Question about Kenwood Radio TK 260 360 270 370 2100 3100 Compatible Battery
I have a kenwood tk260. When I press the talk button it seems to lock and the light flashes red.
  • 3 more comments
  • Randy Hartman Aug 22, 2010
    I have done that. I even tried a different battery from a different radio that works.
    You misunderstood me. The good battery didn't make a difference.
    The battery is good.
    Also when you press the talk button it emits a tone continously.
    I have a Kenwood tk260 tranciever that will not transmit. It has 4 frequiencies in it. It will receive on all 4. When you press the talk button it emits a continous tone and the red light flashes red. If you try to transmit the red light flashes orange but nothing happens.
    President:
  • 3,278 Answers
Hello.
The Low Battery alert causes the red TX LED to flash a warning when voltage drops. The Battery voltage is 7.5 V DC If the problem continues, replace or charge your battery (if rechargeable).
If you don't have a battery charger, I've seen them online, priced about $38 (USD). I've also seen a new rechargeable battery for $30 - $40 (USD) online.
Hope this helps.
Posted on Aug 22, 2010
    Brigadier General:
  • 5,158 Answers
Have you tried "rebooting" it. basically taking out the battery for about 15 minutes to a half hour. ?
  • 12 more comments
  • Roberta Smith
    Roberta Smith Aug 22, 2010
    does sound then like the battery is dying. especially if you can use another battery and it functions properly. the most inexpensive replacement batteries are likely found on ebay. make sure they are O.E.M tho.
    robert
  • Roberta Smith
    i did indeed. the red light should be normal when you transmit. the flashing light usually indicates that the radio is trying to transmit out of it's normal band or that no antenna is present and that would be obvious to you. i presume this is not a new radio for you. if so was it working before. as it would appear it's not been programmed.
    It was working and just quit. It is a not a new radio.
    It has 4 frequeiencies programed into it. I can transmit from a different radio and it will receive but not transmit.
  • Roberta Smith
    either antenna issues or it's not been programmed properly or it's lost it's programming.
    How do I program it?
  • Roberta Smith
    one other question before we get to the topic of how to program it. you mentioned it will recieve. have you tried transmitting on one of the other channels to the other radio ?
    Yes, all 4 do the same thing.
  • Roberta Smith
    in that case i would suggest the transmit section of the radio has died. being a ham i'd just take it apart and try and sort it out but if that's beyond your capabilites you may want to take it to an electronics repair place.
    Thanks.
  • Roberta Smith
    wish i could have given you good news but that appears from what you describe to be the problem.
    please take a moment to rate this solution.
    robert
    You didn't tell me how to program this radio.
    Somewhat what I expected. But didn't answer all my questions.
  • Roberta Smith
    to program the radio you need the cable that hooks up to your radio and the specialized software.
How to pair a ROMAN R6250 Mini Wireless Bluetooth Headset Earphone Headphone to an iPhone 5S
1. Charge the headset:Headset is charged via USB cable, the light will be red when charging. When the battery is fully charged (about 2-3 hours), the red light of the headset will turn off automatically or the red light turns blue.
2. Turn on the headset:Press the on / talk button on the headset for about 5 seconds until the blue and red flashes alternately (or blue flashes or the blue lights all the time ), now the headset is ready to be connected to the iPhone.
3. Go to Settings, and tap Bluetooth. Turn on Bluetooth.
iPhone will automatically start searching for Bluetooth devices. Tap the device in the Devices list, then follow the onscreen instructions to connect to it. After matching successfully, the blue light on the headset will flash twice per time.
4. Call: when you finish all the above steps, you are going to talk via the Bluetooth headset. When there is incoming call, press the on / talk button, you can talk with Bluetooth headset, when you want to end the call, press the on / talk button, you can end the call.
5. Turn off the headset: Press the on / talk button for 5 seconds until the red light of the headset flashes quickly for twice, then release the button, the headset will be turned off.
Mar 25, 2014 | Apple iPhone Cell Phones
I lost my ear piece for my Plantronics Voyager 500A so I am trying to pair a new earpiece. How do I do this?
1. On the base, press and hold both speak volume fine adjust buttons until the blue talk/on line indicator light and red power indicator light (on the front of unit) start to flash.
2. On the headset, press and hold the listen volume adjust + button and call control button until the status indicator flashes red and blue.
3. Pairing is complete when the talk/on line indicator on base illuminates solidly, and the status indicator light on headset flashes blue.
Important: Make sure your headset is not connected to any other Bluetooth device when attempting to pair.
Good luck from Headsets Direct!
Jul 13, 2011 | Plantronics Voyager 500A Deskphone Adapter...
I bought a 1996 Subaru Impreza L 4dr 5speed AWD that runs and starts fine but when I was installing fog lights i noticed that there appears to be an alarm hooked up (it says "code alarm elite DM...
Battery Constant 12v+ Positive Wire (+): Black/Yellow
Battery Constant 12v+ Positive Wire Location: Ignition Switch Harness
Starter Positive Wire (+): Blue/Red
Starter Positive Wire Location: Ignition Switch Harness
Ignition Positive Wire (+): Red
Ignition Positive Wire Location: Ignition Switch Harness
Accessory Positive Wire (+): Red/Yellow
Accessory Positive Wire Location: Ignition Switch Harness
Parking Light Positive Wire (+): Red
Parking Light Positive Wire Location: Low In Drivers Kick Panel
Power Door Lock Negative Wire (-): Add Actuator. This vehicle uses a central door locking system. When connecting a keyless entry, you will need to add a door lock actuator and some units will also require (2) extra relays.
Power Door Lock Negative Wire Location: To Drivers Door Only
Power Door Unlock Negative Wire (-): Add Actuator. This vehicle uses a central door locking system. When connecting a keyless entry, you will need to add a door lock actuator and some units will also require (2) extra relays.
Power Door Unlock Negative Wire Location: To Drivers Door Only
Door Trigger Negative Wire (-): Red/White
Door Trigger Negative Wire Location: In Black Plug, Above Hood Release
Domelight Supervision Wire: Use Door Trigger, Requires Relay
Domelight Supervision Wire Location: N/A
Horn Negative Wire (-): Red/Green
Horn Negative Wire Location: At Steering Column Harness
Tachometer Wire Negative Wire (-): Black/Blue
Tachometer Wire Negative Wire Location: At ECM, Under Drivers Side Dash
Brake Light Positive Wire (+): White/Black
Brake Light Positive Wire Location: At Switch Above Brake Pedal
CODE ALARM SYSTEM
Used on:
Impreza 1996-2001
Legacy 1995-1999
Forester 1998-2000
codealarmremote2.jpgBattery GP-23A
Lock: Left button will lock all doors. Double chirp indicates locked.
Unlock: Right button will unlock driver's door only. Hold unlock button app 6 seconds, it will unlock all doors including rear gate. Single chirp indicated unlock.
If the car chirps or lights flash 4x the alarm was triggered.
Panic. Press both buttons to activate emergency honk and flashing lights.
Valet mode: With optional alarm onlyPress the red alarm button on the left of the steering wheel. The light will quickly double flash. To re-set back to normal mode, press the red alarm light button again
Battery failed and lights flashing?
Parking lights will flash when the vehicle's battery is disconnected and reconnected.
To stop lights from flashing, either:
Press remote transmitter "UNLOCK" button once OR turn the ignition switch to the "ON" position and press programming button for one second (see below).
The vehicle interior (courtesy) light and door open warning light (DOOR AJAR indicator) will then illuminate for 60 seconds when the ignition is turned off, or until the doors are locked with the remote transmitter. Yes, the dashboard instrument panel lights will flash when the parking lights flash.
Programming or Overriding the Alarm when you have lost the remote
Open driver's door.
Turn ignition key to 'On'
Press and *hold programming button* in (see diagram, button under dashboard)
After 15 seconds the the door locks will cycle 3 times. Do not release Programming button.
Press lock (left) button the remotes to be programmed. The door locks will cycle one time. Exit programming mode by releasing Programming button under dashboard and turning key to off.
codealarmremote1.jpgCode Alarm Programming Button is under dashboard on the kick panel by the driver's left knee, left of the steering column. If you can't find it, it might still be tucked up in the wiring harness higher up in that same general area. The botton is recessed in a plastic ring (see diagram).
This button must be pressed while programming remotes or if the battery was disconnected and the lights are flashing.
Jan 05, 2011 | Subaru Impreza Cars & Trucks
How do i program my kenwood tk260
You'll need the Kenwood serial cable and software to program this radio. Your best bet would be to contact a Kenwood Customer Service Representative directly. You should have the the radios in front of you when you call so that you can answer questions about them instead of having to call back, etc.
Kenwood contact information can be found here. The TK-260 radio falls under the "Land Mobile & Business" category.
Please rate this reply if helpful - good luck!
Aug 12, 2010 | Kenwood KNB-15AM,...
I have a kenwood tk-272g and the keys are locked and i cant figure out how to unlock them, the owners manuals ii found online aren't helping me at all
One of the keys has been programmed as the lock button. you will have to experiment by holding each button for a couple of seconds until you hear a tone that tells you the radio is unlocked.
On the one I have for our fire and rescue it is the < button but it could be any of the four on the front or the two on the side below the talk button.
Jun 12, 2009 | Kenwood KNB-15AM,...
Digitech DC1010 locked!
I referred the problem to a retail outlet. All fixed. Don
Jun 10, 2009 | Kenwood KNB-15AM,...
I will be talking to base and onther driver will start talk over
Tone squelch settings are not correct on the radios. or the microphone ground is disconnected so one user of the other is not opening squelch when the mic is removed from the holder.
Apr 09, 2009 | Kenwood iTECH iQfive iQplus...
Kenwood TK-361 Manual
http://safemanuals.com/ pleace rate me let me know if this helped.
Nov 29, 2008 | Kenwood iTECH iQfive iQplus...
Stoped working
reprogram the radio, it sounds like it has corupted software
Jul 27, 2008 | Kenwood ProTalk TK-3102 (4 Channels) 2-Way...
Kenwood Radio TK 260 360 270 370 2100 3100 Compatible Battery Logo
114 people viewed this question
Top Kenwood Radio Communications Experts
eradiostore
eradiostore
Jason
Jaime Hernandez
Are you a Kenwood Radio Communication Expert? Answer questions, earn points and help others
