Question about GE JVM1320 Microwave Oven
Barely heats up food - GE JVM1320 Microwave Oven
  • GE Master
  • 43,501 Answers
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
fgs
Posted on Sep 30, 2010
Model:OGD21102 MICROWAVE IS NOT ALLOWWING ME TO COOK MY FOOD. The microwave says Food and that is it. Will not heat, I can push a time and it says Food. What should I do.
if opening and closing the door fails to clear the fault , then your door switch's have a fault in them , this is not too uncommon on microwaves , as most of them have three separate door switches ,(its a safety thing ) as the last thing in the world you'd want to happen is running it with the door open . make sure the door seals properly and there's nothing down in the cracks (even the hinge side) that keeping it from closing properly , I once had a pealing factory label do this , so it doesn't take much to trip the door switch
Feb 09, 2016 | Oster OGD21102 Black Countertop Microwave...
The microwave is not heating the food.
When it did heat food before and you used the same settings now, the microwave must be defect.
But before you are sure, put a cup with water in the micro and try to heat that.
Dry food can't be heated in a microwave. There must be some moist in the food if you want to heat it in the microwave.
Mar 13, 2015 | Microwave Ovens
Wont cook
It will just barely warm food, what is the problem?
Nov 29, 2013 | GE Microwave Ovens
My maytag cmv1000ada starts and seems to be working, but barely warms food, it makes a little buzzy/ vibrating noise at startup but doesnt heat food like it used to example a bag of popcorn would be burnt...
Remove cover after disconnecting , check for dirt/moisture in the cabin, if so wipe clean and dry, check the magnetron and area clean and use an jet air to clean off. Check the wave guide covers, if food had deposited
then it must be checked or replaced. See link:
http://www.espares.co.uk/advice/microwave/a/5/1146/how-to-replace-a-microwave-guide-cover.html
Jan 31, 2013 | Sanyo Microwave Ovens
Frigidaire microwave won't heat
Generally the magnetron (the part that heats the food) is the cause if everything else still works and it only works once in a while, possibly a short, but not as likely. Unfortunately replacing the magnetron is barely cheaper than buying a new microwave though you can check out repairclinic.com to decide whether you want to attempt replacing the part.
Let me know how this works out for you.
Benjamin
May 24, 2010 | Frigidaire PLMV169DC Microwave Oven
My Maytag microwave stopped heating. Everything
Generally the magnetron (the part that heats the food) is the cause if everything else still works. Unfortunately replacing the magnetron is barely cheaper than buying a new microwave though you can check out repairclinic.com to decide whether you want to attempt replacing the part.
Benjamin
May 24, 2010 | Maytag 2.0 Cu. Ft. Over-the-Range...
Powers but no heat. Everything else functions
Sounds like the magnetron has failed. This is the component that produces the microwave that heats the food. The cost of the magnetron is about 95% of the cost of a microwave . Most people don't, for this reason, replace the magnetron, they replace the whole oven which is probably what you will end up doing. There is a possibility that the circuit that provides power to the magnetron is faulty and you need to take it apart, find the proper electrical leads and test them with a volt meter. To do this you have to remove it from its mounting and take it apart. It is a fairly lengthy process however.
Benjamin
Jun 30, 2009 | LG LMV2053 Microwave Oven
It doesn't heat up
When the microwave won't heat, but you hear a loud buzz, you usually have a defective power diode, high-voltage capacitor, or magnetron. We recommend that you consult with a qualified appliance repair technician for help in determining the problem and deciding what to do about it.
thanks and please do not forget to accept the solution
Apr 03, 2009 | Kenmore Microwave Ovens
Microwave heats bowl but not food
First of all, you must be sure you are using a microwave safe container. If it is not marked as such, it is not.
Try heating a cup of water in a clear glass container. If it still does not work right, your stirrer may be bad.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
LIGHT BULB
I have a diagram at my site which helps you find & replace many GE cooktop and cavity light bulbs. It's at http://207.234.249.73/mwd/ge_lamp_replacement.jpg
If there's no obvious removable cover over the bulb (most often on the rear or side) and the owner's manual doesn't address it, then disassembly will be required.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Nov 25, 2008 | GE JVM3660 Microwave Oven
Doesn't Heat
replace magnetron, check highvoltage related circuit.
Nov 06, 2007 | Sunbeam SMW777 Microwave Oven
GE JVM1320 Microwave Oven Logo
196 people viewed this question
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
