Question about Remington R5130
I am replacing blades for remington r5130. i removed the middle screw. plastic bracket doesn't want to come out. Is there a trick to remove the bracket to replace the heads?
  • Remington Master
  • 1,610 Answers
You do NOT need to remove the screw. The blades and comes are removed from the top so it is not necessary to take anything out from the underside.
Instructions should be included on the back of the pckage that the replacement heads came in. You can view the instructions at the link below
http://shaveroutlet.com/media/catalog/product/cache/1/image/5e06319eda06f020e43594a9c230972d/f/i/file_36_1.jpg
Posted on Aug 22, 2010
Battery will not charge on remington hair trimmer hc5550.
You can, but you need some experience with soldering.
Look for the other answers here in this forum, there are some descriptions on how to open the device.
In short: you have to remove the power button (be careful not to destroy it), then slide off the middle plastic part, remove a screw, then take off the upper main plastic housing, remove another two screws and take out the inner device which holds the motor and batteries.
The old batteries can be replaced by 2 AA-size eneloops.
Aug 21, 2012 | Remington Hair Trimmer Accelerator Hc5550
How do yoo remove the individuai blade assemblies for cleaning?
there is a small button side pressit and pull the blade outside 1 by 1
Mar 25, 2011 | Remington R5130
How often should i change razor blades
Remington suggests changing the blades every 12 months on model R5103. If replacements are needed, you will find at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/remington-spr-titanium-360-pivot-and-flex-replacement-heads-with-frame.html
Mar 02, 2011 | Remington R5130
Remington 5130 battery is fully charged and when you put it on it goes click. I noticed that one of the heads moves when you try ot turn it on. Removed that head on the unit works great. Put it back it...
It sounds like either the heads are packed full of hair particles and the blades can not turn OR one of the blades has been damaged and is causing it to lock up.
Try removing all of the blades and cleaning them thoroughly and also insoect the blades, particularly the one that moves when you turn it on
If replacements are required, you will find them at shaveroutlet.com. See link below
Dec 08, 2010 | Remington R5130
How do i relace the battery in a remington R5130. I cannot see how to take it apart. John
The plastic cover faceplate on the front where the on/off switch and LED indicator lights "pops" off. (you will need a sharp pen knife blade to get into the seam and start this process.) Once the faceplate is removed you will see 4 phillips-head screws that hold the two halves of the body together. Taking the body apart will reveal the two rechargeable batteries, but the bad news is that these were not designed to be replaced and are actually bonded (glued) to the control circuit board. This is a good example of engineered obsolescence the manufacturer wants their product to be disposable. I am looking for a razor that has rechargeable batteries that are also replaceable.
Nov 16, 2010 | Remington R5130
Re Remington electric shaver R5130, "User &
The outer combs must be turned first so that they can be removed. You will find instructions posted at shaveroutlet.com. See link below
Nov 13, 2010 | Remington R5130
Assembling chain to bar: r there 2 guides on either side of chain?
remove plastic side cover - three screws on outer side,one screw on inner side.remove the two guide bar bolts.remove the phillips head screw going thru black bracket in middle of sproket gear. wear protective gloves and remove chain
Sep 24, 2009 | Remington Electric Chain Saw
After two weeks use of my new Remington R5130, now one of the three heads keeps popping off during almost during every shave. Any suggestions?
My R5130 kept falling apart when I shaved. I really like Remington Shavers (Spectrum Brands) and have had good luck with them until the R5130 model.
Two points.
1.) -THEY SHIPPED ME A NEW HEAD ASSEMBLY (BUT)- The original one I got had poorly formed plastics tabs on the blade retainer (head) I Googled Remington Shavers and used their Consumer Service tab to request a fix. They sent me a new head assembly free of charge and yes it worked much better. However, it eventually the heads started falling off again.
2.) RUBBER BAND FIXED IT - I looked it over again and thought that the range of movement and forces on the assembly pieces was just more than the design could handle so I looked for a way to contain some of the movement. I slipped a single thin (1/16"x1/8") - 2" diameter rubber band around the three head assembly and the problem has been completely eliminated. I can shave normally now. The rubber band nearly disappears under the black head flanges so it doesn't even look bad. The shave is a little firmer now but it still has most of the flexibility of the original design.
This simple fix will be a hard one for Remington (Spectrum Brands) to adopt but you might help spread the word. I am sure they will avoid this problem in the next models.
Jul 08, 2009 | Remington R510 Electric Shaver
Remington R5130 Logo
599 people viewed this question
Top Remington Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Jerry Greenberg
Jerry Greenberg
Are you a Remington Health and Beauty Expert? Answer questions, earn points and help others
