Question about Kyocera Mita FS-1920 Laser Printer
Kyocera load a casset
When i turn on my kyocera-1920 printer there was a message that CASSET LOAD??what is the problem of my printer??
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 58 Answers
Check the paper size dial on the left inside of cassette draw.
Posted on May 11, 2008
I have canon iR2022 someone help me for setting A4 paper.when i m printing its taking A3 by itself.
You must adjust your paper size in casset .in canon 2022 look to your machin casset left . You see how to adjust
Nov 08, 2016 | Canon iR 2022 Printer
Even though cassette is loaded it keeps saying "add paper in cassette" and will not print
theres a sensor where the casset meets the back of the machine if it dosnt get triggered it wont see any you can trick it and it will always see paper just keep it stocked of paper
May 30, 2014 | Kyocera FS-2000D Laser Printer
Reseting to factory settings
my printer saying "use currents setting yes or no" i say y it prints again if i say no load paper in casset any one help
Jan 16, 2012 | Canon imageCLASS MF4320D
2000 Buick Century. Put in a replacement radio/cd/casset player. Radio works, clock works, but CD and casset do not. The message comes up E 13. What does this e code mean?
if its a radio shack radio, it means E13 means "Tape Communication Error". It is caused by the
microprocessor reading speed pulses from the tape deck either too fast, most other makes mean about the same thing, normally a stuck tape will cause this code to show up, either that or the drive gear that loads and unloads the tape is broken, cracked, or jammed
Sep 26, 2011 | 2000 Buick Century
Our FS2000D keeps forgetting it has a 2nd casset tray. I am having to go into properties daily (at least) and tick the box. This is a pain. Any ideas?
very stange 1st thing u need to try is upgrade firmware and perhabs take the tray off completley and re fit it again Make sure the connector on the tray and the copier not damaged in any way
Nov 10, 2010 | Kyocera FS-2000D Laser Printer
How do I change size?
if you want to change paper size for copier you should going to user mode then change casset paper size but if you need to change paper size for printer mode and i guess you mean's that you should go to printer properties then select advance then click printing default then change paper size then click apply then ok
Aug 16, 2010 | Kyocera Mita Kyocera-Mita SCANNER RACK...
VDO casset still in my VDO player
F-03 means mechanizam jam while unloading please contact nearest expert
Jun 09, 2009 | Panasonic NV-MD9000EN Mini DV Digital...
The Casset is rejecting back
I got the solution from your net only.Thanks it is wotking presently.you have to do simply take out the cassete and keepp the cassete door open.And then take both the battery out i,e one main battery and another small battery and leave camera in this psoition for two hrs and tehn place back battery in its position and then load cassete .It will work.I have tested it.Thanks a lot.
BK PRASAD
Apr 19, 2009 | Sharp Viewcam VL-Z1 Mini DV Digital...
Kyocera FS-1920 error message: "call service 6400:0295998"
Your drum unit is not seated correctly. Look inside for a bent drum ground clip.
Oct 19, 2008 | Kyocera Mita FS-1920 Laser Printer
Canon ZR60 Mini DV Digital, remove the cassete message
This is a tape transport problem and is expensive to fix. Unless you know a cheap tech, it's time for a new one. Be patient loading and unloading tapes. This is usually what causes this problem. The Yellow warning sticker is REALLY important. Another important item is to always use the same brand of tape because switching tapes causes a gummy build-up the makes tapes get caught in the machine.
Videoteacher
Dec 08, 2007 | Canon ZR60 Mini DV Digital Camcorder
Kyocera Mita FS-1920 Laser Printer Logo
189 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Kyocera HP Expert
Henry Gertcher
Adorjani Laszlo
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
