Question about Garden
Just got a 705 miter saw from son who is moving. No manual and I can't seem to find one. Where do I look? Thinks
  • 2,019 Answers
The DeWalt 705 miter saw is discontinued, but maybe this one will do:
http://powertool.manualsonline.com/manuals/mfg/dewalt/36255.html
Posted on Aug 22, 2010
Skil Compound Miter Saw laser quit working, Help
SKIL 10" Compound Miter Saw 3317-01
www.skiltools.com/Tools/Pages/ProductDetail.aspx?model=3317-01 Skil10 In. Compound Miter Saw with Quick Mount System and Laser Cutline. Model #3317-01 ... manual Get Manual (PDF); parts list Get Parts List (PDF) ...
[PDF]Operator's Manual 10 in. COMPOUND MITER SAW WITH ...
c.shld.net/assets/own/00921236e.pdf
Dec 14, 2015 | Skil Saws
Dewalt DW 705 Type 1 Hard to pull down to cut material
Go to www.2helpu.com that is the dewalt site. You might have to change the link arm that moves the guard up. They get bent over time. Check other parts on the raise and lower assy for wear at the same time.
Dec 04, 2012 | Dewalt DW715 Heavy Duty 12" Single -...
My LS1216 slide compound miter saws mitering table is stuck at 0 degrees it appears jammed although I've looked for something jammed stopping the plate from moving and see nothing, the handle locking...
Hello stella....... There is a locking mechanism on the miter saw to lock it on whatever setting you require. loosen that locking mechanism and the saw should move for you. Here is a schematic of the parts so you can see exactly which parts are involved
http://www.searspartsdirect.com/partsdirect/part-model/Makita-Parts/Saw-Parts/Model-LS1220/1339/0744300/P8100100/00002?blt=06&prst=&shdMod=
Joe
Thanks for choosing Fixya!
Feb 06, 2011 | Makita 10" Dual Bevel Sliding Compound...
Will not cut 45 miter cuts perfect
Possible but I would think not likely
Try this
Put a new blade on
Set a magnet on the table or fence with phillips screw driver stuck to it
Slide the point of the screw driver up to within 1/16" from the blade just above the teeth
Run the unplugged saw by hand and watch for any side to side movement of the blade
Can you move the blade up and down or side to side?
If everything seems normal the plug the saw in and run it again watching the screwdriver
Please be careful don't allow the screw driver to contact the blade at high speed you will create a bullet
Mar 10, 2010 | Porter Cable Cable 12" Compound Laser...
The saw do not stop when i off the trigger
the commutator might be dirty, try and turning the brushes 180 degrees and you might have to clean the commutator with a stone for that purpose to seat the brushes.
Jan 13, 2010 | Dewalt DW715 Heavy Duty 12" Single -...
DW705 Miter saw Spark in motor Compartment
Yes spark in motor compartment is normal. You only need to worry if you see a lot of sparks flying out of the motor compartment! Most power tools will spark inside the motor compartment (particularly if carbon brushes are used).
Bevel and miter could be off... Consult your manual for how to adjust these correctly, but usually the bevel has a 0-degree setting screw or adjustment, and the miter adjustment on the saw is usually done by altering the fence position... Again check your manual for specifics on your saw.
Mar 19, 2009 | Dewalt Saws
How do you adjust the angle of the miter
It should move if you unscrew the handle at the base of teh table. There is also a lever on most of these saws, under the handle. Unscrew handle, operate lever to release locking pin and move. That's the theory anyway.
Oct 24, 2008 | Makita 10" Miter Saw LS1030N
Garden Logo
77 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
