Question about Microwave Ovens
I have smeg hood model P780 now it is not work when i turn on and i try to press swicth for light it is notthing .
Why doesn't it work?
Not sure what "elements" you are referring to on a microwave oven but in any case, give the electrician who installed it an opportunity to get it working.
Dec 16, 2015 | Smeg Microwave Ovens
I have a Smeg FME24X 900 Watts Microwave Oven, and has stopped working, no power but occasionaly the display lights for a fraction of a second, any ideas? Have tried replacing fuse in plug but still only...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Sep 08, 2010 | Smeg FME24X Microwave Oven
GE MIcrowave model JVM1631BJ01 hood lights won't work
The part that controls that is goes through your control panel on your microwave. For the lights to come on to start with the door being closed switches have to be working right and when you press start the lights come one. When the microwave is through cooking and you open then close the door then the lights should go out. The logic IC on the control panel board that detects all these events is not being reset correctly. Unless you get a microwave tech to track down the component on the control panel circuit board it is not something that you could do on your own since it takes voltage and signal checks with the proper equipment and then some soldering and desoldering of the defective component(s). Good luck and God bless.
Dec 22, 2008 | GE JVM1631 Microwave Oven
Need to remove this fitted SMEG FME24X Microwave
Thanks for the quick reply. As you said this has been mounted into a recess and surrounded like a picture frame.
I found some screws are very deep inside the recess and it has been obstructed by the grille/frame.
If you have any pics or any illustration, can you please forward it to me.
Thanks
Oct 24, 2008 | Smeg FME24X Microwave Oven
My smeg microwave is not heating. i think the light globe is blown. how to get it fix?
I would recommend you visit Smeg Service spares.
Oct 19, 2008 | Smeg Microwave Ovens
No power, is there a fuse for model no. SA31-1MX
It may be the fuse, which is usually located on the floor of the oven behind the control panel or between the door switches.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
It will probably be a grey or white ceramic fuse. If you can't find one locally, try Smeg Service spares.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 20, 2008 | Smeg Microwave Ovens
Fmc30x - microwave not working at all. Oven and Grill still work and the light is still on.
I would suggest you contact Smeg:
http://www.smeg.com
http://www.smegusa.com
We're happy to help and we appreciate your thoughtful rating of our answer.
May 05, 2008 | Microwave Ovens
Smeg Microwave Components
Generally speaking, light bulbs can be had from common sources such as department stores, home improvement stores, and hardware stores. Of course, I don't know much about what you'd call those places "down under and over a bit", but I'm sure the terms will translate well enough. *grin*
May 16, 2007 | Smeg S43KIT3750EB Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
