Question about Baby Gear
Fitting rear seat covers to AU Ford Falcon
We are trying to fit car seat covers to the rear seat of a AU Ford Falcon. How do you get the seat out to fit the covers?
  • Anonymous Sep 26, 2008
    i am not able to remove rear seat to put on the new seat cover. and without removing i cant do it.
  • Anonymous Apr 28, 2009
    I'm having the same problen with my XT falcon? Any ideas?
To remove the rear seat off an au falcon get in the rear of the car facing the opposite way to which you drive facing the rear seat. you need to slide your hands along down where the seat belt conectors are pulling it up abit. than you need to use quite a bit off force pulling it towards your self.
Posted on Nov 08, 2009
How do i remove the whole diff and IRS suspension in au falcon intact
jack up car, fit safety jacks at each side of frame well in front of rear wheels, remove tail shaft , place floor jack under rear axle housing and jack up , but not lifting off safety jacks.remove brake lines, remove rear shocks, remove drag links ect from chassis frame, lower and remove jack, wheel out rear axle.
Sep 27, 2016 | Ford Falcon Cars & Trucks
2002 AU ford falcon alternator change over.?
Disconnect battery take note of the way the drive belt is fitted write it down using cogs as markers then draw the belt onto them in same order (belt only fit one way) then with a 3/8 ratchet leave r the adjuster and remove belt unplug wiring undo bolts holding it to the motor.
Sep 25, 2016 | Ford Falcon Cars & Trucks
Can you fit adjustable roof racks to a Ford falcon sedan au 2000 model
A good roof rack shop will be able to put you on the right track
Apr 10, 2016 | Ford Falcon Cars & Trucks
Hi there, does anybody have complete fitting instructions for installing a towbar on an fg falcon
NO I don't but if you go to the FG Falcon section of the Ford Forum in the link below, and ask for help politely, then i'm sure one of the guys there will help you out.
fordforums com au
Dec 15, 2015 | Cars & Trucks
How to remove rear axle from 2004 ba ford falcon
Remove rear wheel and brake drum remove 4 bolts on axle housing axle and bearing will slide out . some times you have use slide hammer puller as the bearing is a tight fit.
May 04, 2014 | 2005 Ford Falcon
We are changing the rear brake pads on a 1998 ford falcon I want to know do the calipers move if so how do they move to put pads in
most falcon rear disc calipers require a special tool that fits into the piston then a 1/2 inch drive ratchet used to spin the piston while pushing in . You should be able to uy this from most auto parts outlets.
Jan 13, 2009 | Ford Futura Cars & Trucks
Rear seats for 98 Windstar
aerostar and early 95 windstar as well as 99 & up dont fit but can be modified to fit. your best bet is go to a junk yard because the rear seats are a dime a dozen. all the upper parts are the same but the lower steel parts are slightly different
Oct 13, 2008 | 1998 Ford Windstar
Baby Gear Logo
1,324 people viewed this question
Top Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Are you a Baby Gear Expert? Answer questions, earn points and help others
