Question about Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model
I have Craftsman lt2000 with 18hp ohv engine...runs perfect until hot. It then will sputter as if running low on fuel or losing spark.have replaced fuel filter , changed the spark plug, changed oil/filter, and the air filter. is there a coil that may be cracked? or is it possible something more serious like a cracked head/intake, that is expanding when hot?
  • 472 Answers
IS THAT A BRIGGS 24 HP
Posted on Aug 22, 2010
  • jerbanta Aug 22, 2010
    no, just the Briggs 18hp ohv
  • 27 Answers
Sounds like coil my be braking down
Posted on Jul 10, 2014
18 HP OHV Vapor locks or real warm day after working 30 min or so.
is the air movement correct under the hood? Newer models have a plastic shield on the hood to direct cooling air for engine. Is this known to help my problem?
Posted on Aug 15, 2012
  • Gene R Steere Aug 16, 2012
    18 HP OHV Vapor locks on real warm day after working 30 min or so.
    is the air movement correct under the hood? Newer models have a plastic shield under the hood to direct cooling air for engine. Is this known to help my problem? I have hydro-stat so I run high speed when mulching.
Why is my craftsman running rough?
Black smoke means it is running rich. Too much fuel or not enough air. I doubt that it is an air issue. Check the float and carb.
Aug 16, 2014 | Craftsman Garden
Ohv 179cc snowblower engine will not start
I'd check to make sure any fuel shut off valve (often "inline" or located directly under the tank) is open or on. Check or replace any inline fuel filter as well. If your snowblower has a priming bulb, you should hear gasoline spritzing after the second or third full press. More presses will probably cause gas to drip out of the carb to the ground. Next, check the spark plug. Clean or optionally replace it - set / check proper gap. With the plug out (and the spark plug wire away from the spark plug's threaded opening in the engine) pull the starting cord several times, and then check for the smell of gasoline in the cylinder. If no gas odor, you may have a bad float in the carb or other blockage. It will not run until you can get fuel into the cylinder. You can try pouring a few drops of gas into the cylinder of the engine via the spark plug opening or give it a "quick blast" of aerosol starting fluid or ether. Reinstall the spark plug and try again. If you added fuel, starting fluid or ether, the engine should have either attempted to run or sputtered briefly or is actually running. If it did neither, check for spark. Remove the spark plug wire from the spark plug and insert the tip of a screwdriver into the boot on the end of the spark plug wire and position the screwdriver's shaft to within 1/4" of the top of the spark plug. Be sure to only hold the screwdriver by the insulated handle (do not come in contact with the metal shaft of the screw driver) and pull the starting cord again. You should see a spark jump to the spark plug. If none, you may have a bad spark plug wire or magneto - and need to clean or replace it. before trying again. Good luck!
Feb 02, 2014 | Yard Machines 31A-62BD700 179cc OHV...
1999 dodge ram 5.2 runs about thirty miles then stalls after running fine just suddenly loses all power sputters backfires engine stumbling badly. crank it up 4 or 5 hours later runs a little then same...
General advice:After warming up track the problem:sparkplugs (even new can have the ceramic parts broken/cracked /wiring (after warming up the isolation get's soft,can loose spark power)/ignition coil(s) (gets hot,stop runnig),running reach,fuel pump/fuel pump relay.Best guess:fuel pump mallfunction (low pressure) related,fuel filter cloged/water in the fuel/fuel line cloged/chipped. Cheers,hope u figure it out,let the people know.
Oct 26, 2013 | 1994 Dodge Ram
Briggs& Stratton 18hp OHV Intek engine will run only under a load.
Your PTO safety switch is opening intermittently. Would help if you would always add your model # such as 917.100000 that way I could look up on Sears site and tell you approx. Location of switch.
Aug 28, 2017 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
1o h.p. generator, starts fine, runs good for short periods then kind of sputters, a single sputter, but every second or so and will run like that for hours, thought running would help, didn't.
I realize you have a 10 Hp Briggs engine. The symtom your describing is often caused by the valve lash gap being to narrow on the EXHAUST valve. You may have a 0.001 gap cold but when it warms up that gap is less and you get just a bit of compression blow by but not enough to impede power output. Over time it will usually get harder and harder to start. The remedy is to reset the valve tappet gap
Depending on what engine you have the GN series the gap for intake and exhaust is 0.002 with the flywheel directly at TDC.
Standard OHV Briggs are adjusted with the flywheel 1/4 inch past TDC to a gap of .004 - .006.
The Jam nuts are torqued 65 - 85 inch lbs
Non OHV engines L-head are adjusted .004 intake and .006 Exhaust at TDC by changing valve stem length with a grinder or replacing the valve if necessary.
If you still have the problem after doing the above... replace the spark Plug... (again even if yours is new) After spark plug replacement you still have the problem respond here and I will help you until this is resolved.
This could also be a case of the fuel mixture just a tad lean..
Thanks for choosing FixYa,
Kelly
Aug 29, 2011 | Briggs & Stratton Briggs Stratton 6200...
Craftsman 18in. chainsaw. Engine stops running after use for 15 mins. Will let sit until cool, starts up immediately but engine power is very weak and eventually sputters out in a short amount of time.
Two possibilitys here, either a clogged fuel tank breather ( slacken the fuel cap when the problem occurs, this will allow air into the tank, if this cures it replace the tank breather ) the other possible cause is an ignition unit breaking down when hot, unfortunatly this will be a case of replacing the ignition unit.
Feb 15, 2011 | Craftsman Garden
Craftsman DLT 3000 18.5HP - Engine Dies
sounds like the choke mechanism is stuck in closed position, causing a overly rich mixture, to check this removethe air filter cover, element and housing, there are two nuts and a 5/16 head screw somewhere that need to come off too, then pull off housing and you will be able to see the choke plate, it should only be closed when throttle lever is all the way up. when you determine if this is the pronlem or not you can email me if you want
thisoldtruck2@yahoo.com
May 16, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Motor chokes and misses under moderate load and loses power
Sounds to me as tho it might need a carburetor adjustment, providing there is an adjustment screw on the carb. Sounds like the engine is running a bit lean. Did this problem occur right after the carb cleaning, or was it there in advance? Is there a fuel filter that might be clogged?
Jan 18, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Sears 19 hp twin 42 inch tractor, won't start if hot
Hi
Two things come to mind. First it could be not getting enough fuel when hot due to carb adjustment being too lean. That could be that the float level in the carb is set too low or the low speed jet is set too lean. When cold the choke circuit in the carb supplies the extra fuel required.
Second in some enjines that have low compression they start cold but when hot the compression drops below 60 psi and makes starting very difficult until engine cools down.
I suspect a fuel problem.
Nov 25, 2008 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model Logo
922 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
