Question about Kitchen Ranges
My rational oven makes a buzzing sound for 20 seconds then stops for 1 minute and then starts again. i cannot find any information in the manual. what is this constant buzzing nosie
  • 146 Answers
SOURCE: Oven not working -makes a buzzing sound when turned OFF!
You just need to adjust your door latch assm. Try putting a little oil on the latch and arm. The sound you hear is the solenoid trying to pull the latch arm all the way back to lock the door. Even though it is pulling the arm back and the door locks it may not be all the way back. A little lubrication will fix the problem.
Posted on Dec 21, 2007
KevinWhite
  • 1902 Answers
SOURCE: Our Hot Point model RB787
Hello & Welcome to FixYa
This means open/shorted oven temperature sensor and to solve this problem the sensor needs replacement. If you want to do it yourself and wan to be sure before replacing the sensor then you can test it with a voltmeter between 1080-1120ohms....if it reads more then or less then this then it needs replacement however, if the reading is around between 1080-1120ohms then it is the control board that needs replacement. Please get back to me if you have any other questions.
Kevin
Posted on Apr 21, 2011
SOURCE: jenn-air jes9800AAB keeps buzzzing, front function panel flashes on and off
Your control panel is getting ready to quit. Mine did the same thing, I ignored it and now nothing on the touch panel works. About $150.00 for the part.
Posted on May 30, 2008
  • 116 Answers
SOURCE: I have 2 problems. The
The first problem - I am not sure this is a problem - it is normal for ovens during cooking to cycling on or off several times. Is this something you notice recently or this is the first time you have ever noticed this.
The second - this may be happenning because the microswitch at the knob may be deffective (constantly on) check this and the wiring harness to make sure nothing is shorting out
Regards
Posted on Oct 01, 2008
SOURCE: hi. The oven won't stay hot after 20 minutes.
yahoo messenger is not working in the first
Posted on Jan 24, 2010
RE: Samsung microwave SMH7187STG mfg'd 5/08. I heated cup of tea 2 min.Then I closed micro's door & micro emitted a continuous electrical buzzing sound.I opened door & buzzing stopped.
The cook relay on your control board is shorted, and the unit is cooking whenever you close the door.
When the magnetron overheats, its thermostat opens, shutting power down until the unit cools to a safe level, then power is restored.
I regularly repair these with my $54.95 service, which includes insured return shipping.
Details are here, or for full information and instructions, please e-mail me here at pupista@gmail.com and remind me of your full model number and symptoms.
Dec 20, 2016 | Samsung Microwave Ovens
When microwave is started, why does it make a loud buzzing sound--like a Skil saw sounds?
Whirlpool Microwave Buzzing Loudly - ApplianceBlog
www.applianceblog.com/.../26531-Whirlpool-Microwave-Buzzing-Loud...
Aug 12, 2011 - 10 posts - ‎2 authors
My Whirlpool MT4155SPS-2 microwave oven has recently started to buzz loudlywhen operated. The sound is getting louder and more frequent ...
Whirlpool making intermittent loud buzzing noise Microwave ...
www.fixya.com > ... > Microwave Ovens
Whirlpool microwave ovens making intermittent loud buzzing noise related questions and answers. Ask your ... ...loud buzzing noise and it doesn't heat. i just tried it again and let it run for 1 minute. ... Question about Accuwave Microwave Oven.
Troubleshooting the Microwave: Potential Problems ...
www.appliancejournal.com/.../troubleshooting-the-microwave-potential-...
If your microwave buzzes loudly and produces no heat you probably have a defective power .... I have a whirlpool oven range and it's less than a year old. .... Humming sound stops when I open door to remove food, but when door is closed, ...
Whirlpool Microwave Ovens - Consumer Affairs
Feb 03, 2016 | Whirlpool Accuwave Microwave Oven
Rational selfcook oven say service 21
Service 21 refers to your humidity control valve (climavalve) did not make a full revolution in the time allotted (about 20 seconds). Pop open the front control panel by inserting and turning a 5mm allen key into the opening on the top of the oven. While the oven is at the home screen, flip the dip switch #1 on the back of the control board to the up or on position. On the screen you should now see a new icon resembling some tools, like a wrench and screwdriver, click this icon. Go to Basic Settings and scroll to the right once until you come to Basic Settings 1.2. It should say drain valve and flap with some numbers at the bottom. F-t is the number we want to focus on, take notice of the number there, usually 18-20 seconds. Push the start button to the right of flap, this time will change to 0 while the flap is re-initializing. After 20 seconds or so a new number should come up, if it doesn't or it is over 20 seconds by a lot then you need to replace your humidity control valve.
Additionally every time you turn on your oven the climavalve will cycle, checking to make sure it is working correctly, if you interrupt this cycle by powering off the oven you can simulate this error falsly, to rectify the error turn off the oven and turn it back on and wait a good minute for all of the self testing components to finish their checks.
Sep 23, 2012 | Microwave Ovens
Unit makes a loud buzzing sound whenever the unit has power.
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Nov 23, 2008 | GE JVM1860 Microwave Oven
Works - but the sound has changed
Possibly, the "fault" was the buzzing in the first place! Buzzing is usually a cabinet vibration caused by magnetic fields from the "gubbins". If the buzzing should occur again, try pushing/ pulling/ poking the cabinet while the oven is running, you may find a position that causes the buzz to stop.
Another possibility is you previously had something else placed in close proximity to the oven.
If a rattling cabinet is the problem, either try to reposition something, or just ignore it!
Apr 29, 2008 | Maytag MMV4205 Microwave Oven
Anoying
My mom and dad had this problem, after replacing the bulb everything is working great again.
Jan 25, 2008 | Hitachi 50VG825 50 in. LCD HDTV
Kenmore Dryer works for about 20 MINUTES, not seconds
SD, doesn't sound like the same problem. Yours sounds more the like motor kicking out on overload and when it cools down you are able to start it again. The thermal fuse and high limit TCO are non resettable so you can rule them out. You are going to have to check some things out. Make sure the rollers and pulley are not binding. The blower wheel is not binding. These things will cause a drag on the drum and put a heavy load on the motor. Catriver...post back
Feb 12, 2007 | Kenmore 64902 Electric Dryer
Kitchen Ranges Logo
189 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
