Question about IBM ThinkPad R52: R52 P M 760(2.0GHz), 512MB RAM, 80GB 4200rpm HDD, 15in 1400x1050 LCD, 64MB ATI Rad... (THINKPADR52R52PM76) PC Notebook
I replaced my original IBM hard drive with a Western Digital hard drive and there is a compatibility error at boot .. how can this be corrected
  • Ekse Aug 22, 2010
    could you clarify what do you mean with Compatibility error? have you reinstalled windows to the computer yet?
4 Suggested Answers
DJGray
  • 56 Answers
SOURCE: can't boot and forgot bios password on ibm r50e
Yikes. You've set a password on the BIOS and don't remember it?
Well, most manufacturers set a "backdoor" password on the bios that will allow you to get in. It used to be the backdoor PW for IBM was "merlin" but that may no longer be the case. If you absolutely cannot get in, then your option is to open the case to the laptop and disconnect the CMOS battery for about 15 seconds and then reconnect it. That will clear the CMOS to the factory defaults.
I wish you well with this.
Thanks for using FixYa!!
Posted on Mar 06, 2009
  • 18 Answers
SOURCE: IBM r52 thinkpad laptop hdd compatibility issue
Download Hiren CD .. format the hDD and install the OS Freashly
Posted on Mar 31, 2009
digitalhubz
  • 109 Answers
SOURCE: I bought a new Western Digital PATA 320gb notebook
Take a look at this image, read the Had drive manual on how to set the jumper, Try cable select jumper settings, if not work, try the master settings, if not try the slave settings, one of the settings must go on and works fine.
Here where you can find the jumper settings,
Posted on Oct 21, 2009
I tried installing windows server 2008 on my Ibm x236. after the installation completes when the system reboots I'm getting error msg. file: \windows\system 32\drivers\wdf01000.sys
that is a Western Digital driver file......for your hard drives likely.
If you are using RAID, then make sure that the RAID is the correct one, and if not, then make sure in the BIOS, you have NOT selected a RAID option.
If those do not seem to be at issue, then attempt to boot in Safe Mode with Networking. That error has been known to have other driver(s) unrelated to the WD driver.
Nov 04, 2014 | IBM X236 Server
000 wd5000c035
Yes, this model is certainly compatible with Windows 7.
If you've lost the AC adapter and need to replace it, the most important things to look at are:
1) the size of the plug
2) the input voltage of the drive
3) the minimum current in Amperes (A) or milliAmperes (mA) required
For units manufactured after June 1st 2008, these are the requirements:
12 Volts
1.5 Amps
18 Watts
Western Digital recommends only using original WD power adapters.
See here for more information: https://wdc.custhelp.com/app/answers/detail/a_id/1378/related/1/session/L2F2LzEvdGltZS8xMzg3MTQwNTQxL3NpZC9aNG1NbVZIbA%3D%3D
Tip: sometimes you can find a cheap and original power adapter on eBay or Craigslist or Kijiji.
Dec 13, 2013 | Western Digital Elements powered by WD 320...
My WD3200B007 won't boot. Power light is on, as are the neon colour bars, but no response from the drive itself.
I strongly suggest you purchase a Hitachi hard drive, I have replaced several WD's due to the problem you have. I have never had an IBM/Hitachi hard drive fail and I have used dozens of them over the last 15 years in new builds as well as repairs.
Oct 20, 2013 | Western Digital Computers & Internet
Western Digital WD800JB internal hard drive. I install it, it is listed in device manager, but not on "My Computer". I have unistalled the device and drivers (IDE primary & secondary),...
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to boot
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
Dec 11, 2010 | Western Digital Caviar SE WD800JB 80 GB...
My hardisk 1tb only shows 500gb space, just bough it yessterday and i have installed it in port 0 and an other hardisk off 500 gb was installed on port 1 and when i go into my computer i only see both...
If you're using the original XP version it wasn't able to format the correct size of the hard drives. You need to find a version with Service Pack 2 and boot off that CD in order to format the correct size of the drives. You could also boot off a Vista installation CD and format the correct size.
Oct 01, 2009 | Western Digital 500GB My Book Pro-External...
Western Digital Reset / Set Hard Disk Size ?
hit F1 when you bootup dont let windows come on . Go in you Biso to set you new hard drive.dont forget to F10 to save changes...Good Luck
Aug 15, 2009 | Western Digital 500GB My Book World...
BIOS self-set Password after upgrade/HD Install
http://sodoityourself.com/hacking-ibm-thinkpad-bios-password/
try this if you can do  but i am not sure.  i am good on electronic things but its hard to do that. its only way.
May 28, 2009 | IBM ThinkPad T43 Notebook
320 GIG Hard Drive now thinks it is an 80 GIG hard drive
Enter your BIOS setup and check what the BIOS sees for hard-drive. It may not be assessing the drive size correctly so you may have to force it by manually entering the data it needs to see the drive.
May 23, 2009 | Western Digital (WD3200JS) 320 GB Hard...
Ibm t43, xp pro won't recognize my WD my book
please write down the error and contact me now
anaesarora online
Feb 06, 2009 | Western Digital (WD3200JS) 320 GB Hard...
Computers & Internet Logo
163 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
