Accidently selected s-video connection
While messing around with my Mustek V56L-5E DVD player's menu on my Samsung tv, I accidently told the TV to use the s-video signal to connect to the DVD rather than theYUV connection. As I have no s-video cable their is no such connection, and now the TV can't display the DVD's menu so I can't change it back! So now I can't use the DVD player at all. I can't seem to find any option on the DVD itself to change the selected connection. How can I change the default connection back to YUV, or do I have to get an s-video cable?
    Novelist:
    Champion:
  • 236 Answers
You get to the menu options of your TV not the DVD. you should be able to find the input selection for your video.
Posted on May 04, 2008
How hook up dvd player to tv. what channel put tv on to see dvd pitcure
You should be connecting your DVD player to either an HD input or a composite video connection. Most modern TV SHOW will have at least 2 HD connections. On your TV setup menu there should be an HD connection to choose (probably HD-2) You will need to switch your input selection on your TV menu between HD/TV for TV and HD2 for DVD. It's hard to give specific directions without knowing the TV and DVD models.
Oct 27, 2016 | Televison & Video
VCR/DVD & Samsung TV: "weak or no signal"
Take the VCR remote, check VCR output settings ( scart1, scart2 , RCA) and signal format (PAL) etc
Jul 26, 2008 | Samsung TX-T3093WH TV
Tf d Ihave a tf dvd7100 I am trying to hook it up to my tv to plac a movie cd
HI,
Before connecting the the DVD to your TV First of all you have to the audio out put of your for the do the following using the setup menu.
Press SETUP button of of the DVD player to show "setup" menu. Select the audio setup the select the digital out then change to OFF from SPIDF/RAW.
Here i have added a picture which shows how to hookup the dvd player to a TV. Its for the same model that you have .
to make the connection you need two codes
1. 3.5mm stereo to two RCA (for audio)
2. 3.5mm mono to single RCA(for video)
connect the first cord to inoptical/audio and second one to video output of the dvd player.
connect the cable which comes from the video out out of dvd to the video input (yellow) of your TV. then connect the cable which comes from the inoptical/audio of the dvd player to the audio input of the TV (red and white ).
You have to select the input of your TV by pressing the AV/ source selection on the remote of the TV. check where you made the connection on the tv AV 1 or AV 2. then select the corresponding input. hope you will get it worked.
Also Added the image of the cable that you need to make the connections.
25383850-eev1v0sv1zwox43luwgxtns5-4-5.jpg 3.5mm stereo to two RCA (for audio)
Electronics Equipment Repair Center
Jan 25, 2015 | Coby TF-DVD7107 Portable DVD Player
I connected my sony DVD player to a 26" sanyo tv. I used the enclosed cable. I plugged the cable in as shown using yellow to video and red and white to audio. Selected video 1 input on tv the DVD...
If you have red, white, and yellow on both DVD and TV it should work. The DVD is obviousy an output so, check your connection on TV. You may find that if you scan through the TV's menu, you will have sound in one arae and picture in another. If you have a DVD in or AUX input on the TV try, and make sure you use the inputs for the respective setting, to hook up there and see what happens. You want input on TV.
Jun 20, 2011 | Sony DVP-SR200P DVD Player
I accidently selected in the setup for TV type> Aspect 4:3 & 480p. The setting was on Aspect 4:3$ 480i. Now I cannot stop my screen from rolling so I cannot get back into the Setup area to change it back....
connect an rca connection cable on the yellow video output on your dvd player to your tv, grab your tv remote and select that input, then go to the setup menu on your dvd player and change the settings.
Apr 27, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
Hooking up & seeing a dvd player?
does the dvd have a coax output for coax antenna input on the tv? you can use that untill you can get the video input selection straight with the tv and a remote that supports rca's extra functions such as menu , tv/av button
or
also if there is a( wake-up) on/off timer in the tv menu , then you can also set it to come on with the video input instead of a tv station,set it a few minutes after the time it is when you set it( then just turn off the tv set after the time is set and you have exited the menu, then it will come on with the video input instead of a tv station)
otherwise you will need that remote that supports the video input selection on your tv
Jan 08, 2009 | RCA F20625 20" TV
Mintek 2110 no component video
You need to change the Video out in the menu.
Press set up on the remote
move down to video out and select YUV output
it should now work
Aug 08, 2008 | Mintek DVD-2580 DVD Player
HELP - Samsung DVD player P347
From the manual...
Connect the DVD to the TV via S-video or Video outputs (not component video) and...
• Press power on from a cold start with no disc in the unit. Press the
SEARCH/SKIP ( ) button on the front panel for 1 second.
The SELECT MENU LANGUAGE display will appear.
Select the number button of the desired language.
regards, Glenn
keraurus (at) gmail.com
May 17, 2008 | Samsung Televison & Video
DVP334V cant connect to my LCD TV
  1. Connect the video cable to the players VIDEO (CVBS) OUT (yellow) jack and to the TV's VIDEO IN jack.
  2. Connect the audio cable to the players 'AUDIO LEFT' (white) and 'RIGHT' (red) output and the TV's 'AUDIO LEFT/RIGHT' input jacks.
  3. After it is hooked up, you will need to select the TV’s video input channel that corresponds to the jacks connecting the player to the TV.
    • Press STANDBY-ON to turn on the player.
    • Turn ON the TV.
      Note: Video Input selection varies for different brands/models of TVs. Consult the user manual or manufacturer or your TV if none of the below is successful.
      • Press channel 2 on your TV. Then press the channel down button to locate the video input channel. (This channel is usually located between the lowest and highest TV channels.)
        OR
      • For some TVs, there may be a button on the TV’s remote control that accesses the video input channel labeled SOURCE, AV or SELECT.
        OR
      • Select the Video Input Channel from the TV’s on-screen menu system.
Composite Video Connection. (Example Only)
051104165152_4352.jpg Attachments
    No attachment available.
Dec 25, 2007 | Philips DVP3340V
Cyberhome 300 dvd
When I had this issue it was resolved by selecting the video input on the TV. For example: "S" video, RGB, etc. And of course check all of the connections.
Aug 15, 2007 | Cyberhome CH-DVD 300 DVD Player
Televison & Video Logo
81 people viewed this question
Top Televison & Video Experts
