Question about Clarion XMD3-RET AM/FM MARINE CD PLAYER
Recently install, the cd door of XMD3 will not open. what can i do?
Clarion MXD3
It looks lik the on/off switch is faulty. Check for loose internal wiring or faulty soldering.
May 20, 2008 | Clarion XMD3
XMD3 I bought a second hand boat with this radio , not working , do you have an installation schema ?Thanks
hello there ,firstly at the rear of the radio you will see two plastic blocks top block is your power in )secondly bottom block is your( audio ) sound these wires are colour coded for front and rear speakers ,your dc power which cannot be over 13.8v black and red wire on top block you have a socket to the right this will be for the antenna ,also check the fuse line before switching on hope this helps you
goodluck
Mar 25, 2011 | Clarion XMD3-RET AM/FM MARINE CD PLAYER
CD doesn't eject CLARION XMD3 marine radio
Disconnect the fuse of radio and reconnect it again.
That should force him to eject the CD
Oct 27, 2009 | Clarion XMD3-RET AM/FM MARINE CD PLAYER
No Sirius function available.
I have the same problem. When scrolling through the source options, the display goes from tuner-cd-aux and back to tuner...no sat. radio. need help.
May 29, 2009 | Clarion XMD3
I have a Clarion installed in my boat. Sirrius, cd am fm. No jack to plug in iPod. Solution?
FM Modulator.
(clarion makes a hardwire direct connect one)
FM200
You would use a 3.5mm to RCA adapter
There are also battery powerd ones (Belkin)
Either one is used by simply tuning in to an empty (white noise) radio station.
Im assuming the XMD3-RET is not the radio you are inquiring about since you described Sirius as a feature.
Some clarion radios have an AUX input or changer port that can be converted to an ipod cable.
If you reply with a model # i can look it up for you. I am a Clarion Dealer.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question
Apr 14, 2009 | Clarion XMD3-RET AM/FM MARINE CD PLAYER
Instaling a Clarion XMD3
clarion website download + print
Jan 08, 2009 | Clarion XMD3
NO SOUND FROM CLARION XMD3
I have a XMD3 with Sirius on a Larson boat. Had same problem - everything seemed to be fine on unit (everything lit up and CD showed different tracks and time changing), but no sound. I suspected a ground problem and checked wires I could see. Found one speaker wire that had been frayed due to faulty installation. As soon as I wiggled that wire I got sound on all speakers. Not sure why one faulty speaker would kill all sound, but it did for me.
Oct 19, 2007 | Clarion XMD3
Car Audio & Video Logo
42 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Marco Avila
Marco Avila
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
