Question about Hunter Fan Company 5/1/1 Programmable Thermostat
I AM TRYING TO REPLACE A MEARS THERMOSTAT. MODEL # M402 DOUPLE POLE. 22A-120/240V
Adjust the temp. limit on my Model M402? Setting thermostat far below 55 degree mark, gives me 65 degrees.
Hello... may be you can set the desired temperature and later the remote control and/or the internal unit show to you the temperature of the air ... just let the air conditioning try to match your desired temperature...
Watch this...
https://www.youtube.com/watch?v=2Ck_xsdrmSM
Oct 29, 2014 | Heating & Cooling
Replacing double pole 220 v with honewell ct410a two wire120/140v wiring diagram not clear
1 power wire (120v) will go to the thermostat and 1 power wire (120v) will go directly to the unit. The other wire on the unit will go to the other side of the thermostat. The safety precaution behind using a single pole to replace a double pole contactor is that you will always have 1 leg of power going to the unit. Many systems are designed like this from the factory, but it is always better to have a 2 pole to cut all power off to the unit unless it's in operation. The unit will still not work as long as it does not have both legs of power.
L1 to Thermostat T1 to Unit
L2 and T2 wired together.
This is only for 240v systems. 120v Will have 1 common and 1 power, therefore you will need to know which wire is which. Power to thermostat, common wired direct.
Nov 26, 2013 | Honeywell Programmable Thermostat Heater
Changing double pole thermostat to 2 wire 240 volts
Wire nut one leg (the 2 wires of the first pole), & use the thermostat to complete the circuit (the 2 wires of the second pole).
Burning up tips fast with Miller S-22A
tooslow and probaly too close to work piece try turning heat down a little also make shure you have a good ground/ maybe angle your gun a little more
Dec 17, 2012 | Miller Welding Tools
2001 pontiac grand am se will not strt after replacing the fuel pump
Douple check that you're plugged in correctly. Also did you replace a wiring kit when you changed the pump. When you first turn the key on , dont't try to start abnd listen for the pump. Do this 4 times before trying to start, as this will prime the system. If still no start. get a gauge and make sure you have 45-50 psi at the fuel rail.
Jan 20, 2010 | 2001 Pontiac Grand Am SE
I have a Dimplex in wall heater model 690221900 120 volt 1500 watt. Their is a 110 volt feed line (black, white and ground wire)coming in to the heater housing as well their is a two wire thermostat...
Well, for your wiring, there's nothing wrong with it, So, I think there's two way to find out which ones is wrong, first:
Install your heater without thermostat first, is it working, does the breaker blowing!!!.
If No, then your thermostat is the cause, but if Yes, then,
second:
Try install it with the new breaker with 10 A minimum, you must replace the breaker with new ones.When it's OK, then try install the thermostat too.
Hope it works!!!
Dec 09, 2009 | Sewing Machines
M402 didnt receive the gps signal transmitted by garmin 72 via nmea 2.0
Check the wiring again. Installing my M422 needed to switch the polarity of the NEMA input from my GPS75. May be similar problem
Oct 23, 2009 | ICOM Informatique Icom IC-M402 VHF Marine...
Jamming and staying open
try this. Give it a real good cleaning inside the action area and maybe switch brands of ammo.
Aug 18, 2009 | Sport & Outdoor - Others
Hunter Fan Company 5/1/1 Programmable Thermostat Logo
401 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Brandon Berry
Brandon Berry
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
