Question about Refrigerators
My GE refrigerator GE GSL25JFPABS stopped cooling on both the frig and freezer sides. I pulled it out, took off the panel and cleaned around the fan. I plugged it in and it worked perfectly for just less than two weeks, then it started warming up again. I unplugged it and let it sit for about 8 hours. It worked perfectly after that. I bought a thermometer, frig about 30 and freezer about 0. Again, just short of two weeds it starts warming up. It's 7 years old. Any help will be appreciated.
  • 122 Answers
You may have a defrost problem, check for frost in freezer, back wall, or pull off rear panel and check evaporator, it should have some frost on coils, if frozen all around evaporator, check glass element at bottom of evaporator, should have blue and pink wire going to element
Posted on Aug 22, 2010
I have a GE side by side Model No. GSS25JFMCWW. The refrigerator side is not staying cold. When I remove the back panel in the freezer there is heavy frost build up on the coils. If i thaw out the coils...
the ice disp stopped working now the unit will try to start then stop over and over, went to main board on back of frig. took off jumper one connector it stopped but not sure what jumper one controls
Oct 26, 2010 | GE GSS25JFM Side by Side Refrigerator
My refrigerator stopped cooling and my freezer stopped freezing but the freezer is still cooling
Same thing with our GE Eterna Series - off and on for the last two weeks. Took back panel off, looked around, vacuumed dust build up off of the fan blades, etc.; everything worked fine for five good days. Then frig went out stopped cooling. Off and on for the last week. Unplugging it works for a day then back to not freezing and or colling.
Jul 17, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
GE model gsl25jfpabs, freezer is cool like refrigorator, but won't freeze....
Look for frost on freezer back wall.
dirty condenser, condenser motor not running
bad compressor
Mar 03, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
My frig is running but not cooling - frig is 50 degrees,freezer 40 degrees, cleaned the coils,etc GE side by side coils in bottom if frig side feel cool, "box" between freezer and frig side is not blowing...
I can help you diagnose the problems with your GE. Several things can cause these symptoms. All you need is a voltage meter patience and a want to, to repair and do it better than a paid technician. In most cases with the PSS26MSRSS the defrost heater is the cause for this. Look into rear of your freezer and back wall. Is Ice or frost building on rear wall? If yes unplug and prepair to remove contents in freezer compartment. Remove rear panel in freezer and use hair dryer to defrost ice until the defrost heater is visible. BRB , Sea Breeze
Jan 23, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a Kenmore Cold Spot fridge, freezer on top. Fridge is warm, and freezer keeps freezing up on sides and bottom. I cleaned it all out, defrosted it, and it still freezes up and fridge still won't get...
Is this a self defrost model? Frost inside the freezer could be an air leak around the door gasket. Remove the back panel in the freezer and completely defrost the coils. Is the fan running in the freezer. That will make the frig not be cool. With the door closed peek in the gasket to make sure the light is shutting off, this will warm a frig also.
Eric
Jun 20, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Freeze will not freeze.
I had a similar problem. The frost in the back is an indication that your coils are frozen. This could be from food packages falling out of the freezer drawers in the back and blocking the air circulation vents or maybe the freezer door was not closed completely and letting moist/humid air in and freezing the coils.
For me it was the first problem listed.I had to completely empty the freezer and Frig. and take the back panel off in the freezer. There you will see the coils and lots of ice!
1. Remove all items from the frig. and freezer and unplug frig.
2. Pull all the freezer drawers out.
3. On my GE side by side I took the light cover off and removed the bulb. There you will see two panel screws. Remove the screws.
4. Now pull out the mouldings on each side and you should be able to remove the panel.
5. Take a hair drier and completely defrost all the ice from the coils.
Be sure to keep plenty of towels handy for all the water mess. Remember to keep an eye on the drain tray in the back of the frig. and use a sponge to collect the water that will build up.
Hope this helps!.....
Woody
Mar 29, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
FRESH FOOD SIDE OF FRIG NOT COOLING
i would take the back freezer panel off and see what kind of frost pattern your coils have.they may be frosted over and the begining of a defrost problem.
Mar 11, 2009 | GE GSH22KGM Side by Side Refrigerator
GE side by side by side,water drips from bottom freezer door
I have the same problem. Just talked to a friend that's a great appliance repairman. he said I have to remove the panel in the back inside of freezer and there is a drain that gets clogged up, a little hole or tube.
clean that and should work fine and stop leaking. I haven't had time yet, but this weekend I'll do the deed. Hopes this helps ya!
Jan 28, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE ADORA Refrgerator :
The water line from the house to the frig works, however the water in the frig just stop working one day. Any suggestions?
Feb 09, 2008 | GE Profile PSW26P Stainless Steel Side by...
Refrigerators Logo
306 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
