Question about Coby DVD-R1200 DVD Recorder
My CODY DVD-R1200 frequently stops and starts when I try to play a DVD. The DVD is in perfect condition, clean and not scratched. It plays without any problems on other recorder/player units as well on my computer.
  • gmolicki Aug 22, 2010
    The unit starts and stops, after some time it starts and stops again, this happens repeatedly.
  • 10,515 Answers
This is a common problem with these players. As DVD is in perfect condition, clean and not scratched- confirms the problem with player.
If this frequent start and stop occurs with all other DVD's, more often there could be few causes :-
1. Lens is worn out and needs replacement. Of course, you could open and clean the lens manually with a cotton.
2. This could be a mechanical failure that causes frequent shut off. ( Note - This is a possibility ONLY if the DVD only stops. If it restarts itself, more often it is lens failure ).
3. It could be a circuitry problem. ( Firmware - i doubt as i have hardly seen on these models ).
Overall, not worth repair as the repair would cause more than the investment in new. If under warranty, get it replaced. If out of warranty, try to clean the lens and see, if that helps.
I have seen a strange case - Few months ago, i was in a same situation. The player was new and hardly used. We checked every component and does not found anything wrong. We kept the player off for few minutes ( 30 minutes ) and then ON it.Perfect, it worked. This is due to the microprocessor which was reset by disconnecting the power supply.
If the problem is with this DVD, it could be a format problem. In this case, either use another brand or a different format.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Aug 22, 2010
  • Coby Master
  • 17,130 Answers
If the DVD player is playing the DVD without a fault prior to the fault and then all of a sudden the set fails, then I wish to advice that you open the set when the faults occurs .
Now keep the lid aside and check in the main board if any of the IC's are heating up. Now use a good soldering iron and do a fine job of soldering all the suspected dry solderings found on this board. please take care not to bridge any circuits but use a good iron. Now if the fault stays get hold of a freeze it spray that can be used to cool the iC section .Do this and see if the fault changes, If so the IC / board is defective.
Find the availability , the cost and then decide on the job.If in warranty claim for a replacement.
However if the picture is irregular on all DVD's then the fault in the optical head is also a possibility.
Hope my advice helps.
My DVD and VCR in one has always played DVDs, and now when I tried to play a DVD, it says playback feature may not be available on this disc. I've played the same DVD on the same tv perfectly before!!
sometimes the discs get scratched enough that the player has difficulty reading them, using some car wax on the disc to clean it may help
Mar 09, 2013 | Televison & Video
I make my own movies using pinnacle system 10.6. After burning onto dvd and playing on tv, they play perfectly, after a few showings the dvd freezes (have cleaned dvd and cleaned dvd player and they still...
I would say your player is proably getting a lil old and maybe damaging the cd itself as most due overtime even the most pristine kept cd will catch scratches from being put into the player I would suggest taking a can of compressed air to your player to ensure the lense is clean
Mar 31, 2010 | Philips DVP642 DVD Player
5 disc cd changer CC4000 will not read
All players need cleaned from time totime. Do NOT try to clean it with anything other than a CD / DVD lens cleaner. They are available almost everywhere that sellsBlank media. It will clean the lens without scratching or smearing it.
Dec 06, 2009 | Marantz CC-4000 5-Disc CD Changer
DVD freezes when playing on a Sony SLV D300P DVD/VCR
That particular unit is very sensitive to scratched or dirty disks. Remove the disk and make sure there are no finger prints, peanut butter & jelly, or popcorn butter stains on the back side. If there is, gently wash the disk under warm water with a DROP of mild dish detergent, being careful not to scratch the surface. Rinse the disk well and dry with a soft, lint free cloth (like an old cotton t-shirt) again being careful to avoid scratching the disk. Replace the disk and play.
If the disk is scratched, there is little hope of fixing the scratch so the unit can read it.....
Nov 20, 2009 | Sony SLV-D350P DVD Player/VCR
Dvd doesnt always play,, takes ages to load
CHECK THE SPINDLE.IF OK,REPLACE THE LASER
Jun 30, 2009 | Televison & Video
Picture freezes, dvd wont play or starts stops continuously
the lens on laser needs cleaning manually never use disc cleaners ever
Dec 17, 2008 | Philips MX3600 System
Problem with the lens
I think we have a design problem here; possibly the unit uses a single-beam laser. Here are the symptoms I have found from my V6800.
When I inserted a DVD that had some minor imperfections, I found that the DVD would hang, usually at the same spot. After cleaning the DVD, there was a noticeable improvement, but it still would start to hang at about 38 to 44 minutes.
Although I have not corrected the problem, I did get enough information to pin the blame on the V6800, and not the DVD with the minor imperfections. Here is how I came up with my conclusion:
I took the "defective" DVD to my PC, and made a copy of it.
The copy played perfectly on the V6800.
The "defective" DVD played perfectly on my PC.
CONCLUSION: If you have a DVD in perfect condition, the V6800 will play it without any problem.
I don't like the DVD medium because of the scratch problem. Fortunately the write-once Flash Memory cards will take the place of the DVD in the near future. Watch SanDisk!
Aug 26, 2008 | Samsung DVD-V8600 DVD Player/VCR
CD/DVD intermitent audio
CD's and DVD's has different speeds try to check your dvd player/rom if it is compatible with your cd/dvd disk. Some dvd players are sensitive it will not play perfectly if your cd's are scratched. try to use new cd's. It might work.
Jan 20, 2008 | HP Compaq Presario V2000 Notebook
Dvd video player
Your DVD player is having a problem reading the disc. This is what is accounting for the pausing and the slow loading times...especially if it plays other movies without hitches. Even if the DVD is cleaned, some scratching on the disc will prevent it from being viewed properly. Blockbuster shoudl give you another disc to try of the same movie if you ask. Also, you can try getting a cleaner for your DVD player to remove dust and help it read discs better.
Dec 26, 2007 | Toshiba SD-3980 DVD Player
DVDs & CDs will not play
If you are playing STANDARD CD or regular DVD that you have purchase and you are having this problem,your dvd player is malfunction;however,if you are playing DVD burner disc or a different dvd region disc(we are region 1 in U.S.) that is no going to work.Same thing for your CD burner disc,it might not work.
If you are using a rental dvd disc,check and see if there is scratches?If so,try to get one without that many scratches!
Joe
Jan 07, 2007 | Philips DVD Micro Theater Shelf System...
Coby DVD-R1200 DVD Recorder Logo
46 people viewed this question
Top Coby Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Coby Televison and Video Expert? Answer questions, earn points and help others
