Question about Black & Decker Hedge Trimmer
The motor on my Black & Decker HS 1010 hedge trimmer has started to run slowly. Do you have a solution & would it be worth repairing.
boscia
  • 163 Answers
SOURCE: Black and Decker 16 in Hedge Trimmer
I use a dremel with a sharpening stone, if u don't have one you can also use a power drill with a small sanding disk (1 inch) and course sand paper (30 or 40 grit). or you can use a bastard file. its too tight to use any kind of angle guide so just take your time and do it by eye. it shouldn't take much to get them sharp enough to do the job, over-sharpening is unnecessary and dangerous, and will make the blades dull faster. sharpen all the free blades, top and bottom, then start the trimmers to advance the blades to free up the sides you couldn't get. i use a light penetrating oil to clean the blades first, then lithium grease spray to lubricate.
Posted on Nov 28, 2008
  • 279 Answers
SOURCE: Describe your Black & Decker Hedge Hog
You may have a piece of metal between the moving blade and the stationary one. Also the motor may have been at the top of the stroke when it stopped. You may be able to "force" the blade to move a little. This may free it enough to work.
Posted on Jul 14, 2009
  • 18 Answers
SOURCE: Black & Decker Hedge Hog 24-Inch Hedge
You can definitely pick up a sheer pin for that model. I know ereplacementparts.com has them usually pretty discounted, or just check out a local store, but make sure they are in stock.
Posted on Apr 29, 2010
  • 5 Answers
SOURCE: My Black and Decker hedge trimmer's blades won't
Your blades are stuck together.
Had the same problem: when I turn on the trimmer, the motor would hum but the blades won't move.
What I did:
1. Sprayed a ton of wd40 between the blades
2. Took a screwdriver and kinda wedged it between the blades to get them unstuck. Also removed some guck between the blades.
And it worked!
Posted on Jun 09, 2010
  • 5 Answers
SOURCE: homelite hedge trimmer , motor runs but blades do
What I did:
And it worked!
Broken won't move
Check the teeth for something jamed. Has it set up for many years, maybe rusted bar. Does the motor run? If so maybe a cam gear broken or jam. Does the teeth on the bar move when removed from unit? Or does the motor run when bar removed? To many question to ask need more info.
Jul 04, 2015 | Black & Decker Hedge Hog 22-Inch 2.8-AMP...
My Black & Decker trimmer starts and stops whenever I move the trimmer in any direction -- any advise as to how to solve this problem?
I'm not familiar with your machine, BUT... that description of symptom sounds suspiciously like a bad/poor electrical connection.
The problem could be in many places:
  • plug
  • cord
  • switch
  • brushes
  • internal electrical wiring
The "solution" to this problem is for someone who knows what s/he is doing, to troubleshoot the defective machine, determine the defect, and properly repair or replace the defective part.
Jun 10, 2014 | Black & Decker Hedge Hog 20-Inch 2.8-AMP...
I bellieve I have sheared a pin or bolt. The trimmer runs fine but the teeth do not move. Any suggestions. Is there a operators manuel online?
Had the same problem with my Stihk hs 81 R hedge trimmers. Ive stripped it down and found that the clutch drum had sheared. Hope this helps.
Apr 28, 2012 | Black & Decker 22 In Dual Action Hedge...
Two-year-old Black & Decker 19"
if its not in the cord. it may be the brushes in the motor. if they are worn down and not hitting armature. motor will not run. good-day !
May 05, 2011 | Black & Decker 19" Electric Lawnhog...
I have a Black and Decker 17" Hedge Trimmer
id check the electric motor first, was it whining when it was going? like maby the brushes in the motor are worn out. if so u can maby get replacements
Mar 22, 2011 | Black & Decker 17 in Hedge Trimmer
Need diagram of blade assembly for Hedge Hog HS 2400 Type 1. Need to know how the spacers and eccentric are laid out between the blades.
try hulufile.com its a good source for pdf manuals on 2 stroke machines. i hope you find this useful as i use them alot ..
Nov 23, 2010 | Black & Decker Hedge Hog 24-Inch 3.0-AMP...
Black & Decker GT370-GT371 20 inch hedge trimmer - electrical fault in front handle causing difficulty in starting/resuming cutting. There is no local servicing and help from B&D was restricted...
Your best bet would be to use http://www.eReplacementParts.com as a source to get your Black and Decker parts and than use their tool repair forum and submit this question. They have licensed mechanics that repair these things all the time, so I'm sure they could put together an easy fix.
Sep 28, 2010 | Black & Decker Hedge Hog 22-Inch 2.8-AMP...
My hedge trimmer blades do not move when I turn it on
Check the power wires that connect to the motor. My 18 inch B&D hedge trimmers both had loose wires at the motor that had to be re-soldered. You will need to open the trimmer casing to get to the loose wires, if that is the problem.
Jul 09, 2010 | Black & Decker Hedge Hog 20-Inch 2.8-AMP...
Black & Decker Hedge Hog 24-Inch Hedge Trimmer. Motor runs, but blades don't move. Is there a sheer pin that I can replace, or is the thing bound for the dump?
Apr 27, 2010 | Black & Decker Hedge Hog 22-Inch 2.8-AMP...
Jul 14, 2009 | Black & Decker Hedge Hog 22-Inch 2.8-AMP...
Black & Decker Hedge Trimmer  Logo
47 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
