Question about Linksys Wireless-G WRT54G Router
Linksys router Cannot establish an internet connection via linksys router...also, during setup, the program keeps telling me that it cannot detect the router. It actually did it one time, however, just stopped again...Please assist. Thanks, Andre'
  • 558 Answers
I personally just shut off the security its a pain in the ***, I just only allow the mac addresses that I input on the allowed list that way only your mac addresses will be allowed on the network
Posted on May 04, 2008
Connecting a Linksys WRT54GL. no internet connection detected
The ISP modem connects to the main LAN port on the router. The PC connects to any other port. Done. You should have internet via wire at this point.
Feb 12, 2013 | Linksys Wireless-G WRT54GL Router
I want to connect a Scientific-Atlanta WebSTAR 2000 series Cable Modem to a Linksys Wireless-G WRT54G wireless router but the linksys doesnt detect the modem and the computer wont let the setup program for...
Most Cable Internet Service Providers (ISPs) use Media Access Control (MAC) Address authentication to establish Internet connection for end-users. MAC address is a unique identifier assigned to the network adapter/s of the computer.
To set up your Linksys router to work with a Cable ISP, you have to enable the MAC Clone feature of the router. MAC Cloning is a procedure which enables a router to copy the MAC address of the computer that's registered with the ISP.
To setup a Linksys router with Cable connection you need to perform four steps using the computer that's been registered with the ISP:
i. Verifying Internet Connection
ii. Connecting Devices Together
iii. Checking the Router's LEDs
iv. Configuring a Linksys Router for a Cable Internet Connection
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 19, 2010 | Linksys Wireless-G WRT54G Router
My linksys w/2phone ports cannot hook up with the ethernet
To set up your Linksys router to work with a Cable ISP, you have to enable the MAC Clone feature of the router. MAC Cloning is a procedure which enables a router to copy the MAC address of the computer registered with the ISP.
To set up a Linksys router with Cable connection, you need to perform four steps using the computer that's been registered with the ISP:
ii. Connecting the Devices Together
iv. Setting Up a Linksys Router for Cable Internet Connection
Connect the computer to the Broadband modem using an Ethernet cable without the router installed. If you cannot get online, contact your ISP. If it's online, use the computer to set up the router.
NOTE: Some cable modems use the USB port. If the physical connection is via USB port, you may not be able to go online via Ethernet connection. Contact your ISP to have the Ethernet port of the modem configured.
kb17251-001_en.png NOTE: The image may vary depending on the computer and modem you're using.
After confirming the Internet connection through the modem, connect the modem to the Internet port of the router; connect the computer to any of the four Ethernet ports at the back of the router. For instructions, click here.
After connecting the devices together, check the lights on the front panel of the router. Ensure that the Internet light, as well as numbered light corresponding to the Ethernet port where the computer is connected, is lit. For further instructions, click here.
Step 1:
Access the router's web-based setup page. For instructions, click here.
NOTE: If you are using a Mac computer to access the router's web-based setup page, click here.
Step 2:
On the Setup tab, click the MAC Address Clone sub-tab.
Step 3:
Select Enabled then click Clone My PC's MAC.
Step 4:
Click Save Settings.
Step 5:
Click the Status tab.
Step 6:
Check the Internet IP Address. If the Internet IP Address has numbers, this means the router has been properly configured. You should now be able to access the Internet. If you're still unable to access the Internet, powercycle the modem, the router and then restart the computer.
NOTE: If the IP address is still 0.0.0.0, click IP Address Release then, click IP Address Renew. If this does not change the IP Address, powercycle the modem, the router and then restart the computer.
Nov 14, 2010 | Linksys WRT54GX2 Wireless-G Broadband...
Linksys will not connect correctly to my laptop
Try a new setup.
On your computer, insert the supplied Setup CD that came with your Router. Setup should start automatically.
NOTE: If setup doesn't load automatically, please click here.
The first screen greets you with the Software End User License Agreement. Please take a moment to read through and understand the agreement. Once you're ready, go ahead and click Next.
NOTE: The Linksys Wireless-N Router model displayed on the setup screen may vary based on the Linksys Wireless-N Router model you have.
Step 4:
On the next window, please follow the on-screen instructions on how to connect your Linksys Wireless-N Router:
kb21463-002_en.png Plug one end of the power cable into your router and the other end into an electrical outlet.
NOTE: The Linksys E3000 features a power switch, located at the back-end of the unit, next to the power port. Please make sure that this switch is ON. Other Router models may not have this feature.
kb21463-004_en.png Plug the Internet cable into the yellow port in the back of your router labeled "Internet". Plug the other end into the modem.
QUICK TIP: Click Show me how for an illustrated guide on how to complete the above instructions.
After completing the above steps, click Next to continue.
Step 5:
Setup will now perform a series of tests to determine the optimum configurations for your network. You may notice your computer connecting and disconnecting to a wireless network several times. This is normal. Your wireless network is simply being secured.
NOTE: The setup process automatically generates a unique and secure Wireless Network Name (SSID) for your convenience.
kb21463-006_en.png Step 6:
The next part of the setup automatically detects your Internet connection type. If you are using a DSL connection, you may be requested to enter your account details. If this is the case, simply enter your Account name and Password in the allocated fields. Otherwise, you may skip ahead to Step 7.
NOTE: If you don't know your Account name and Password, your Internet Service Provider (ISP) will be able to provide these details.
QUICK TIP: Click Examples to see what your Account name should look like.
kb21463-007_en.png NOTE: Cable Internet users will not see the above screen.
Step 7:
Sit back and wait a moment as setup finalizes your Linksys Wireless-N Router settings, and re-establishes your Internet connection.
kb21463-008_en.png Step 8:
Once your Internet connection is up and running, a confirmation window similar to the screenshot below will appear on your screen. Your Linksys Wireless-N Router is now secure and connected to the Internet. This concludes the setup process. Click OK to continue.
Step 9:
You will now be taken to the main Cisco Connect window which lets you manage and further personalize your network settings. If you would like to learn more about the available features in Cisco Connect, please click here. Otherwise, you may click on the Close button to exit Cisco Connect, and begin surfing the Internet right away.
NOTE: To launch Cisco Connect again at later time, on a Windows computer, go to Start>All Programs>Cisco Connect. To launch Cisco Connect on a Mac computer, navigate to the Applications folder in Go, and then start Cisco Connect. For more help on this, please click here.
kb21463-010_en.png NOTE: Cisco Connect is automatically installed each time you use the Setup CD or Easy Setup Key to setup or connect to your Linksys Wireless-N Router.
Nov 02, 2010 | Linksys Wireless-G WRT54G Router
Computer repair tech said Linskey wireless caused internet prob
If you are using DSL as your internet connection there is a timeout period that could be setup in the linksys.
In order to change this you need to log into your router and on check on the setup page. You see the timeout option.
Check with your linksys manual for detailed instructions for logging into the unit. If you dont have it, you can always get it from their website.
Jul 31, 2009 | Linksys Wireless-G Broadband Router
Time Warner Cable won't identify Linksys WRV54G wireless router
If you can connect directly via your modem, then the line up to your house is fine. So no problem with your ISP.
Since you changed from cable to DSL, you might have to re-configure your router.
Open a web browser, type "192.168.1.1" in the address bar and log on to the web based router configuration page. (The default values are "admin" for username and "admin" for password)
Go to "Setup", choose "Basic" and review the entries there. You want to see it configured for "PPPoE".
Some DSL-based ISPs use PPPoE (Point-to-Point Protocol over Ethernet) to establish Internet connections. If you are connected to the Internet through a DSL line, check with your ISP to see if they use PPPoE.
If they do, you will have to enable PPPoE.
User Name and Password: enter the User Name and Password provided by your ISP.
Connect on Demand: Max Idle Time. You can configure the Router to cut the Internet connection after it has been inactive for a specified period of time (Max Idle Time). If your Internet connection has been terminated due to inactivity, Connect on Demand enables the router to automatically re-establish your connection as soon as you attempt to access the Internet again.
If you wish to activate Connect on Demand, click the radio button.
In the Max Idle Time field, enter the number of minutes you want to have elapsed before your Internet connection terminates.
Keep Alive Option: Redial Period. If you select this option, the router will periodically check your Internet connection. If you are disconnected, then the Router will automatically re-establish your connection. To use this option, click the radio button next to Keep Alive.
In the Redial Period field, you specify how often you want the Router to check the Internet connection. The default Redial Period is 30 seconds.
When you have finished making changes to the screen, click the Save Settings button to save the changes, or click the Cancel Changes button to undo your changes.
(This info is from the Linksys manual)
Dec 29, 2008 | Linksys -Cisco Wireless-G VPN Broadband...
Cannot detect the router
What version of the router do you have 1,0 or 1,1? This is located on the bottom of your router. There is a firmware update for both models, I will provide link. Also how is your laptop connected wired or wireless? Let me know and I will try to help you troubleshoot your problem. We always can set up your router manually.
http://www.linksys.com/servlet/Satellite?c=L_CASupport_C2&childpagename=US%2FLayout&cid=1169671597537&pagename=Linksys%2FCommon%2FVisitorWrapper&lid=9753741396B13&displaypage=nodata&proxyid=1172713508141
Jan 10, 2008 | Linksys Wireless-N WRT150N Router
Cannot obtain internet through router
Try resetting the router and modem. Unplug them both from the electrical outlet. Leave them unplugged for at least 1 minute. Then plug the modem in, let it establish a connection, then plug the router in. Do this with your pc turned off. After you reset the router and modem, plug them all back together and into the pc, then turn the pc back on.
Aug 23, 2007 | Linksys A+G WRT55AG Wireless Router
Linksys Wireless-G WRT54G Router Logo
29 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
