Question about Necchi 6015 Mechanical Sewing Machine
Casn I use a double needle on this model? - Necchi 6015 Mechanical Sewing Machine
  • 109 Answers
If you have a zig-zag stitch on your machine, you have the capability of using a twin needle when using a STRAIGHT stitch. The width between the needles is the same as the width for the z-z stitch but you won't be using that stitch. Only the straight stitch.
Posted on Aug 23, 2010
Testimonial: "I thought I should be able to but the bottom stitch was so loose. Just need to work on it a little. "
  • sqs1011 Aug 24, 2010
    If the bottom stitch is loose tighten up the tension on your upper thread. The tension dial should be around 4 for a good stitch. Also re-thread the top thread a make sure the thread is snug in the tension discs. This too can cause a loose stitch underneath. Do all this will the presser foot lever up.
How do i change double needles on janome mylock
Don't know the model of your machine but this manual, or one specifically for your machine, may be helpful:
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&ved=0ahUKEwio3tC-1p7PAhXm5oMKHed8DIMQFggeMAA&url=http%3A%2F%2Fjanome.com%2Fsiteassets%2Fsupport%2Fmanuals%2Fsergers%2Finst-book-634d.pdf&usg=AFQjCNFFa0YXjvhgmGspP4BP7E6p_z59bA&cad=rja
FWIW, overlockers do not take double needles. There are usually at least two needles each installed separately. If you try using a double needle, you will most likely break them and possibly damage you machine.
Sep 20, 2016 | Janome Sewing Machines
Can I use a double needle with this machine
No make/model was provided, so there is no way we can assist with your question. The Owner's Manual should have instructions whether a twin needle can be used. If you don't have one, search the internet for:
Make + Model + the word "Manual"
or contact the manufacturer directly.
Mar 23, 2016 | Sewing Machines
Can I use a double needle in the euro pro model 9101?
Most all machines will take a double needle
Apr 26, 2015 | Sewing Machines
I have a janome 2049LX. Why doesn't my double needle pick up the bobben thread?
The length of the needle might be too short. Compare the length to your single needles.
Jan 11, 2015 | Janome 2049LX Mechanical Sewing Machine
I would like to know how to thread a double needle industrial sewing machine. i must be doing something wrong as the stitch is not good
for a double needle, first thread the first needle, then put the second spool up & thread in the same places as the first, making sure every guide is used, then thread the needle.
that's how I do when I used my double needle to sew
Aug 07, 2011 | Sewing Machines
Skips a few stitches when using a double needle. I'm using a recently acquired old Pfaff Hobbymatic and have used a double needle before on a Singer. When I tried sewing, it will stitch but then skip a...
firstly are you using a regular twin needle on a knit fabric? this could cause skipped stitches.
is the twin needle quite old and possibly blunt?
Is the Hobbymatic a model that requires a slanted twin needle, there are two types of twin needles as the computerised machines need the offset style. You can distinguish between them by the plastic block on the needle shaft where the twin needle points are set, either red or a deep brown colour.
If none of the above apply, then it is possible that the timing sequence is slightly off so that one of the needle's thread is not getting caught during the stitching.
Timing is an adjustment that I leave to the technician to address. But if you want to have a go yourself there may be some videos on you-tube for your model and how to make this adjustment to it.
Jun 18, 2011 | PfaFF Sewing Machines
Needle will not pick up bobbin thread when sewing
double check the upper and lower tensions they often need to be changed to suit types of fabric and threads
Dec 12, 2009 | Singer Sewing Machines
Double needle use on Juki HZL-E80
if the machine regular needle threads front to back NOT side to side, you can use a double needle. simply pass both threads thru all the same slots (thread one at a time so they don't get twisted up) then just before the needles, leave one out of the thread guide just above the needle. you may have to loosen the top tension SLIGHTLY, like a half number. and do NOT use a zig zag stitch without first hand cranking it thru the cycle to be sure the needles clear, or you'll make a 5.00 mistake (the cost of the double needles!)
Jun 16, 2009 | Juki HZL-E80 Computerized Sewing Machine
Necchi 6015 Mechanical Sewing Machine Logo
177 people viewed this question
Top Necchi Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Ellen Den Dulk
Ellen Den Dulk
Level 1 Expert
Are you a Necchi Sewing Machine Expert? Answer questions, earn points and help others
