Question about Electrical Supplies
We have a Kawasaki GE5000 generator. Starts and runs fine but no power when we plug in an extension cord to operate powertools. Green light is also not on. thank you!
  • 90 Answers
There are several componants that need to be checked. you will need to know how to use a volt ohm meter to check the generating parts. there should be a rectifier and capacitor to check. then you need to check the field for a beak in the wire or if it is grounded. then you need to check the armature for a break in the wire. some armatures have diodes in the wiring and those need to be checked. then you need to check the outlet itself and the breaker. there are a lot of things to check.
Posted on Sep 01, 2010
Honda GX390 Generator not performing under load.
a GX390 Honda Motor but the used generator stator can be different cannot give more suggestions then measuring the circuitbreaker it can be broken the suggestion 60 mf capacitor can have trouble and electronic modul and bridge rectifier for some other dc connectors the coil diodes inside the stator. several options to go.
Jun 21, 2017 | Honda Electrical Supplies
How to flash a generator
Get two short extension cords and cut the FEMALE end off each one. Strip back the insulation on that end. Connect the two green wires to each other, and connect the two white wires to each other.
Connect one black wire to a light switch, and connect the other black wire to a 20W appliance-type incandescent light bulb. Also run one short black wire (from a cut-off end) from the second terminal on the light bulb to the second terminal on the switch, like so:
plug -- black -- switch -- black -- bulb -- black -- plug
plug -- white ----------------------------------- white -- plug
plug -- green ---------------------------------- green -- plug
Turn the switch to the OFF position.
Start the generator. Plug one plug from your new rig into an outlet on the generator. Plug the other plug from your new rig into a wall outlet supplying 120V. With the generator running, turn the switch to the ON position.
The bulb should flash for a short while, then become steady. When it's steady, that side of the generator is flashed. Repeat for the other side of the generator if it makes 240V.
Jul 22, 2014 | Electrical Supplies
Cannon penncraft cannon work
Jul 12, 2014 | Electrical Supplies
How do i flash my generator to get power again
Jul 10, 2014 | Electrical Supplies
What can I try next?
Jul 01, 2014 | UST GG2300 Portable Gas Powered Generator
Wall light switch timer inline with Extension cord GE 15313
Black to black (hot), Green to green (ground) and the only one left is of course white to blue. The (neutral) white wire can be many different flavors (blue, red, orange, brown, etc.).
If the outlet your plugging into (or controlled by the service panel breaker) is 15 Amps use a minimum of 14 gage wire (or 12 gage is even better), if its a 20 Amp outlet use 12 gage wires (or 10 gage). Don't use a 16 or 18 gage wire because it may get hot and start a fire because its undersize for the Amps.
Nov 13, 2012 | Hardware & Accessories
What is the proper oil and quantity used for a Kawasaki GE5000 AS generator
Can I just point out how NO ONE WHO ANSWERED paid attention to the fact that this question is about A KAWASAKI GENERATOR!? NOT A MOTORCYCLE!! Also, the filler cap will be on the lower region of the generator, with the image of an oil can on it, much resembling the oil filler cap on almost all engines, but smaller. I also though am wondering the proper viscosity and quantity thereof, and these "answers" were FAR from helpful...
Mar 17, 2012 | Motorcycles
The generator is locatd on my back porch. How can it be connected to the house electricity so I can use some appliances in my house? Can it be connected by an extension cord to a plug inside the house in...
the generator will need to be wired into your panel box, it is required by law to be done by a licensed electrician as it requires a safety switch to be installed. Now if you just want to run a extension cord inside you will need to physically plug into that extension cord. Hope this helps Tim
Jan 09, 2011 | Heating & Cooling
My kipor KGE 1000Ti starts fine but after several minutes stops generating and the red overload light comes on, with the demand for power left connected and the generator still running electrical...
You may be UNDERLOADING the generator and it may be unstable with such a light load... see if it might behave running a heavier load... put a 100 watt light on it as a test,
Jul 25, 2010 | Electrical Supplies
Electrical Supplies Logo
456 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
