Question about Maytag Dryers
Have to put a four wire pig tail on maytag de313. can you give me the color coded connections for the pig tail to dryer connection?
  • 10,319 Answers
Two of these wires are for 110 volts
these colors can be of any color since Maytag does not produce them.
an ohm meter in hand will tell tou which wire is for 110 spades on the plugs end.
the other two wires are ground wires only
one connects to the center plugs prong
the other to the dryers back sheet metal panel for added grounding protection
Posted on Aug 22, 2010
Can you change a four prong pigtail with a three prong pigtail on a whirlpool duet dryer
Yes, you surely can!
Here's how.
When you open up the back of the machine where the electric cord attaches, you will see a row of 3 screws/bolts.
Your 4 wire cord has the black wire going to one of those screw/bolts. That is a HOT connection.
Your cord also has a red wire attached to a screw/bolt. It too is HOT.
These two hot connections are the outside two of the row of three screws/bolts.
The one in the middle is a ground wire, and is white.
The other, the fourth wire, usually blue or green, it is attached directly to the sheet metal of the dryer itself.
It too is ground..
Now, the 3 wire cord is not color coded, it is "position" coded.
The two outside wires go to the outside (in the row of 3) screw/bolts of the dryer. the middle wire is hooked to the middle ground screw.
It doesn't matter whether the outside wires go to the right screw or the left screw, but never to the middle screw.
By the same token, never hook the middle wire to an outside screw/bolt.
You will have no fourth wire going to the sheet metal.
Be blessed.
Apr 16, 2013 | Dryers
How do I change from a three wire to a four wire pig-tale on a Maytag 3000 dryer?
Here is a tip that will help you with changing your dryer plug.
Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
heatman101
Dec 15, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Having to replace 3 wire power cord with four wire and can't find manual and unsure how to connect propperly.
Connect the colors with the colors on the dryer wires Black with black, White to white, and red to red. The green wire gets attached to the dryer cabinet on the screw on the outside of the access hole on left normally. on the exterior of the cover. Give me a rating if I helped you. Good luck!
Aug 22, 2010 | Maytag MDE308DAYW Electric Dryer
I need to know which wires on the new pig tail wire in the the old harniss they are different colors but they both are marked a b c d so do i match colors or do i match a b c d can you tell me or show me...
Your best bet is to go to mitchelldiy online and get the wiring diagrams. Not knowing what year your car is and what harness or computer or component your talking about and since the wiring harness may not be the correct one for your application I would be hesitant to give advice that could ruin a computer if hooked up wrong.
Mar 22, 2010 | Cadillac STS Cars & Trucks
Changing pig tail from three prong to 4 prong on maytag dryer where do i put the red black white and green wires on the pig tail connection on the dryer
the red black and white wire go in the same place as the other wires and the green wire gets screwed to the green ground screw.
the white wire goes in the middle red to the left and black to the right.or just look att he wires and match them
Mar 09, 2010 | Dryers
User manual for Maytag DE313 Series 107
(Click below for user manual)
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=RF262LXSB0&siteCd=WHRCOM
The age of your dryer I'm not sure, The elements for your dryer can be found below, go to my web-page and enter the model DE313 into search feature and you will get pictures of the parts. The element part# is Y313538 (click link below)
http://servicepartstec.blogspot.com/
If you need help, just let me know,Thanks,Sea Breeze
Mar 23, 2009 | Maytag Dryers
Trying to connect dryer cord to a neptune, old dryer had place for four connections, this one has two connections and and one off to th side with a white wire and a green wire the cord is three prong...
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
I don't quite understand what was wired how but the wiring should be as follows:
For a 4 prong plug and matching outlet
1. Black wire on one end terminal of choice.
2. Red wire on remaining end terminal.
3. White wire only, on the center terminal
4. Green wire on the the dryer frame or chassis terminal.
For a 3 prong cord and matching outlet:
1. Black wire on one terminal end of your choice.
2. Red wire on the remaining end terminal.
3. White wire on the center terminal.
Always be certain that the wire in the breaker or fusebox match the wiring of your outlet.
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Jul 02, 2008 | Dryers
Electric dryer internal short
Make sure that the dryer is disconnected from the wall outlet before doing any repairs on it. Electric dryer work on 240 volts AC and this could hurt or even kill you. loose connection on the terminal block will cause the wires to get hot. and melt the terminal block and wires and the pig tail wires. you will have to replace the terminal block and pig tail wires and make sure you use the correct bolts and make sure you tighen them. let me know if this helps.krazytech
Sep 09, 2007 | Magic Chef CYE4000AWW Electric Dryer
Dryers Logo
51 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
