Question about Canon imageCLASS D320 Digital Copier
We can't get our copier to print dark enough. Can this be fixed? Our copier is 6 yrs old . Colleen Snell
  • 10,515 Answers
If you are only getting light prints, there could be many reasons for the same. Unfortunately, as i cannot see the machine, i could only suggest few details that i have seen on these copiers.
As it is 6 years old, more likely the fault is with drum unit. You could try cleaning the charge roller with water .Do not touch the drum. ( best to first remove the drum from the unit ).
Try adjusting the image exposure up as far as it will go. Exposure calibration can also be altered in the 'Additional Functions' menu, under 'Settings & Adjustments'. Settings can be reset to the center if no improvement is made. It's hard to exactly diagnose but worth following the above option and maintenance schedule given by Canon.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Aug 22, 2010
My eltron ip2844 wont print dark enough. I went into setting and turned the burn darkness to 15, but still not dark? Help!!
This may be due to your thermal paper.
This printer doesn't deliver enough heat to your paper or you have a problem with the head pressure.
Press on the bloc while printing to see if it's this reason?
You may also have a mis-alignement of the thermal head.
Try also to change the print speed?
Aug 05, 2011 | Zebra Eltron LP 2543 Thermal Label Printer
Zebra Z4MPlus not printing dark enough
In your label software there should be a setting option for print darkness (I assume it adjusts the head temperature) In ours (bartender) you can get to it when you select 'print' and a window appears with a 'documents properties' button. Click on this and select options and a darkness bar appears which you can adjust. You may also need to slow the label print speed if the darkness adjustment is not enough. I suspect it isn't in the printers best interest to run the print head at maximum darkness/heat so a sensible balance of darkness and print speed is best.
Another, less likely, possibility is an incompatability between the label material or surface finish, and the ribbon type. We did have a problem once whem Homebase changed their price label design and we had to test a load of other ribbon types until we got one that did the job. A chat with the label or ribbon supplier is always usefull, they sent us several sample bits to test.
Sep 30, 2009 | Zebra Z4Mplus Label Printer
Printer not printing dark enough
go to the print settings select the dark scale
u can get print darker than the previous
May 27, 2009 | Samsung CLX 3160fn All-In-One Printer
My hp 1200 printer is not printing dark enough. this problem just started/ I can barely read the print. MY hp 1200 printer is not printing dark enough I installed a new toner cartage but it still does the...
If you have installed the toner cartridge correctly then it is a hardware problem called the Fuser and is the most common problem with printers...the fuser is a part of the printer which actually melts the toner onto the paper. The fuser has to get up to a high enough temperature to be able to melt the toner, if it is malfunctioning then it cannot give you a dark print. You may search google for Fuser information: Recommendation is change out fuser to repair problem. Pls rate this solution.
Apr 20, 2009 | HP LaserJet 1200 Printer
Copies are dark
No. It would most likely be the opposite.
The stripes could be caused by contamination of the dev roller, fixing rollers or marks on the drum.
You could also clean the laser ****-glass.
Apr 10, 2009 | Canon IMAGERUNNER 6570 Copier
Fax is received is very dark and almost unreadable
You can try using the menu to lighten the fax, but if all received faxes are dark, you may be experiencing a weak scan light. try making a copy instead of fax (which essentially is a fax printed to yourself) if also dark, its certainly your scanning imager that's failing. If that's the case I would recommend replacing the entire machine. Parts are expensive, and its a difficult to service part yourself. Also you may find that toner costs alone may pay for the replacement machine over this unit.
-Good Luck!
-FW
Jan 05, 2009 | Sharp Office Equipment & Supplies
Your HP PSC 1210 All-In-One
if cleaning wont work & cartridges are most 6 mos, trying a different cartridge will fix it
Jul 31, 2008 | HP PSC 1210 All-In-One InkJet Printer
Copy Quality Problem for Thiashen
bit vague...Cq not good? What does that mean?
Light copies> could be related to toner or ROS unit (laser unit)
if prints OK but copies U/S clean mirrors and ccd lens
Dark copies , streaking? Cleaning blade /drum unit U/S
or could be streaking from fuser roll
Patchy copies , dark edges, light edges ???????
more detail please
Feb 02, 2008 | Office Equipment & Supplies
Poor printing
With printers $23 at Wally world these days its not fessible to repair this age of printer. The problem we have with customers here locally is the same thing. We ask them "How old is the ink?" They reply "Its new!" then come to find out later that its new to them cause they bought it 6 months ago and havent used it since. Well typically if this is a cartridge printer eg:the tank and head is one unit, change the blasck cart. IF it has seperate heads change the black print head it has probable reached the end of its life, but the thing with the heads is there typically $30-$70 each which its more feesible to go get a new unit.
Sep 14, 2007 | Canon MultiPASS F50 All-In-One InkJet...
Canon imageCLASS D320 Digital Copier Logo
35 people viewed this question
old marine
old marine
