I have a wi-fi printer and despite downloading the software on my printer and going through the steps several times to set it up on my computer, I've been unsuccessful. Any ideas?
  • Blessedx Sep 30, 2009
    The orange Wi Fi light is still on , why?
    Genius:
  • 3,587 Answers
Hmmm..it's all about IP addressing..you may need to modify the ip addressing in your network connections panel..
Posted on May 04, 2008
My Kindle is not recognizing my wi-fi signal. No Wi-Fi signals show up on the list. I have tried several times to turn the Wi-Fi on and it doesn't work.
I would recommend backing up all of your data and reset the device to factory setting and try again. Sometime software have glitches and required a complete factory reset.
May 09, 2017 | Tablets & eReaders
Connection to itunes
Hi Yvonne
Several things you can try...
To check for updates, tap Settings > General > Software Update. You can also connect your iPhone, iPad, or iPod touch to iTunes and click Check for Update on your device's Summary page. To check that you're in range of a Wi-Fi router or base station.
  1. That your date, time, and time zone are correct. Tap Settings > General > Date & Time. Time Zone might list another city in your time zone.
  2. That your iOS software is up to date. To check for updates, tap Settings > General > Software Update. You can also connect your iPhone, iPad, or iPod touch to iTunes and click Check for Updateon your device's Summary page.
  3. To check that you're in range of a Wi-Fi router or base station. If you're using cellular service, make sure that cellular data is turned on from Settings > Cellular. If you're connected to cellular data, larger items might not download. You might need to connect to Wi-Fi to download apps, videos, and podcasts.
  4. That you have an active Internet connection. For help with your connection, check your device's user guide.
  5. To see if other devices, like portable computers, can connect to the Wi-Fi network and access the Internet.
  6. To reset your Wi-Fi router by turning it off and then on again.
Jul 07, 2016 | Apple iPhone Cell Phones
Cannot unblock iphone 5
Fix the issue on your iPhone, iPad, or iPod touch If you can't connect to the iTunes Store on your iPhone, iPad, or iPod touch, make sure:
If there's still an issue, learn what to do if your device won't connect to a Wi-Fi network.
Jul 07, 2016 | Apple iPhone 5
I have a different home wi fi router how do i reconnect my wi fi thermostat sing-in
Press Fan & up arrow @ the same time until you get into programming mode. download the manual & go through the numbered steps until you get to the turn wifi on & off. When you turn it on, it should show up on your computer wifi list. then program the wifi the same way you did initially with the other router.
Jun 05, 2016 | Honeywell RTH6580WF Wi-Fi Thermostat
Can't connect iPhone 5s and hp 1220c
Sir/Madam
iOS: Troubleshooting Wi-Fi networks and connections Symptoms This Issue is Related To Your apple Mobile And Make Sure You Already Install HP Printer Software In Your Desktop or Laptop. If yes I suggest you perform below Solution for Your Apple 5s and HP Priter Connectivity Issue:
Learn how to troubleshoot WiFi.Issues you may encounter while using your iPhone, iPad, or iPod touch.
Resolution Occasionally while using your iOS device, you may notice unexpected Wi-Fi behavior: Difficulty locating or connecting to a network
Unexpected Wi-Fi signal strength or disconnects
Inability to access the Internet
Not automatically connecting to WiFi when expected
Follow these steps to troubleshoot the above issues:
1.Be sure you're in range of your Wi-Fi router (access point).
2.TapSettings WiFiand turn WiFi off and on. If your Wi-Fi setting is dimmed,follow these steps.
1.Confirm that your Wi-Fi router and cable or DSL modem are connected to power, turned on, and connected to the Internet. If not, refer to your network administrator or Internet service provider (ISP) for assistance.
2.Restart your iOS device.
3.Tap Settings WiFi and locate the WiFi network to which you're connected.
4.Tap and Forget this Network.
5.Try to connect to your desired Wi-Fi network.
Note: You may need to enter your Wi-Fi password again if your network requires one.
6.Turn your Wi-Fi router off and on. If your ISP also provides cable or phone service, check with them before attempting this step to avoid interruption of service.
7.Update your deviceto the latest version of software.
8.Update your Wi-Fi router to the latest firmware. For AirPort Base Stations,install updates using the AirPort Utility.
If the issue is still unresolved Follow the steps below for the issue you're experiencing.
Collapse All'Expand All
Unable to locate a Wi-Fi network
Unable to connect to a Wi-Fi network
WiFi disconnects or signal strength is less than expected
Unable to access the Internet while connected to Wi-Fi
Unable to automatically connect to Wi-Fi
Additional Information Find information onconnecting to a Wi-Fi network.
Some third-party routers may not be compatible with all iOS devices, even after updating to the latest firmware. If your iOS devices can successfully connect to other Wi-Fi networks, contact your router's manufacturer to ensure that your router is compatible with your iOS device.
See recommended settings forconfiguring your Wi-Fi router for use with iOS devices.
Notes
1.iOS devices sold in China may use the term Wireless LAN (WLAN) instead of Wi-Fi. Not all China iPhone models supportWLAN.
2.If needed, please consult with your network administrator (which may be your Internet Service Provider) for assistance with this step.
3.iPhone 5, iPad devices, and iPod touch (5th generation) are the only iOS devices that can connect to 5 GHz networks.
If You Still Haveing Problem then Visit official Below Apple Website URL Link:
http://support.apple.com/kb/ts1398
Or
In case you still having HP Printer Issue Then Follow Us On:
HP Printer Support
Feb 12, 2014 | HP DeskJet 1220c InkJet Printer
How to set up wireless printer on windows 7 net book
I have just bought an epson sx435 wireless printer. I have set it up on my xp desktop with usb cable. How do I set it up to be wireless on xp
and how to I set it up on my Acer Aspire one 522 netbook running windows 7.
Home > Printer Wi-Fi Setup Setting up a Printer Wi-Fi Network Using the Control Panel Using the Wi-Fi Setup Wizard with LCD panel WPS setup You can set up a Wi-Fi network for your printer by using the printer's control panel. Using the Wi-Fi Setup Wizard with LCD panel If your printer has an LCD panel, you can use the Wi-Fi Setup Wizard to simplify manual setup. mark_no.gifNote: This setting is not available for all printers or may not be enabled. Make sure that the Wi-Fi is enabled on your computer in advance. Check the SSID and password for your network as these are required during Wi-Fi setup. If you do not know the SSID and password, check with your network administrator. For step by step information on setting up a Wi-Fi connection using the Wi-Fi Setup Wizard, click the following link. This feature is not available for all printers or may not be enabled.
exlink.gif../p_body/panel/wizard/manual_01.htm
Well to start with xp look at the following.
http://support.epson-europe.com/onlineguides/en/sx430sx435w_nwg/html/index.htm
May 30, 2012 | Computers & Internet
It will not print my document, but will print test pages, from the internet and from other programs. It gives me a message that I need to install my printer (which I did again) but it says there is none...
1. Have we made sure the printer cable is connected to the computer? The cable is sold separately from the printer, generally speaking it is a USB cable. (In most cases this cable needs to be plugged in to the computer and the printer needs to be powered on when running the printer installation software)
2. Of the printer is a Wi-Fi printer you will first need to make sure that you join the printer to the same Wi-Fi network that your computer is joined to.
3. Sometimes even if you have a Wi-Fi printer the manufacturer will require you to connect the printer to the computer just the first time, it gathers information about this Wi-Fi network from the computer and then passes the information to the printer.
4. I have also noticed that in some cases steps all or some of steps 1-3 need to be completed for internet printing to work.
Nov 08, 2011 | Corel WordPerfect Office 12 Home Edition...
Unable to join network
Found this written by someone on another website - worked great for me - not a problem since - have downloaded books via Kobo website straight from the device, everything works perfectly. Thank goodness this person posted.
Go to advanced and reset the system to the mfg settings & it will power down. Turn back on, don't set the date/time & instead reset the system again a second time. At this point it may take awhile to power down and come back on but once you go thru this process, your Literati will update w/ the latest software and work. I followed these instructions and works great now no problems at all.
Dec 27, 2010 | Sharper Image Literati Reader 16375680042...
I can't get it to print wirelessly with my airport express. What do I do? Does Canon Smartbase mp360 not print wirelessly?
You have to setup this printer as a Network printer, the PC using it, must Browse for the PC on the network. Setting up a wireless printer is not a complicated matter to accomplish. It can take as short as five steps to get the whole thing done.
Step #1: The Location of the Wireless Printer.
Since more than one computer would be making use of the wireless printer. It makes sense to figure out the best place to put it. The wireless printer should be set up at a place at home or in the office that is accessible to everyone and where there is ample space for paper, printer ink and other such paraphernalia.
Step #2: Bluetooth or Wi-Fi?
There are two connectivity choices when it comes to setting up a wireless printer, and these two choices are none other than Bluetooth or Wi-Fi. Most new computers and printers nowadays are equipped with either Bluetooth or Wi-Fi capacities, but if not, it is easy to get a wireless card that can be plugged using a USB port. The only difference is that Bluetooth printers has a smaller range than Wi-Fi.
Step #3: Enable Printer Sharing
The server computer’s operating system must be informed that the printer that will be added to its network is a wireless printer. In Windows Vista, this is done by accessing the network settings in the Control Panel and then activating file and printer sharing in the local area network settings.
Step #4: Share the Printer.
The other computers on the network must also be set up for using the wireless printer. To do this in Windows Vista, open the Control Panel in the classic view and then open Printers. Right click on the printer that is going to be shared, and then open Properties. In Properties, check the box that allows the printer to be a shared device.
Step #5: Continuous Troubleshooting
Wireless networks are prone to interruptions, and so it is important for whoever it is that is maintaining the wireless network at home or at the office to keep the connections to the wireless printer active. Nothing is more irritating that setting up a wireless printer and then encountering numerous glitches afterwards.
Mar 05, 2010 | Canon SmartBase MP360 All-In-One InkJet...
My Iphone wifi button is grey out
Resolution First, sync your iPhone or iPod touch to iTunes to backup your user information, Contacts, Calendar, and other data. Then try the following steps in order.
One On the device, tap Settings > General > Reset > Reset Network Settings. Check to see if the device now displays the Wi-Fi address or Bluetooth address (tap Settings > General > About and scroll down to Wi-Fi Address or Bluetooth). If there is a Wi-Fi address and a Bluetooh address, then you're done with these steps and you can resync your settings and your media using iTunes.
If there's still no Wi-Fi address or Bluetooth address, then continue to step two.
Two On the device, tap Settings > General > Reset > Erase All Content and Settings. Check to see if the device now displays the Wi-Fi address and Bluetooth address (tap Settings > General > About and scroll down to Wi-Fi Address or Bluetooth). If there is a Wi-Fi address and Bluetooth address, then you're done with these steps and can resync your settings and your media using iTunes.
If there's still no Wi-Fi dddress or Bluetooth address, then continue to step three.
Three
  1. Restore the iPhone or iPod touch software (this erases all data on the device) using iTunes (see article 305744 for additional assistance).
  2. After the restore is complete, sync your previous settings (mail settings, text messages, notes, call history, contact favorites, and so on).
  3. Now see if your device shows a Wi-Fi address and Bluetooth address (tap Settings > General > About and scroll down to Wi-Fi Address or Bluetooth).
If there is a Wi-Fi address and Bluetooth address, then you're done with these steps. If there is no Wi-Fi address or Bluetooth address, then continue to step four.
Four If there is no Wi-Fi address or Bluetooth address listed after doing the above steps, then your iPhone or iPod touch may need to be repaired. See the iPhone Service FAQ or iPod Service FAQ for additional service information.
Nov 08, 2009 | Apple Computers & Internet
241 people viewed this question
jasbo
jasbo
