Question about Alpine CDA-9856 CD Player
Head unit turns on sometimes
Sometimes it works. Sometimes it dont even turn on. I checked all wiring and eveything looks like they match up. I have a pink wire that I'm not using. Is this have anything to do with it not turning on sometimes? I am getting frustrated cause I just got this deck from ebay and I really want to run this deck. Someone please help.
    Problem Solver:
  • 8 Answers
CHECK CONTACT POINTS ON BACK OF FACEPLATE , THEN CLEAN W/ ERASER ........ DON 'T BRUSH OFF EXCESS RUBBER !
Posted on Jun 29, 2008
What could be the problem
Pull the pump out and see if just running 12 volts across it gets it to work. If that happens then it is not the pump at all but more likely fuse board or even the body computer.
Feb 14, 2015 | Cars & Trucks
Pioneer DEH-3300 UB
Apparently, you have no power at the 12 volt battery/memory wire at the radio harness of the vehicle. This wire is white with blue in color.
Also, based upon your description, you have connected the battery/memory wire and the accessory wire of the radio to the 12 volt accessory (switched) wire of the vehicle. This wire is white with red in color.
Check the radio/ stereo fuse of the car. You may have blown the fuse during your installation.
You have no memory at the radio because when you turn off the key, you lose all power to the radio.
Also, I mentioned the wire colors just in case you used an aftermarket radio wiring harness. Make sure that the yellow from the Pioneer unit is going to the battery power source and, the red of the Pioneer is going to the switched power source.
Sep 12, 2012 | Pioneer Car Audio & Video
Turning signals work when they want too
Since the unit reuires power from the hand control - cluster switch - the voltage on the turn signal unit must be checked so that it is confirmed that the switch works.
If so the fault can be the unit failing to work which must be double checked before it is replaced.
Also check the fuse box for loose conection in the circuit.
Nov 22, 2011 | 1996 Chrysler Town & Country
Can set the time but not save it or display it
i would look at the red assesory wire that is to keep power in your head unit even when the car is shut off it is part of the memory for time, radio stations ext.some have fusable link in red wire,sometimes they blow out like a fuse.can be picked up at radio shack.its a cheap fix if thats what it is.some dont have link in red wire.if thats the case its inside the head unit.it is not keeping power in the unit once the car is shut off.FORGETS EVERYTHING LIKE A 90 YR OLD MAN LOL.PS CHECK ALL CONNECTIONS.good luck
Dec 22, 2010 | JVC KD-AR870 50W x 4 CD/iPod Ready/Sat....
Kenwood head unit not powering up help please.
find your remote wire. it would help to know the type of car and the kind colors of wires your using as your 3 main wires.
normally in most chevy and fords they are yellow 12 volt.
black as ground.
red sometimes even a tan as your remote start.
deff check your start
May 09, 2009 | Kenwood KDC-W6027 CD Player
Radio does not work
put a wire in the antenna hole while radio is on if you get some reception then you know its your antenna do you have sirius if you do it sometimes it runs through your antenna if you dont then check your antenna wire where it connects to the antenna good luck.....
Dec 28, 2008 | Pyramid PDVD79 CD Player
Xm 1002 hx
1. What type of head unit are you using
2. does the head unit have a Loud feature?
- Sometimes you have to press the loud button on certain head units to engage the amplifier.
Try disconnecting your remote wire from the amplifier, grabbing a piece of small 12 or 16 gauge wire and bridging the remote wire with the (+) on the amplifier. if your light does not turn green, then check your fuse and the ground for the amplifier itself and the subwoofers.
When you connect the remote wire to the (+) it should automatically turn the amplifier on even if the cd player isnt on. The reason I want you to try to connect the remote and power is because sometimes the remote wire for the cd player is bad. If it does end up being a bad remote wire from the head unit, then your best fix would be to connect the red wire (ignition 12v) on your head unit to an on/off switch to the remote on your amplifier. You can then turn your amplifier on and off by flipping the switch. If you go to autozone or advanced auto parts you can pick up a toggle switch for about $3.00.
Feb 20, 2008 | Sony Xplod XM-1652Z Car Audio Amplifier
Install pioneer DEH-P6400 into 98 dodge dakota, just wont work :-(
Have you measured the 12v ignition and permanent supply?
Also check the earth.
You will need a tester for this.
Check the fuses
John w
Feb 13, 2008 | Pioneer DEH-P6400 CD Player
Sony V555ES RECIEVER
Its detecting a short somewhere.Make sure all speaker cable connections dont have stray wire shorting outputs
Jan 09, 2008 | Sony STR-V555ES Receiver
Alpine CDA-9856 CD Player Logo
57 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
