Question about Vacuums
Carlon plug in chime model rc8253r instructions
Does model, 3040 use batteries
It's a rechargable battery and they can wear out. Contact Bissell Consumer Care at 1-800-237-7691 for troubleshooting instructions or repair directions.
Jul 27, 2014 | Bissell 3040 Clean 'n Light H Vac Vacuum
Green light but won't start
Here is a video showing a quick temporary fix and the full fix showing the change of all the electrolytic capacitors.
Jun 14, 2014 | Neato 945-0041 XV-21 Robotic Vacuum...
Evo 46400PL Ed3 wireless door chime, no connection between the bell push and the chime unit.
Maybe the batteries are emty, is that not the problem then lay down the bell push in your living room for 1 day, the companents can be a little wet, you can't see that ( they look to be dry) I had this problem too and it works.
Jun 26, 2011 | Vacuums
I have a First Alert model 610 timer. It is an older model and I need the instructions for it.
I called First Alert @ (800) 323-9005 and they faxed me the instructions for Model LS510 which is the same and got it working. They will mail it too but not email. Choose Fixed or Random mode. Choose how many hours it will stay on after dusk. Turn your lamp off and unplug the lamp. Plug lamp into timer. Put function in Fixed or Random position. Put hours on switch to number of hours you want it remain on after dusk. Plug timer into the wall outlet. Turn the lamp's switch on and Timer's LED light should be on and the lamp should be off. Turn the lamp's switch off then on again TWICE. The second time you turn the lamp's switch on the bulb in the lamp will flach on then off quickly. This indicates that the Timer is controlling the lamp's operation. Leave the lamp switch in the ON position. The timer is now set for automatic. I hope this helps.
Jan 06, 2011 | Vacuums
I got as vacuum sealer at a yard sale - I don't know the brand/make/model to find instructions for it.It is electric - has a cord to plug in - white - 2 lights on front - 'seal; ;vacuum' under unit is a...
I have the same machine, foodsaver BS828, and no instruction manual.i need to know how to use it properly...anyone have or know how to find a manual?
Oct 16, 2010 | Vacuums
Battery does not seem to fit machine
the light only shows that its plugged in, it wont shut off when its fully charged
Jul 03, 2009 | Vacuums
I need yo find out hoe to use the upholstry attachment. Ilost my
I'm not quite sure where the attachment plugs in but, I did find an owner's manual for this Hoover online.
http://www.hoover.com/pdfs/manuals/F5918900.pdf
I hope that helps. Good luck!
May 25, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
I require the Old hose handle/end plug disassemble instruction for a Kenmore Whispertone model 116.20600001c
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=575171
Generic problem for all Vacuums
Posted by hrabed on May 06, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
There are some hoses that have separate hose ends and some hoses that you have to replace the entire hose the way the manufacturer made the hose. There are some local vac dealers that may have a new, or a good used hose or they also may have a non-genuine replacement hose that you could use. It really depends on the hose that you have and how it was made.
So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.sears.com/shc/s/home_10153_12605
National Customer Relations 1-800-549-4505
Home Services & Repairs 1-800-4-MY-HOME
1-800-469-4663
Parts Orders & Inquires 1-800-366-PART
1-800-366-7278
Don – The Vac Man
Go Ahead. Use Us.
May 06, 2008 | Vacuums
Vacuums Logo
924 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
