Question about Epson R1900 Printer
Hi, have just returned from a 5 week break, have switched on my Epson R1900 and the print head seems to be stuck. The friction strip that usually moves the print head makes a ratcheting noise as it runs through, but the print head itself doesn't move. Both the paper and ink warning lights then come on, and a 'general error' message appears. There is no paper in the printer and no obvious blockages. John
JayBlair
  • 328 Answers
SOURCE: printer
Heads are clogged. Has it been sitting for an extended length of time? Ink will dry up in the heads and tubes. Alot of work to take apart and clean and may still not work. Try to get a service manual at justmanuals.com
Posted on Aug 09, 2007
  • 26 Answers
SOURCE: Epson 1280 Printer breakdown
it is the wasted ink pad, they are full.
to have your printer work again
turn off the printer.
press and hold the ink and paper button while turning on the printer, wait for 5 seconds then release the button and press the paper button for at least 10 sec.
if done correctly , you will see the carriage start moving
Posted on Jan 21, 2008
SOURCE: EPSON R300 PRINTER NOT FEEDING PAPER INTO MACHINE.
my epson r300 makes all the right noises when feeding paper but will not draw the paper through can you help
adrian
Posted on Apr 30, 2009
Remag1234
  • 387 Answers
SOURCE: my epson stylus R1900 printer wont recognise an
Call Epson for a replacement. Get a CISS for your printer. It will save you TONS of MONEY, never change a cartridge again and it will pay for itself in a month.
http://www.inkproducts.com/ink-store/
Posted on Jun 23, 2009
bhagyavichar
  • 414 Answers
SOURCE: Head won't move far enough to the left to get cartridges out
seems a case of carriage jam n needs servicing..
howevr, do it if ur printer is out of warranty and u r a professional..
check for loose/faulty carriage-belt and the drive-assembly..jammed/sticky cleanser-unit (esp the rubber, gears n base)..
also chance of defective/faulty photo/opto-coupler 'sensor(s)'..the diodes and resistors in dis section..
always better to hv professional supervision, contact ur system admin/vendor....
Posted on Oct 31, 2009
Epson R1900 cartridge carrier goes lef and grinds until it stops with flashing lights
It;s general error or fatal error. Find the Adjusment Program for R1900, then Click Printer Information Check. You will find the latest fatal Error code. You can figure the actual error of your printer.
Jan 17, 2013 | Epson R1900 Printer
I have the Epson R1900 and I did a nozzle check twice and head cleaning twice. I am unable to check my supply levels. I am getting a message saying to only use genuine Epson Ink but that is what it
More than a little unusual that the printer is reporting non-OEM cartridges if those are the ones loaded unless your cartridge supplier has obtained their stock from another sales zone, in which case it may be that the printer is not recognising them as being valid.
Presumably, given the model you are getting the warning on your computer so you can disable this status monitor by doing the following:
- Open Printers & Faxes (or the equivalent for your operating system
- Locate your R1900 printer in the list
- Right click and select "Printing Preferences" (or "Properties" followed by "Printing Preferences")
- Click the "Maintenance" tab
- Click on the button marked "Speed & Progress"
- Tick the box marked "Disable status monitor 3.0" (The exact line may differ)
- Click Apply then OK
This should disable the annoying "Use genuine" warnings although it will also disable your ink monitoring capabilities via software.
I would still contact your supplier and/or Epson to complain about the problem and ask for replacement cartridges for the ones most recently changed as obviously this is something that should be covered under the cartridge warranty.
Hope that helps.
Dec 14, 2012 | Epson R1900 Printer
I have had my Epson R1900 since last July, and it has worked just fine for me up until a couple of months ago when it began printing with a very noticeable blue-green tint. I always use Epson 87 inks, and...
using your printer once a week makes your printer clog even if you use original cartridges i prefer using it once a day, if you dont have anything to print, just turn on your printer and it will automatically head cleaned its head
May 24, 2011 | Epson R1900 Printer
My R1900 is over 1 year old. Profiles are set for Epson glossy and matte paper. Epson ink is used. Colors are now very green when printing to glossy or matte paper. However, if I use the plain paper...
The difference in choosing the paper type will have an impact on how head squirts ink onto the media. For Epson printers, the best choice to fit the color is plain paper.However, to the maximum dpi (best photo or photo rpm), plain paper does not support.This can be overcome by adjusting the color management of the program that we use.Or convert to bitmap all objects (such as Corel Draw), or also in print as bitmap option.
Feb 22, 2011 | Epson Stylus Photo R1900 InkJet Printer
Power light is out and the two amber lights are flashing at same time.
Power off and paper and ink flashing alternately:
Parts inside the R1900 Series are at the end of their
service life or an unknown error has occurred. Contact
Epson for help
Power off and the paper and ink flashing fast:
The print head is obstructed by paper or other foreign
material. Turn off the printer, remove any obstructions,
and turn it back on. If the error persists, contact Epson
Good Luck!!!
Nov 02, 2010 | Epson R1900 Printer
Epson 1900 inket print head clogged
Hi There
Summary
Usage of compatible ink and leave the printer idle too long may cause printhead clogging
What should you do if you get this problem. Relax; you may recover the printhead by unclogging it. Follow these steps to unclog the printhead
1. Right click in the printer driver name
2. Select Properties menu
3. Click Maintenance tab
4. Click on cleaning sign for regular cleaning. Perform this up to 3 times.
5. If this does not work, perform Deep Cleaning
And if that not work
Some times it needs a good clean up but this is up to you if you want to do this,
But after you done this prime the printer so it gets the inks back in the heads, it may take a little time for the inks to work.
Ok.
There is fluid cleaner for this but I can never find any in the shops the only ones I seen is when they sell them in Tesco but they come in with the ink refill bottles so I just use worm water by it self on a cloth and dabbing on the heads to clean them, it will not harm the heads but not to much water.
Some heads are on the inks them self but some have them inside the printer so I not know your printer so if the heads are inside you need to get them out you may find that some heads will just clip out put some need to be unscrewed so you got to know how they come out so be careful and not push to hard on them, if the heads are on the ink then it is a easy job to clean them,
It worth a try it worked for me more than ones.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Apr 07, 2010 | Epson Stylus Photo R1900 InkJet Printer
Printer prints to dark
Hi and welcome to Fixya!
your print head needs cleaning ..
Thanks for using FixYa!
Jul 18, 2009 | Epson R1900 Printer
How long can epsonR1900 printer last ?
RETURN PRINTER FOR FACTORY REPLACEMENT OT TO THE POINT OF PURCHASE.RICHARDM69
Dec 13, 2008 | Epson R1900 Printer
Epson stylus cx3200 printer when switched on display says printer error get assistance fron engineer
Check there is no foreign objects in the way of the print head. Check the encoder strip is clean and in tact. Ensure the print head can both leave and return to the home position easily. Check that the head lock is retracting when power is turned on.
Sep 14, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Open Questions:
See all Epson R1900 Printer Questions
Epson R1900 Printer Logo
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
