Question about Water Heaters
No hot water. Display reads ER3. - Water Heaters
Not sure how to remedy this as I have no Instruction Booklet. However, I disconnected system then rebooted it. Seemed to do the trick!
Posted on Feb 09, 2015
    Problem Solver:
  • 6 Answers
Hi, If you have the book for this system, then go to the problem solving to the rear of manual. This will tell you what code ER3 means, and what you need to do to correct it.
If you dont have the manufacturer's book then try to down load it!.
All boilers and water heaters have different fault finding codes, so can-not give any more info, unless you can tell me the exact problem.
Thanks Paul.
Posted on Aug 31, 2010
ER3 error code on amtrol hot water tank
Simply means hot water heater called for heat for 1 hour and never rose in temperature or reach stepping, unit automatically goes into lockout. I would reset power
Feb 14, 2015 | Amtrol WHS-80Z - WHS-80Z 80Gal Hot Wtr...
Er3 flashes hot water will not reach set point
Had this happen to me before, if you have hot water from the boiler going in and out of the boiler mate and the temps are not rising within the hot water means more than likely you may need to remove exchanger and clean sediment off element, basically sediment creates a blanket over the heat source causing poor thermal conductivity. Things to check before removing heat exchanger
- outlet temp of boiler water to aquamate -inlet temp of boiler water to aqua mate= 20-30'F if low then bad thermal transfer or poor water movement
-make sure sensor is reading properly
- get boiler temp higher to speed up thermal gain in water heater
Jan 19, 2014 | Amtrol 2704E76 41 Gallon WH-7C BoilerMate...
Boilermate er3
is it an electric or gas or oil fired. Er3 means it is not getting up to temperature within the required time. Electrical - element bad. for oil or gas, no ignition or fuel supply.
Oct 28, 2013 | Amtrol ST-120V-C THERM-X-TROL ASME...
What does an error code ER3 tell me?
It tells you that your water heater called for heat for more than an hr and never got hot enough to meet the demand.
CAUSES
-bad sensors
-no hot water from boiler
-bad thermal transfer
-low delta T across water heater
Oct 09, 2013 | Amtrol 2775S5009 60 Gallon WHS-60Z...
Noticed the circuit panel is blinking the code Er3, what does this mean?
CAUSES
-bad sensors
Sep 02, 2013 | Amtrol 2704E76 WH-7C Premier Boilermate...
I'm getting an er3 reading on my water heater tank , what does that mean
CAUSES
-bad sensors
Apr 21, 2011 | Amtrol ST-120V-C THERM-X-TROL ASME...
Armitrol boiler mate hot water maker has code er3 and we have not hot water. can u tell us what that code means?
It tells you that your water heater called for heat for more than an hr and never got hot enough to meet the demand. multiple scenarios can cause this
CAUSES
-bad sensors
Dec 02, 2010 | Amtrol ST-120V-C THERM-X-TROL ASME...
I have a ER3 message. How can I fix this
CAUSES
-bad sensors
Mar 15, 2010 | Amtrol ST-120V-C THERM-X-TROL ASME...
ER3 no hot water
Er3 means that the water is being heated for more than 1 hour without reaching the set temperature.
Need new aquastat.
Sep 28, 2009 | Amtrol ST-120V-C THERM-X-TROL ASME...
No hot water from the Amtrol Boiler Mate model wh7p
The smart control was only reading 140 it never went up or down from that number and now it has an ER3 code seem the circulator just runs and runs
Mar 09, 2009 | Water Heaters
Water Heaters Logo
347 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
