Question about Hayward 250kbtu Ng Pool Heater - Inground
Error code either 5f or sf. any suggestions - Hayward 250kbtu Ng Pool Heater - Inground
    Problem Solver:
  • 15 Answers
Temp sensor failure. The temp sensor should be screwed into the header near the plumbing and is wired in to the control panel ( where you raise or lower pool temp) Almost positive the wire is blk/red
If you unscrew the temp sensor and its corroded ( green) try cleaning it with a wire brush, if it still doesnt work, replace the sensor. Worst case, the new sensor doesnt work, that means the old sensor was fine and its the board that its plugged into thats bad. Not likely, but always possible... sensor is much cheaper then a board so go that route first.
Posted on Aug 22, 2010
SF-P95JJ GIVE ERROR C9
Not "hitachi washing machine error code c9 what to do"
electronicsfurnitureinfo.com/.../hitachi-washing-machine-error-code-c9-...
Info about hitachi washing machine error code c9 what to do in Electronics ... What do you think about this washer Electrolux ZWT-61M, do you like the design?
Jul 28, 2015 | Washing Machines
5 f code after hearing poping noises filter and pump are new
SF (not 5F) = Temperature Sensor or Thermistor
HS = High Limit Sensor
Heaters Set Temperature out of Sync with actual Water Temperature.
Heaters Maximum Water Temperature has been Exceeded.
A few reasons this occurs...
  • Low water flow thru heater, check :
    • Dirty Filter
    • Opened By Pass Valves
    • Plugged pump impeller
    • Dirty/Full baskets at skimmer or pump
    • Anything that may reduce water flow
  • Sensor could actually be doing its job, in a different aspect, Thermostat failure, and water is overheating in spa or pool?
But anyway, your heaters fault code you asked about does not necessarily mean the sensor failed, but is only informing of a problem.
Jun 07, 2015 | Hayward Pool & Spa
What should I do if Hayward pool heater is reading error code SF??
The code is SF. This is a teemperature sensor failure. Check the wiring on the electroniics bord and confirm its not damaged and that it is securly plugged in. If all is good than the temperature sensor will need placing.m either a gas fitter or swimming pool reepair center will help with this is your not comfortable replacing it
Jul 15, 2013 | Pool & Spa
My mark 6 pool heater has power but is displaying "5f" help???
The actual reading is SF and that indicates a temperature sensor failure.
Mar 12, 2013 | Hayward 116k HeatPro Heat Pump HP3100
Hitachi SF-P95FJ WASHING MACHINE ERROR CODE F9
if you have Hitachi nw-d8ax f1 error check water sensor f3 error check rinse filter f9 error do not know where the error but I did repaired, remove back panel and right hand side inside polithine cover find blue connector its with 2 wires remove it and switch machine it will give f3 error with sound reconnect the socket its started working
mail me if yours working I will give you more tips nava@netintec.com cheers
Oct 29, 2010 | Washing Machines
Error f1
How do you do. You should check join from the main of the charge to device сортера.If connections is checked and where are no mistakes in join no pay attention to mechanical possible damages, findings scrap papers and stranger subject in sorter device. Recall, pr what circumstance appeared the fault.Error code F1 for sharp copiers sf 2020.2030 Sub code 00: Communication error between main board and sorter. Sub code 02: Sorter transport motor drive.
Sep 23, 2009 | Sharp SF 2020 Copier
ERROR MESSAGE 5F
This fault concerns the relay drive circuit. If this fault code cannot be canceled, replace the oven control (also called clock or ERC).
Jul 26, 2009 | GE JKP15 Electric Single Oven
Hayward 250kbtu Ng Pool Heater - Inground Logo
1,311 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
