I have an older model Toshiba CF1927B and I am moving to college soon. I need to know how to hook up a DVD player to the TV. Usually I'm pretty good and this kind of stuff. But I have no idea. Thank you.
  • 236 Answers
SOURCE: toshiba 36a41 television
You should be able to use your remote control to do this.Your channel 73 is more than likely UHF 73 so you need to put your tv in the antenna setting rather than cable setting. Once you do this just input 73 with your remote. Hope this helps! Stargazer
Posted on Jan 28, 2007
  • 205 Answers
SOURCE: connecting Panasonic DVD to TV
What kind of cables are you using to hook up the DVD to the TV? Are they they composite, component, or S-Video? What are the connectors you're plugging both ends of the cables into labeled? Are you plugging the audio cables into the TV or directly into the sound system?
Posted on Jan 12, 2008
SOURCE: JVC DVD player problem
press and hold I\P button from remote control
Posted on May 16, 2008
  • 48 Answers
SOURCE: connect magnavox dvd to ge tv HELP!
There are a few options to connect an older t.v. with a DVD player.
  1. You can connect your new DVD player to a VCR....not recommended as quality loss will occur....use RCA plugs (Red/white/yellow) but it is easy...and many people have an extra one around
  2. plug one end of RCA cord into DVD player, other end to VCR (colour match red plug to red cord)
  3. then to connect VCR to TV...use the coax VIDEO OUT (on VCR) to the TV
  4. OR you can purchase an RF modulator like this at http://www.amazon.com/exec/obidos/tg/stores/detail/-/electronics/B00009MDBN#moreAboutThisProduct
  5. this option has a greater cost...but the picture quality will not suffer....Note..you will not have Surround sound...but as it is an older tv. you were not used to that anyway..
Great way to keep an older working t.v. out of the landfill
hope this helps!
Posted on Oct 09, 2008
jsinex2421
  • 62 Answers
SOURCE: dvd is grainy picture
You can use your old on, but I am guessing it doesn't have progressive scan. If it does, make sure to hook it to your TV using a component cable.( RED GREEN BLUE ) Then you will have to hook the audio up seperately with a standard red and white RCA cable. Do nt try to use a standard RCA video cable in the place of a componenet cable. Once you have the compnent (RGB) cable and RCA (RW) cable hooked to the TV, check the DVD menu and make sure it is set to Progressive Scan. If you want the best picture for your HDTV. I highly reccomend a blu-ray disc player. That is the highest quality. There are some prety good upconverting DVD players out there. They take the 480p signal and upconvert them to 720p, 1080i, and 1080p. These have HDMI outputs and connect quickly and easily to the TV you have. Most of them can be purchased for less than 100 bucks. But this would be your second best option. Before you shell out 400 bucks on a blu-ray player, go to a rental company and rent a blu-ray player. Once you see the quality of blu-ray, I think you will run out and buy one!
Posted on Jan 10, 2009
Can not hook up my dvd to my new vizio tv
What is the brand name and model number to your DVD player?
Jun 07, 2012 | Toshiba Televison & Video
I just need a diagram to show me how to hook the dvd/vcr up to my television. I have Dishnetwork as well. I un-hooked and now I can't get a picture.
Not knowing the model of the TV its hard to tell you how to hook it up. Howeever let's assume that yu TV has an auido in and a composite video input. it it does is should have three RCA jacks on the back...one red, one white and one yellow.
Assuming Dishnetwork is being used as a analog video.
Connect the VCR/DVD player via a patch cable ( usually has three cable all color coded, red, white & yellow) Red and White section is used for the audio Left and Right. The yellow cable is video.
Connect the audio out of the VCR/DVD player to the audio input on the TV. Do the same with the videoout of the VCR/DVD to the TV may be marked "Composite Video". Now connect your Dish Network receiver RF Out to the TV. This should be a coaxal cable.
Now when you want VRC/DVD use your remote and select input. Some older TV's have the aux input just before Ch 2. Some remotes have an input button.
once you have aux inpsut selected turn on the dvd and play your movie to view Dish go to Ch 3 or 4 depending on how your TV and system is set up.
Again not knowing the model TV you have, this is a general hook up.
Thank you Let us know if it helps
Tom Miller
Broadcast Engineer
Sep 09, 2011 | Televison & Video
I need a manual for an SD310VU MODEL it was given to us but we do not know what we need to hook it up to our TV. Can you help us Thank You
Toshiba has the manual for the SD-310VU at their site: http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=SB&os=&category=&moid=2841310&rpn=undefined&modelFilter=SD-310VU&selCategory=2797338&selFamily=2797344 .
You can connect the DVD player to your TV either with composite video (AV), S-video or component video cables. For the best signal output, get component video if your TV supports it. So the issue is what inputs do you have on the TV. For an older TV with only a coaxial antenna input, you would need an RF modulator for the composite video cable. (These are available at shops like RadioShack.)
Composite video cables usually have 3 RCA plugs on each end (yellow for video, red and white for audio). S-video uses a different plug and then the audio is carried on a different cable (usually red and white RCA plugs). Component video cables use three wires to carry the video (YPbPr - usually colored red, green and blue). As with S-video you use a second cable for the audio.
Purchase the cable(s) that will give the best signal with the inputs that your TV has and connect the video outputs from the DVD player to the matching input on the TV. Connect the audio out of the DVD player to either the TV's input or your sound system receiver, depending on the speakers you want to use.
I hope this helps.
Jun 16, 2011 | Televison & Video
Need to know how to hook up a Toshiba DVD player to a TV
To hook up a toshiba DVD player to a television, you need to get the prongs, that you will use to hook them up.
You have a prong with red and white tip, locate the audio out on the DVD and plug in one of the prong in it then locate the audio in on the television, then you plug the other prong in the video out of the DVD player also you plug it in the video in of the television.
That is all you need to do, then you ensure you have your television on the AV mode to enjoy the DVD player on it.
Take care and good luck
Oct 22, 2010 | Toshiba SD-2109 DVD Player
I'm trying to hook up my Panasonic DVD player (model DVD-S29) to a Comcast cable box but have not been successful. My DVD player only has Audio Out connections, with no audio in connections. I...
the cable in should go to the box and cable out from the box to the TV.These should all be coaxial cables correct?Hook up the DVD player to the TV using the red,white,and yellow cables is also correct.In order to watch a DVD,you have to use the input select button on the remote for the TV ONLY to change inputs.If you have a universal remote for the TV and not the original factory remote provided with the TV,you need to use the menu button located on the outside of the TV.I just searched on my flat screen and was unable to find an input select through the menu button.It may not be possible on this TV if you do not have the original remote and if you own a universal.My universal for one of my older TV's is about 7 years old so I do not know if newer ones have an input select option.If they do not,it is most likely due to patents and royalty payments which these cheap remote makers do not want to pay.Anyhow,let me know if this helps.Just comment here and i will get an auto link to your comments.Good luck! Greg
Sep 19, 2010 | Panasonic DVD-S29 DVD Player
Emerson Model EDW 2203 DVD/VCR Player
Mar 02, 2010 | Emerson EWD2203 DVD Player/VCR
I HAVE A OLDER (2005) TOSHIBA MW24FP3 DVD/VCR/TV COMBO UNIT. THE DVD PLAYER IS STARTING TO RUN OUT OF GAS, SKIPPING, SHUTTLE PROBLEMS ETC. CAN IT ACCEPT AN EXTERNAL DVD PLAYER THROUGH THE FRONT CHASIS...
Absolutely you better bet it can, just hook up the cables to the front and select the input on your tv and you should be ok. For the internal DVD try running a cleaning disk you never know it could be just dirty.
Thanks if you like my advice and solutions please use the thumbs above to rate it and give me some feedback as well.
Jan 30, 2010 | Toshiba 23HLV84 23 in. TV/DVD Combo
Craig dvd player, model CVD327, won't play
no, s video is not required to work. if you hooked up 3 colors to the tv 3 colors. make sure it's on video 1 or aux channel. and as long the dvd player is on and that channel is on, if that does not work, try on another tv that has same connection. if that doesn't work, then we know that dvd player doesn't work.
Oct 17, 2009 | Televison & Video
Only getting sound but no picture!
Well, i had a look at the back of that Toshiba TV - make sure that the red, white, and yellow cables are hooked into the Video-1 slot of the Toshiba and that the Toshiba channel is changed to Video 1.
Then check your nameless DVD player and make sure the red, white, and yello cables are all hooked to OUTPUT slots that are in the same column or row - if I had you DVD manufacturer and model #, I could suggest some additional steps to check. Also, make sure your dvd player is in dvd playback mode.
-Tha Mp3 Doctor
Dec 31, 2008 | Toshiba 42HL167 42 in. LCD Television
Televison & Video Logo
67 people viewed this question
Top Televison & Video Experts
Electro Med Services...
