I own a BIC subwoofer and I can't get it to work. I have replaced the fuse and it still dosn't seem to work for me.
    Genius:
  • 1,689 Answers
Check to see that there is signal actualy reaching it from the amplifier's sub output. I have seen this one a lot!
It is possible the the output stage or the speaker driver in the sub box is blown and requires service.
Jerry G.
Posted on May 04, 2008
How can I hook up BIC F12 subwoofer to Onkyo TX-DS838 receiver? Will the receiver power the subwoofer and other speakers?
Get a RCA cable and connect from your amp where it said Sub Woofer in the Pre Out box in the back of the amplifier top left hand side and take it to the "Sub In" located in the back of your Sub woofer bottom right hand (White round connector).
Good Luck!
Aug 06, 2014 | Onkyo TX-DS838 Receiver
I need a replacement sub woofer for my LW 12
Polk Audio PSW505, BIC America F12, Hsu, SVS, Outlaw, Axiom Chane Subwoofers
Sep 03, 2012 | Cerwin Vega LW12 Subwoofer
Electrical problems with a 2002 Satun SL 200, the electrical door locks dosn't work, the mirror adjustments dosn't work, the dome light dosn't work. The engine runs good. head lights work
check all your fuses in engine compartment and under dashboard engine check light comes on every 3000 miles for oil change reminder
Jul 23, 2012 | Cars & Trucks
There is no power to the speaker, the green light is not showing. We have changed the plug fuse but this was not the problem
If you're talking about a powered subwoofer pluged into an electrical wall outlet check the wall outlet. One of my kids could not get a lamp to turn on in the den. It turned out the outlet was switched off from accross the room by a wall light switch. To check your electric wall outlet, plug in something, like a lamp, fan or a clock and see if it turns on. If not, look for wall light switches and flip them on and off. If it (example fan) dosn't turn on, you have a problem with your house electrical system. Probably right there at that outlet.
Sep 08, 2011 | Revel Audio Players & Recorders
BIC America Venturi V815 - subwoofer manual“
Click on the link below.
http://reviews.cnet.com/1710-11312_7-0-1.html?node=11312&keywords=BIC%20America
Post back if it is not working we will be happy to help you.
Hope this helps.
Cheers!!!!
Jan 09, 2011 | BIC America (900020) (00900020)
Please help! Jamo SUB 300 subwoofer still blows (0.8A) fuses after replacing a faulty thermistor, despite a high ohms reading directly across AC mains terminals on the board. What is causing the fuse to...
hi,
i have a jamo 250 sub.the blue light is working.when i connect the jack to the left line IN according to the manual it makes a sound as well.but seems not working.is it related to the fuse????i know the fuse box.but i dont know how to remove the fuse to check.pls help me out.my receiver is onkyo tx-sr 608
thank you
ron
Jan 08, 2011 | Jamo SUB300BA SUB 300 Powered Subwoofer...
Fan blower fuse location on a ford f150 year 2000
FUSE #105 40A** Climate Control Front Blower, THIS FUSE IS LOCATED IN THE UNDERHOOD POWER DISTRIBUTIOPN BOX
Oct 14, 2009 | 2000 Ford F150 Flareside SuperCab
Amplifier power light will not turn on. subwoofers will not work.
Recheck the fuse on the amp, if the fuse is good, try replacing it anyway, if that doesn't work your amp has blown an internal component, (most likely an output transistor). it is probably cheaper to replace the amp than repair it.
Apr 12, 2009 | Power Acoustik LT-980/2 Car Audio...
Encore subwoofer not getting any power
Might be a power supply for the amp. Are you handy with a VOM? You can check the power supply output pretty easily. If not, some local electronics repair guys will diagnose / estimate repairs for free .. especially if you already have the unit apart (just did that very thing myself). Then you can make the choice of repair / replace.
Good luck.
Feb 26, 2008 | Energry Speakers Energy Speakers Encore 8...
67 people viewed this question
 Grubhead
Grubhead
