Question about HP Officejet Pro L7580 All-In-One InkJet Printer
Unreadable printer screen messages and unable to print, or scan. Lost computer and possibley damaged printer in lightning storm. Printer screen displays unreadable symbols.
    President:
  • 1,566 Answers
Jim,
I would highly suggest you let a technician personally check on your printer to avoid causing more problems to the unit. If the machine is not over a year, it is possible you can still claim the warranty. Most probably, some of the parts are toasted and it already needs replacement. Touching the internal parts is very crucial.
Posted on Aug 22, 2010
HOW TO FIX...PRINTER IS OFFLINE BUT IT IS ON...WE ARE UNABLE TO PRINT.
If you are getting a status message as the printer is offline on your pc,and afterward you can't ready to print the reports.
Steps to Resolve the Printer Offline Issue:
Step 1:
At first, you need to check your network through the HP Scan Doctor which encourages you to discover and fix the printing issues.
Steps To Run the HP Scan Doctor
    •Open the HP Scan Doctor tool by double tapping the symbol.
    •Start- - >Select your printer- - > Fix Printing
    •Then the list of issues displayed on the screen as result.
    •If the tool shows the white checkmarks at that point there is no issue.
    •If the tool shows the white wrench then the issues are found and repaired
    •If the tool shows the yellow shout point then the issues are found however that can't be solved or skipped.
    •If the device shows the red stamp then you have to take after the on-screen guidelines to determine the issues.
    Step 2:
      Set Your Printer as Default Printer
      •Search your gadget on your PC and select your printer and uncheck the Pause Printing and Use Printer Offline
    •If you can capable print implies your printer is online.
    Officejet 4650 keeps going offline then proceeds with following step Step 3:
    Check Whether You Connect With Correct Port
      •Go to printer- - > Printer Properties - >Port
      •For USB association utilize USB or DOT4
      •For Network Connection use WSD, organize, Standard TCP/IP Port Step 4:
      •Update the printer firmware which may resolve your issues
      Step 5:
      •Manually connect the wired or wireless connection
      Step 6:
        •For network connection just you have to add the second printer to your Windows.
        •Select your printer - > Properties - >Add Port - > Standard TCP/IP Port - > Next port
        •Now you can ready to print implies stop the troubleshooting. Still get the same issue mean you need to connect the printer customer support via +1-800-836-3987
Jan 08, 2016 | Office Equipment & Supplies
Unable to print 76
Yay, the real answer. Be careful to have clean hands when touching the decoder strip or you may damage it and then you will need to replace it.
http://support.brother-usa.com/ModelDocuments/Technical/Service%20Updates/SU_F1379.PDF
Jul 05, 2012 | Brother MFCJ6710DW All-In-One InkJet...
My printer won't print. It will also say "unable
Ok, for the printing part you should check the following:
-connection between printer and computer
-make sure the machine is not in power save mode
-make sure machine is online; click start, printers, choose printer and make sure 'Use Printer Offline' is unchecked
-reinstall the drivers from here: http://welcome.solutions.brother.com/BSC/public/as/au/en/model_top/colormfc/mfc5490cn_all.html?reg=as&c=au&lang=en&prod=mfc5490cn_all
Now regarding the scan error, seems to be a mechanical error. Remove and objects that might stop the scanning to proceed. Also, check the manual for Troubleshooting on the link above.
Nov 14, 2010 | Brother MFC-5490CN Flatbed Inkjet...
Brother DCP 330C 'unable to clean 46' printer will not print
responded to this on a error 46 post by joachim.
hth,
razors
Mar 24, 2009 | Brother DCP-330C All-In-One InkJet Printer
Will copy, won't print
you may have to reinstall the printer software. The computer may have lost the printer driver and the connection recognition.
if not, try a different USB port, and replace the USB cable if necessary
Nov 27, 2008 | HP Photosmart C3180 All-In-One InkJet...
Printer will not print after lightning storm
Hi chk u r parllport working /not?
if u have drivers cd ,delete the printr &restart u r computr,see u r computr is detected the prntr /not ?if detect install drvs &chk
tell me ple.
Aug 12, 2008 | Epson LX-300 Matrix Printer
Printer message: Unable to Print
5A: encoder disc or encoder strip or main circuit board or printhead circuit board or power supply defective!
Sorry, cant be fixed by yourself!
Feb 20, 2008 | Brother MFC-440CN InkJet Printer
5A means that the purge cam stopps abnormally when it is in use. This could be of a broken cam shaft. You have to replace the whole purge unit. This is a service job to do!
Aug 27, 2007 | Brother MFC 420CN All-In-One InkJet...
HP Officejet Pro L7580 All-In-One InkJet Printer Logo
Seeker5211
Seeker5211
