Question about Toys
I need a wiring diagram for a raptor 12v battery operated quad bike as it will only go forward and not reverse
4 Suggested Answers
rynanlimpiad
  • 36 Answers
SOURCE: motor burn out
replace motor
Posted on Apr 08, 2010
Samir3050
  • 70 Answers
SOURCE: Gator won't operate forward or reverse. Installed
It is the shifter has gone bad. Just to check you can exchange the red and blue wires under the pedal(just for a second or so, do not do this permanently) to see if you get power to the wheels, if so then yes it is Definitely only the shifter, but I am still pretty sure it is just the shifter. you can also call Peg Perego Tech support which is excellent and they can help you too 1800-728-2108 and parts can be priced and found at http://www.mypegperegoparts.com/asgi0115nyr.html
Posted on Mar 02, 2011
SOURCE: Megatredz yamaha raptor 12v, 12ah keeps blowing
Pop out foot switch and switch wires to other side of the switch. There should be a color code sticker on switch.
Posted on Aug 04, 2011
Mototech mini quad. Where do I charge it
Looks like you need a battery charger. It has two 12 volt batteries. Didn't it come with a charger? And your parental control is via a key.
The MotoTec 24v Mini Quad v2 is the ultimate kids atv! Great for driveway and backyard fun, cruise over bumps and speed through dirt trails with ease. Comes standard with front & rear suspension, front & rear brakes and large 13 inch knobby pneumatic tires. This mini quad provides longer ride times than the competition with TWO large 12v 12amp hour batteries. New features include: headlight, key start, battery meter, forward & reverse, 2 speeds selectable by key and twist throttle with safety foot switch. SAFETY FIRST - ALWAYS WEAR YOUR HELMET AND ALL SAFETY EQUIPMENT AND OBSERVE SAFE RIDING RULES!!! Motor: 24 Volt 350 Watt
Battery: TWO 12v 12ah (24v Total)
Top Speed: 5 & 10 MPH (parental speed control by key) Recommended Age: 6+ years old (A parent's decision to allow his or her child to ride this product should be based on the child's maturity, skill and ability to follow rules.)
Max Rider Weight: 150 lbs
Frame: Steel
Tires: 4.10-6 Knobby Pneumatic (13 inch)
Brakes: 2 disc front, 1 disc rear (with parking brake)
Suspension: 2 independent front shocks, 1 rear shock
Throttle: Variable twist-grip (with safety foot switch)
Seat: Padded (single rider)
Handlebars: Adjustable Forward/Back
Battery Meter: Yes
Key: Yes
Headlights: Yes
Charging Time: 4-6 hours
Charger Included: Yes
Assembly Required: Yes
ATV Size: 42x23x25 inches
Handle bar height from ground: 25 inches
Seat height from ground: 19 inches
ATV Weight: 101 lbs
Box Size: 43x25x22 inches
Box Weight: 114 lbs
Product decoration and specifications subject to change without notice.
Warranty: 30 days parts replacement
MotoTec 24v Mini Quad v2 Blue
Dec 09, 2015 | MotoTec Kids ATV-24v Mini Quad
Shifter moves on big bear 350 but quad wont reverse now it goes forwards
for some reason you are not getting into reverse , there is no real reason it should stay in forward gears unless there is someting wrong with the shifter itself being in the wrong position this can happen take it off and reposition it and make sure your clutch is disengauging to shift gears , will it go into all gears or just 1 forward , ck into that and be a little more specific on the problem ,good luck
Mar 18, 2014 | Grizzly Big Bear Atv Maintenance Free...
2010 atomik quad bike wiring diagram
Just call the mechanic and get it fixed, because if any wiring if connected wrong then it may causes a big damage than at this condition result in more expenses.
Classic Motorcycle
Feb 28, 2012 | Cars & Trucks
Quad only will move in reverse wont go forward it was working and then forward quit it and the battery is fully charged is a wiring diagram available
remove the battery and the black plasctic piece this will give you access to the shifter switch, verify that the connecters on the bottom of the shifter witch are still connected
May 23, 2011 | Polaris 800 Twin Sportsman Ride on Toy
Hi, my son has an electric razor quad bike with two 6 volt batteries. We have just replaced both batteries and the full charge light shows when you switch it on but it still wont start up. Can you...
The batteries should be 2 x 12v giving an output of 24v anything less than this the Razor Dirt Quad will not run. always make sure you buy genuine Razor replacement batteries.
Mar 29, 2011 | Razor Dirt Quad Bike
Reverse is out (major grinding, and quad doesn't
It is a pretty big job for a weekend mechanic. You will need some special tools > Impact driver, torque wrench, expanding 'C' ring pliers, case splitter and flywheel puller. The entire engine, top end and bottom end must be torn down. Don't try it without the manual. The clicking noise is probably a broken tooth on a gear. ALWAYS replace gears in sets, ALWAYS. The grinding is most likely a bad bearing.
Oct 19, 2009 | 2001 Yamaha XTZ 660
Panasonic EY7540 impact driver. Does not go into reverse on 1st
The forward/ reverse switch is hanging up and the rotation of the drill is switching it, then it changes direction. The switch needs a little TLC and a good cleaning. Blow it out.
Sep 26, 2009 | Panasonic Cordless 12V Compact Impact...
Looking for wiring diagram for quad bike
kanuni quad bike 150cc i need to fix eletric problem and break problems
Oct 28, 2008 | Hammering
Toys Logo
246 people viewed this question
Top Toys Experts
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
