Question about Welding Tools
Mosa magic 150 does not increase revs when load is applied
I just bought a 2010 buick enclave cxl and on slight incline in drive will roll back. ? Its like the rpms arent where they should be. I don't think the weight should pull it back so much. Thanks
The parking brake is the way to stop it rolling back. Idle RPM are set and have no bearing on how the car rolls back. apart from if you increase the revs, the car will move. The proper procedure on an incline is to apply the parking brake, put the vehicle into drive, increase the revs and take off the parking brake. Just like we did in the old days when we had manual gearboxes :>)
May 24, 2016 | Buick Cars & Trucks
Is the servo faulty if the engine revs increase when applying the brakes?
Sevo is independant unit would not imagine it would affect engine revs
Nov 26, 2015 | Cars & Trucks
Is the servo u's if the engine revs increase when braking?
Hi Gordon:
Don't know about servo's but here are two circumstances that I know can be real:
1) gas pedal and brake pedal may share a common linkage component. When the brake pedal is depressed, "drag" on the throttle component could occur, opening the throttle..
2) Brake pedal and gas pedal may be close enough that the sole of your boot can "overlap" and catch the cas pedal at the same time that you are pressing down on the brake. This has happened to me, and has been the documented cause of accidents.
Hope this is of some help.
Cheers.
Bernina Virtuosa 150 Presser Foot Loose
try increasing the presser with the adjuster
Feb 10, 2014 | Bernina Virtuosa 150
Who has the solutions manual to this book ? 'Introduction to CDMA wireless communication' by Mosa Ali ?? Please help!!!
Your teacher must have a complimentary copy. Or your university/ college bookstore. But the publisher certainly has it.
Jul 31, 2013 | Academic Introduction to CDMA Wireless...
My 94 honda accord fills like it's going to stall when the ac is on
EARLY AC SYSTEMS HAD AN ADVERSE AFFECT ON THE REVS OF A VEHICLE, YOU CAN RECTIFY THIS IN TWO WAYS, EITHER DON'T USE YOUR AC SYSTEM OR INCREASE THE REV IDLE LIMIT BY 150-250RPM
Sep 02, 2012 | Honda Accord Cars & Trucks
I recently modified my dream machine the original pulsar150,by adding alloys and wide tyres both front and rear,so obviously the pick up will decrease,so i want to know that will there be any load on the...
It seems to me that the wide tires, if properly inflated, would not adversely or significantly cause an increased load to the engine, unless they were underinflated. I would just look for clearance issues on the fork and other parts of the frame and mud guards.
In the 1980s, when all terrain bicycles were introduced with 'fat' tires, increased traction on roads compared to their skinny tire race bike counterparts was enjoyed by the masses (Mountain bikes vs. racing bikes).
I think that on a motorcycles, the same would apply.
I don't think the K&N filter would significantly increase pickup, despite advertising to the opposite. Just use standard air filters.
Good luck on modifying your bike to your 'dream machine.'
Dec 28, 2010 | 2005 Bajaj Pulsar 150
Wont idle properly.
vacuum leak.....get some carb cleaner an when you can get the bike to idle somewhat normal spray around hoses and intake manifolds...if idle increases that where the problem is.
Oct 08, 2009 | kawasaki GPX 250 R Motorcycles
Colors all messed up
The fact that you used the term "magic focus" tells me you have a Hitachi projection set. When the colors no longer line up on a Hitachi projection TV, it means that most likely one of the convergence output IC's has shorted out. Sometimes a shorted convergence output IC will burn up a low value resistor too. I have also seen a convergence IC crack loose from the board and burn up 3 low-value resistors. If your set is using the STK392-110 IC's, it is probably a good idea to go ahead and replace both IC's with the newer upgraded STK392-150 IC's. The output IC's should be resoldered / replaced and the circuits checked and realigned by a qualified tech familiar with Hitachi projection sets.
Sep 09, 2007 | Hitachi 61SWX10B 61" Rear Projection...
Welding Tools Logo
60 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
