Question about Proscan 26LA30Q 26 in. LCD Television
My procan tv light is purple and won't turn on
Light won't turn on Shark steam mop
I posted this video explaining how to clean the heater core of the S3501...it is likely a similar design as the Euro Pro.
http://youtu.be/S4NglGXVv50
Dec 09, 2012 | Euro-Pro Shark Steam Mop - Gray/ Purple...
2009 HHR won't start. Battery is good.
Is the security light on or blinking?If not then do you have power to the starter.You can check this with a test light.You should have power when you turn the key to start.The test light should light up.Should be the small wire.I believe it is purple in color.If the security light is on then you will have to get the codes to see what is causing the no start.Hope this helps.Good luck.
Dec 07, 2011 | 2009 Chevrolet HHR
My 1996 Buck LeSabre won't turn over. I took the starter off and had it checked, it was fine. I checked the starter fuses and all was fine. \ Cabling was fine to the starter, voltage was 12.54...
Be sure the AIR BAG/VATS fuse 10 amp, is good. there is a STARTER ENABLE RELAY up high on the left of the steering column. I ASSUME the anti theft light is not flashing?" at the STARTER ENABLE RELAY the YELLOW wire is hot in the crank mode and comes out large PURPLE to the starter. the small purple wire is hot in the crank mode if the fuse (air bag/vats) is good. the small yellow is grounded through the park switch and the VATS module (anti theft)
Sep 21, 2011 | Buick LeSabre Cars & Trucks
It takes about 5 mintes for my tv to actually turn on. I push the power button and it starts to cycle on and off. Sometimes i get purple spots on the tv when it finally turns on. If I turn it off then on...
hello,
Cycling turn on off mostly from capacitors on PCB power board. Read my tips for cycling power on here. For Purple spot i think because capacitor efect i hope.
Good luck.
Apr 19, 2011 | Samsung LN52A580 52 in. HD-Ready LCD TV
I have a procan tv w/o a remote, How can i make the remote that i have which is provided by dish network satellite work with the tv
Hello, the process to do this is fairly simple. Just follow the step provided from the link below, and you will be good to go!!!!!
http://www.dishnetwork.com/SupportSection/power-scan-instructions
Becki Barned
DISH Network Customer Service
Sep 13, 2010 | Proscan PS27600 27" TV
Samsung DLP HL-R5667W not turning on. Showed
Purple spots means Bad Light Engine Part number is BP96-00822J Encompass Parts Has them for
$950.00 - $350.00 core price Part $600.00
1-800-638-3328 Lamp# BP96-01073A
Ballast Board# BP47-00027A
Jan 08, 2010 | Samsung HL-R5667W 56" HDTV
42 plastma problem
Bad Capacitors in Power supply. IF doesnt help changing Capacitors Replace Power Supply Board
Feb 28, 2009 | Haier 42EP24S 42 in. EDTV-Ready Plasma...
Screen turns purple
Loss of green = purple!....Please give model # and age from
back of set ........T.
Oct 27, 2007 | Televison & Video
Proscan 26LA30Q 26 in. LCD Television Logo
50 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
