SOURCE: Keurig home model #B77 Will only brew half of
If you can also see there are a lot of inquiries about the same or similar problem. We have already investigate the matter and it is a design problem from Keurig and it not any much that you can do,
We have a tip at the link that it explains it some more
http://www.fixya.com/support/r5543433-keuring_coffee_maker_b60_b70
Moreover you can contact the keurig customer service which we here that they are more than happy to help you and in many cases they have replace the machines with no further question, you can try also since you are a customer with rights.
Good luck
SOURCE: I am boxing up my Keurig select b77 to move.how do
You cannot without fooling the "water out" sensor... to do that you need to make sure the float is up... and even then... you really would have to take the bottom metal pan off... and remove the plastic hose from the bottom of the heater... you will NOT get 100% of the water out... so if you need to ship... you also should stuff paper towel where the K-CUP holder is... snap out the kcup holder and stuff paper tower in there...as there is water in the plastic hose lines in the unit... enough to make a mess...
SOURCE: Keurig coffee machine model B77 coffee maker will
Mine will not either. Yesterday it worked just fine now it's as if it is not plugged in. I checked the outlet, it's not that.
