How can i connect a ps3 to my dmtech tv? when the hdmi cable is plugged in at both end - there is 'no signal' message on the tv screen?
SOURCE: PS3 (Pal) won't connect to Sylvania HD TV
I just figured it out last night - if you have used your playstation on an hd tv previously, it is set at the highest resolution possible - 1080p. You need to take it back to that tv, and go to display settings on your tv. If you select HDMI as they type of connection you'd like to make, it asks you what resolution your tv supports. In your tv instruction guide, it should give you this information. Check mark all of the resolutions your tv supports, making sure not to confuse 1080i and 1080p. After doing this you can take it back to your other television and it should work.
Posted on Feb 17, 2009
gymhasafit
  • 31 Answers
SOURCE: Sharp Aquos LC-46d65U HDMI connect
First off a little tip that manufacturers don't tell you is that you HAVE to TURN OFF the POWER to ANY UNITS that you are Connecting to via HDMI!!!!!!! If not you can short out the Inputs!!!!!!!! HDMI is usually Automatic, But sometimes you need to go into the Menus on all Devices to the HDMI section and write down their settings and compare them. Any definition that you are not sure of check the Manual or Google it! Match all the Settings (there won't be Much!) Hopefully the Inputs were not Damaged it only takes one time to short it out and then the Repairman makes a few bucks! Good Luck!
Posted on Apr 29, 2009
SOURCE: Help HDMI Splitter Doesn't Work!
The HDMI splitter is intended to take one source to two displays. You need an HDMI switch to take two sources to one display, a device you can tell which input to select.
Posted on Jul 08, 2009
freelander72
  • 124 Answers
SOURCE: Problem connecting my PS3 to my Sharp Aquos LC-C3237U LCD TV
ps3 signal is 1080p you need a 1080p tv for it to be compatible.
Posted on Sep 17, 2009
Testimonial: "Thanks"
SOURCE: samsung 610 46'' lcd - hdmi input not working
why hdmi input wont show up
Posted on Dec 22, 2009
How do I set my hdmi to pick of signal of my ps3
HDMI are initials that are referencing either a cable, a switch box, a device, and your television set/monitor.
your device, such as your PS3, has a HDMI receptacle. Your television or monitor if HDMI ready, also has a matching receptacle. An HDMI cable has the same plug ends on either side. They will then plug-in to your device on one end of the cable and to your television on the other end of the cable. The HDMI receptacle on your television, is labeled either 1- 2 - 3 maybe even 4?
you will then get the remote for the TV, and press input, and then you choose the labeled receptacle that your device is plugged into, in your case the PS3, let's say you plug it into HDMI number 1, when you press the input on your remote, you'll scroll to HDMI number 1, and your PS3 will now magically appear on your TV.
Mar 26, 2015 | Video Game Consoles & Games
Samsung 2007 27" TX-T3092WH will not support HDMI or cannot see PS3?
HI,
Do one thing While PS3 is in standby mode press and hold the power button on the frond panel of PS3 for 30 seconds (factory reset). After doing this you will get video from its composite video.
Also check the hdmi If you didnt get the video through HDMI then,
PS3 out puts Full HD 1080P video through its HDMI out put. IF your tv doesn't support Full HD then it will display format not supported or Software not support.
If you want to get video through HDMI then do the following.
Connect the PS3 to any Full HD tv (friends or relatives) and go to its menu ,select HDMI settings. then down scale the video from 1080p to 1080i.
After that connect the PS3 to your tv you will surely get the video.
Ajin
Jun 16, 2012 | Samsung TX-T3092WH TV
How do I connect my PS3 to my sanyo dp50747 in hdmi? I have everything hooked up correctly, but its not coming up on the TV. What do I do?????
If you see a no signal message, then it means that the signal output format of the PS3 does not match . It happens if you have previous used it on another tv and now connected it to a different tv. To resolve this, turn off the PS3 . Press and hold the power button on the PS3 till you hear three BEEPS. The PS3 should automatically detect the tv's resolution and the initial setup screen should appear. After that you should just follow on-screen instructions to set it up.
Sep 26, 2011 | Sanyo DP50747 50 in. Plasma TV
How do i connect a playstation 3 to a philips tv
The PlayStation 3 (PS3) is a high-definition gaming console that supports both standard AV connections and high-resolution connections (such as HDMI). Most of the older Philips TVs come with a standard AV input. Newer, flat-panel Philips TVs include standard AV inputs and high-resolution inputs. To get the best video quality out of your PS3, using an HDMI connection is recommended if the option is available. The PS3 does not include an HDMI cable, only a standard AV cable
Standard AV
  • 1 Turn off the PS3.
  • 2 Connect the flat end of the PS3 AV cable into the "AV Multi Out" port on the back of the PS3.
  • 3 Connect the "red," "white" and "yellow" prongs on the opposite end of the PS3 AV cable into the corresponding "red," "white" and "yellow" AV inputs on the TV (usually located on the side or in the back).
  • 4 Press the "Source" button on the Philips TV remote.
  • 5 Select the "AV" video display mode.
  • 6 Turn on the PS3. The PS3 logo will appear on the screen.
  • HDMI Connection
    Dec 08, 2010 | Philips Televison & Video
    No Input Signal when PS3 is connected to TV
    go to your video sttings in the XMB and make sure HDMI is selected as the connection type
    Mar 24, 2010 | Sony Playstation 3 (PS3) Console
    No signal on my TV
    try connecting the ps3 to the HDMI only, now when the ps3 is off and all but the single red light is on rest your finger on the on button for about 8 seconds, as soon as you touch it it will turn on but just wait a bit and you'll here the a second beep- this should reset your ps3's video output settings. Try it out, it works for me when i go back and forth from av to HDMI.
    Please remember to rate my response if helpful.
    May 30, 2009 | Sony Playstation 3 (PS3) Console
    No signal on my TV
    have you changed ps3 output to hdmi?
    May 28, 2009 | Sony Playstation 3 (PS3) Console
    PS3 not working on 42'' JVC via HDMI cable port
    I have the PS3 and this TV and it works....Try this.
    1. Turn ON TV
    2. Connect HDMI from TV to PS3
    3. Select the correct HDMI input on the TV for the PS3(important)
    4.Turn OFF PS3 if it is ON.
    5. hold [I/O] Power button on PS3
    6. Wait about 5 second and you should get the "HDMI Detected" or some similar message.
    7. Configure the HDMI output for the PS3
    Also, If you set the PS3 to "auto" for hdmi, it may set the resolution to 1080i. You may want to deselect everthing but the 1080P.
    Mar 24, 2009 | Sony Playstation 3 40GB System Console
    Having trouble playing my Ps3 on a non HD tv after already using it on a HD tv
    Hey bro try going down to circuit city, best buy and get the HDMI cord that converts to a Component cable on the opposite end. You can do this as long as the back of the non H/D tv has the Component Inputs on the back of the TV. If that does not work get the HDMI cable that converts on the opposite end to a S Video signal and connect that end to the S Video input on the back of your tv. I have seen these cables at circuit city in the playstation section. Again on one end of the cable it has your HDMI input to connect to your ps3 and on the opposite end of the cable it has the S video plug to run to the back of your tv and plug it into the S Video input. Same thing can be said for the HDMI on one end of the cable and the Component cables on the opposite end to run to the back of your tv. This will work if you find those cables. Good Luck.
    Sep 16, 2008 | Sony Playstation 3 (PS3) Console
    HDMI ON ILO 32HD
    it sounds like there is a problem with either the output on the PS3 or the input on the circuit board of the TV. I would try a reset on the PS3 first. Also make sure that there are no other video or audio cords plugged into the PS3 because this will cause the PS3 not to send the signal via the HDMI.
    Mar 14, 2008 | iLO 2600 Television
    Televison & Video Logo
    119 people viewed this question
    Top Televison & Video Experts
    Electro Med Services...
