Question about GE Nautilus 24" Built-in Dishwasher
ALL OF MY DISHES ARE COVERED IN A WHITE FILM. i'VE USED CLR, RUN BLEECH THROUGH THE SYSTEM. ...HAND WASHED ALL DISHES BEFORE PLACIING INTHE DISHWASHER. I USE CASCADE ONLY. SMALL AMOUNTS...
    President:
  • 1,197 Answers
If your dishes or glassware appear with a white film or a white powdery residue or spotted following a complete wash cycle, adjusting the amount or type of detergent you?re using and adjusting your hot water heater?s water temperature may solve the problem. But before you do either of these, put a rinse additive (such as Jet-Dry) in the rinse dispenser to improve the sheeting action of the water.
Next, you?ll have to determine whether the film is removable or permanently etched. To do this, soak a glass in undiluted white vinegar for about 15 minutes. Or, wash the glass with warm water and concentrated dishwasher detergent or a high-phosphate detergent (such as Glass Magic).
If the film comes off, it is probably caused by hard water minerals, improper amounts of detergent, or unsuitable water temperature.
Permanent etching is often caused by a combination of soft water and excessive heat or detergent. If glassware is permanently etched, there isn?t anything you can do to make it clear again. But you can avoid future etching by taking these steps:
1) Be sure hot water entering the dishwasher is no hotter than 140 degrees F. Don?t use extra-hot settings such as ?Power Scrub,? and use the ?Energy Saver? dry cycle.
2) Adjust the detergent amount.
3) Don?t pre-rinse your dishes before loading them in the dishwasher. Food particles on the dishes actually help the detergent and drying agents clean better.
A common cause of poor washing results is improper loading?dishes that block or impede the spray arm(s) or prevent the soap dispenser from opening. On the other hand, if your dishwasher has chronic problems with good washing, the problem may not be your dishwasher. A good first step is vary the amount of dishwasher detergent you're using and try switching brands.
Other possibilities: Your home?s water pressure may be too low, your water may be too hard, or the water temperature may not be hot enough.
In order for your dishwasher to fill to the appropriate level, water pressure should be from 20?120 pounds per square inch. If you suspect that your water pressure may be low, turn off all faucets or other users of water (such as washing machines and sprinklers) and then put a half-gallon jug under the kitchen faucet. Turn on the hot water full-blast. If the jug doesn?t fill within 14 seconds, your water pressure may be too low for proper dishwasher operation. Call your city water utility to discuss your options, or avoid drawing water elsewhere in the house or yard during dishwasher cycles.
The right amount of detergent to use depends on how large your load of dishes is and how hard your water is. Hardness is measured in grains of minerals?the more grains per gallon you have, the more detergent you?ll need. If your water has 12 grains or more of hardness, fill both dishwasher soap cups completely with detergent. If that doesn?t work, consider installing a water softener. (For more information, see the article Water Softener Systems.
To check water temperature, hold a meat thermometer under the hot water faucet for two minutes; if it doesn?t register a minimum of 140 degrees F., turn up the temperature dial on your hot water heater. (However, if you have a newer dishwasher that heats the water internally, it isn?t necessary to turn up your hot water heater.)
If your dishwasher has worked fine in the past but suddenly your dishes aren?t clean after the dishwasher completes all cycles, listen to the spray arm(s) spinning inside during the wash cycle. If spinning poorly, wait for the machine to cool down, remove the spray arm(s) by unscrewing the hubcap(s), lifting the arm(s) off, and then cleaning out the spray holes in the spray arm(s) with a stiff piece of wire.
Please rate the solution if you feel I've helped you
Posted on Sep 10, 2010
After 6 years, started leaving white film on dishes and silverware
Run a cycle with some CLR instead of soap, empty no dishes, run two more cycles with just water to rinse out the CLR and then see if the residue is gone, that's the cheapest, the other is some of the jet cleaners out there that clear out the jets that spray the water but I have no clue on the cost of those
Jan 20, 2011 | GE Nautilus 24" Built-in Dishwasher
Tip
We had an ongoing battle with white film on glasses and dishes, inside...
<p>If your <b>dishwasher does not seem to be cleaning well</b> anymore and you are getting<b> residue and film left on your dishes</b> then you need to read this.<br /> <p><br /> <br /> <p>Since July of 2010 the US Government has mandated that <b>dishwasher detergents</b> contain no more then 0.05% phosphates in them. The Detergents before this had contained up to 8.7% phosphates. The restrictions were for 16 states but many companies then dropped the phosphates from detergents to all states...<br /> <p><br /> <br /> <p>Now if you are having the <b>scum, film, and white residue problems</b> in your <b>dishwasher, </b>there is hope.<br /> <p><span>There is a product that you can buy that will compensate for what the makers of the </span><b>dishwasher detergents</b><span> have left out. This product as commonly know as </span><b>TSP</b><span> or </span>(<b>Trisodium Phosphate</b>).<br /> <p>By adding this to your dishwasher, you can manually add back the phosphates to your dishwasher and enhance the cleaning process.<br /> <p><br /> <br /> <p>Now the nest question...how much TSP do I add to the dishwasher?<br /> <p><br /> <br /> <p>For many dishwashers, waters, and for normal loads you will find that a tablespoon or two is all that you will need. For very hard to clean dishes and for some types of water you may need to add up to a 1/3 cup of TSP. <br /> <p><br /> <br /> <p>If you are having problems with your <b>dishes not getting clean</b>, a <b>black or scum film</b>, or <b>white residue</b> being left on your dishes at the end of the cycle, then I would start with a tablespoon or two and then adjust from there. Figure out how much you need to add to you dishwasher to make your <b>dishwasher detergent </b>work correctly for you again.<br /> <p><br /> <br /> <p>To best part is that you can have <b>clean dishes </b>coming from your dishwasher again!!<br /> <p><br /> <br />
on Mar 31, 2011 | Dishwashers
I have washed and rewashed my dishes with no soap and my glasses have a horrible white film and any of my plastics now have white film almost as if the soap is not rinsing off. I have resorted to hand...
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
l'l
Sep 25, 2010 | Kenmore 24 in. 17482 / 17484 / 17489...
When dishes are washed,the glasses come out with a white film on them and you about have to use a brillo pad to get it off, have tryed different detergents and used no heat setting, and still have the...
hi. empty out the dishwasher, toss in two cups of white vinegar and then run the hottest longest cycle, pot scrubber if u have it. If that doesn't work do the same thing with 2 cups of CLR from the hardware store, a calcium, lime and rust remover. J.
Jun 22, 2010 | Kenmore 17252 Free-standing Dishwasher
White film and food particles on dishes
Did you check the incoming water quality, regarding hardness!
If your washing machine supports salt addition technique, fill the appropriate box and fill the salt that is meant for washing machines. Salt works as a softener.
Finally check your rinse aid also for it's fill in the dispenser meant for it
Apr 11, 2010 | Whirlpool 24 in. DU1100XTP Built-in...
DISHWASHER MODEL # KUDS03FTBL2 WORKED VERY WELL UNTIL TWO TO THREE DAYS AGO DISHWASHER NOW LEAVES MASSIVE FILM AND DEBRIS (LOOKS LIKE FINELY GROUND UP GRAVEL AND DIRT) OTHER DISHES AND SILVERWARE HEAVILY...
There is a product out called the dishwasher filtration system. it filters the water going into your dishwasher reducing the hrad minerals that leave that white residue. it is very affordable and works amazing. it goes right under the sink and is easy to install. go to www.dishwasherfilter.com for more info on it.
May 01, 2009 | Dishwashers
Whirlpool gold dishwasher leaves film on dishes
are you in a hard water area such as florida ? do you have a water softener? if so take a can of frozen concentrate orange juice and put the frozen hunk in the bottom of dishwasher and run for one cycle. the citric acid will dissolve undisolved soap . this works much better. than vinegar which will only remain through the first cycle and then drain out as for the already grey glasses wash them in a solution of equal amounts red wine vinegar and water with just a touch of dish soap using a sponge.
Feb 16, 2008 | Whirlpool Gold 24 in. Built-In Dishwasher...
Dishwasher
Go to www.dishwasherfilter.com and have sparkling clean dishes with no film or spots, every time!!!
Make sure you use promo code DF5150 to get an additional discount!
Nov 14, 2007 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
GE Nautilus 24" Built-in Dishwasher Logo
173 people viewed this question
Top GE Dishwashers Experts
Mike
Garth Jackson
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
