with my 2 year old 4cycle. Check if the carb is moving full stroke with throttle movement. I had almost no movement at carb at full throttle, found the trigger in throttle handle was cracked and bent rather than pull cable. I called mantis and they promptly sent a new handle bar ***'y with new cable, throttle ***'y Etc and that solved my problem.
BTW: If you cannot wait, I did figure out that if I pushed the carb to open with the throttle trigger fully pulled it would run at high, but when you let go.....LOL
Rich in Wethersfield, Ct
May 10, 2009 | Mantis 4-Cycle Tiller
Runs short time,quits,wait 20 min, runs again for a few min.
Hello, It sounds like there is a problem with the electrical portion of the tiller. Once the internal coil heats up it looses the power to keep the engine running. The other option is the muffler that is overheating the carburetor to the point that it boils the gas before it gets to the engine. A lot of the older B.&S. engines used a two piece muffler with a screen inside that would get plugged up causing excessive heat to the carburetor. Good Luck, RAC
The Guest's problem is quite different. You should have throtlle cable coming down below the carburetor on the side of the B.&S. engine. Not knowing which type of govenor you have on the engine, early models had a metal plate that was controlled by the cooling air of the engine and later models had a mechanical govenor built into the side of the engine. Is sounds like the govenor is stuck at full throttle for one thing and the engine is running out of gas because it can't flow enough fuel to the motor. This type of problem can also be caused by a loose carburetor causing a vaccum leak or bad gaskets on the carburetor. I would rebuild the carburetor and insure all ports are clean and flowing, including the small screens on the bottom ot the fuel tubes, replace carb gaskets and check the carb. insulator to make sure it is not cracked also. While it is apart check the throttle linkage elements to insure they are free before reassembling the carb. back on the engine. Good Luck, RAC
Apr 17, 2009 | Garden
Troy-Bilt Pony Garden Tiller Logo
202 people viewed this question
Top Troy-Bilt Garden Experts
Jay Finke
Jay Finke
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
