I am looking for the wiring diagram for the bulbs for an eden pure 1000 xl elite heater
  • 3,083 Answers
This is not going to be easy. I tried to go up to EdenPure's support site, and it's not functioning. Other appliance sites do not have the diagram. You have two good shots at this, 1. Contact the manufacturer through your literature that came with it, and 2. Reverse engineer the unit- that is, make diagrams, and label parts as you disassemble it. I see no other alternatives. It might be about as easy to find a good used one on Ebay, not sure.
Sorry I didn't have any firm news, but good luck, and hope this helps some.
Posted on Aug 22, 2010
How do I fix Eden Pure Heater? It goes on and off intermittently, mostly off.
You need to clean the filters in the back of the unit. It is not receiving enough air flow. They just snap out and wash the little foam filter and replace it.
Mar 10, 2015 | Eden Heating & Cooling
Why does my Eden Pure Gen 3 heater blow only warm air?
They have 3 heating elements. Perhaps one or more have burned out. They cost about $32 each.
Aug 31, 2014 | No Clove Leaf Pure Essential Oil 15ml, By...
Ew6507l - nowhere near warm enough
only made for 400 to 600 sq feet try Eden pure heater 1500 watts than cover 1000 sq feet the oil fill heater might have a switch 600 to 1500 watt there r usually a high and low to them good luck
Dec 11, 2013 | DeLonghi 6507L Oil Filled Radiator Heater
Test the element in eden pure
Copy following link for testing elements
http://waterheatertimer.org/How-to-test-water-heater-element.html
Multimeter required
http://waterheatertimer.org/images/ohm-reading-for-emements.jpg
Each element should have Volts and watts printed on end.
Ohm reading should be fairly close, or replace element
Apr 21, 2013 | Water Heaters
Eden pure starts blowing hot air and then turns cold
I recently fixed this issue for a family member on this exact model, the same issue, it would heat fine for 15 minutes and then cold blowing air would follow afterwards non stop, and when we powered down the unit and restarted it, it did the same exact thing. ( What worked for me ) was ordering a new " Thermostat " which is a white rectangle looking plastic thing with 2 blue wires coming out of it, you can find You-Tube video's showing you how to remove the Eden-pure gen3 cover housing easily, my total cost of this do it yourself repair was just under $20 as of 10/10/14 your cost could vary depending on different factors.
1st...unplug the unit....duh ! lol
Once the housing is removed, look at the top of the unit and locate the 2 blue wires coming out near the front, remove the 2 top screws holding in the thermostat, gently pull out the old thermostat but don't disconnect any blue wires yet, put the new thermostat in facing the exact same way as the old one, re-tighten the 2 screws, next follow one blue wire ( One is longer than the other ) to its location on the block, determine if its the shorter or longer wire, disconnect just 1 wire with a Phillips screw driver, and replace it with the like sized blue wire from the new thermostat, tighten but not over tight ! next do the same for the next blue wire on block.
After thermostat is secure and wiring is secure, put the cover and panels back together......and plug it in and test it again....... Hope this works for you as it did for me.
Good Luck !
Oct 12, 2012 | EDENPURE MINT A3705 Infrared Remote...
Need operational manual for eden pure G7
Hi:
You directed this question at me, but unfortunately this isn't my expertise and I am unable to provide you with a real solution at this time.
Hopefully one of other experts will be able to provide you with a real solution.
Thank you for using FixYa
Jan 06, 2012 | Eden Heating & Cooling
Eden pure heater starts to heat then elements shut off i replaced thermostat and heat sensor any other suggestions what to try next
yes u have overheatsensors that shut the strips down if they get too hot these may be going bad and getting weak and shutting off prematurely
Feb 20, 2010 | Reddy Heater R70 Portable Forced Air Space...
I have an eden pure xl model 1000xl. it is not
The bulbs/ elements for this xl 1000 are very easy to install. Not always too easy to find in stock though. PAY VERY CLOSE ATTENTION to the way the wires are ATTACHED! They MUST be reconnected in the EXACT way they were removed. BUT, just in case you forgot to look, I have pictures of the terminal blocks. Hope this is a help as there are no other diagrams or pictures that I have found on the net! Good Luck!
Dec 29, 2009 | Heating & Cooling
Heating & Cooling Logo
476 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
