What dose F1 mean when it is flashing on my whirlpool washing machine
  • 10,319 Answers
An F1 code on your Whirlpool washing machine indicates a primary control failure. The primary control is responsible for the motor control and much of the washers internal controls. To fix a Whirlpool with a code F1 requires replacing the primary control. Write down the model number of your washer when ordering the replacement primary control. Replacement are available through Sears at appliance repair centers. Since you will be working with the electronics of the washer, it is a good idea to purchase a static wrist strap to prevent shorting any wires with static electricity. Place the strap around your wrist prior to disassembling the control console.
Instructions Things You'll Need:
  • Nut driver
  • Masking tape
  • Pencil
  • Replacement primary control
  1. 1 Unplug the Whirlpool power cord from the wall outlet. Turn off the water supply to the washing machine. Pull the washer away from the wall so that you can access the screws behind the control console. Remove the hex head screws securing the control console to the washer with a nut driver. The screws are on the lower rear edge of the control console.
  2. 2 Lift the control console up, and rotate the console forward so that the face of the console is resting on the top of the washer. Locate the interface board cable connector to the right of the plastic tube on the back of the console. Pull the end of the connector straight out of the control console. The primary machine control is the box that the plastic tube connects.
  3. 3 Place small pieces of masking tape around the nine wires connecting to the primary machine console. Label the wire locations onto the masking tape with a pencil. Grasp each wire at the connector with your fingers, and pull the wires away from the primary control. Pull the plastic tube out of the primary control.
  4. 4 Locate the nut toward the bottom of the primary control. Remove the nut with a nut driver. Lift the front of the primary control slightly, and slide it down to disengage the retaining clips. Pull the primary control out of the control console. Insert the new primary control into the control console. Slide the primary control up to engage the lower clips. Secure the primary control to the console with the single hex head screw.
  5. 5 Push each of the wire connectors into their respective positions on the primary control until they lock into place. Push the plastic tube hose over the port on the right side of the primary control. Remove the small pieces of masking tape from the wires.
  6. 6 Position the control console back upright on the top of the washer. Secure the control console to the washer with the three hex head retaining screws. Slide the washer back against the wall. Turn on the water supply and plug the washer into the wall outlet.
Read more: How to Fix a Whirlpool Cabrio Washing Machine With Code F1 | eHow.com http://www.ehow.com/how_6665532_fix-washing-machine-code-f1.html#ixzz0xLDXrjBn
Posted on Aug 22, 2010
2 Suggested Answers
blueextc3221
  • 15935 Answers
SOURCE: my whirlpool cabrio washing machine keeps flashing F1?
Keypad/User Interface Failure
F then 2 flashes when in:
Diagnostics Test mode if a stuck key is detected.
Standby mode if there is a user interface mismatch.
DISPLAY (Saved Code) EXPLANATION AND RECOMMENDED PROCEDURE
Console and Indicators
This test is performed when any of the following situations occurs during the Console and Indicators Diagnostic Test:
None of the indicators light up No beep sound is heard Some buttons do not light indicators None of the indicators light up:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P11 connector is inserted all the way into the machine/motor control.
2. Visually check that the user interface assembly is properly inserted in the console assembly
3. If both visual checks pass, replace the user interface assembly.
4. Plug in washer or reconnect power.
5. Activate the Console and Indicators Diagnostic Test mode to verify repair.
6. If indicators still do not light, the machine/ motor control has failed: Unplug washer or disconnect power. Replace the machine/motor control assembly.
Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
No beep sound is heard:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P5 connector is inserted all the way into the machine/motor control. If visual check passes, replace the user interface assembly.
2. Plug in washer or reconnect power.
3. Activate the Console and Indicators Diagnostic Test mode to verify repair.
4. If replacing the user interface assembly failed: Unplug washer or disconnect power. Replace the machine/motor control assembly. Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
Some buttons do not light indicators:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the console electronics and housing assembly is properly inserted
into the front console. If visual check passes, replace the user interface assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.#$%^
Posted on Sep 20, 2010
What dose a FL code mean on whirlpool cabrio platinum
I will try and help for some reason Whirlpool likes to flip letters around which differ from the service manual FL would be an LF long fill or is it a F1 the model doesn't show in the Whirlpool data base nor parts suppliers I suspect wtw6600sb1 does the machine from initial start fill correctly then wash if so we can eliminate the pressure switch and hose after wash cycle unit should drain then fill with rinse water if the inlet valve does not let water into the machine to satisfy the pressure switch the control times out and flashes a long fill code this unit has a log valve system possible you have a bad inlet valve on the bank of valve or a bad control not outputing voltage to the valve, hope this points you in the right direction
Jan 14, 2014 | Whirlpool Cabrio WTW6600SBT Top Load...
What's code F1?
It Means: Primary Control Failure F then 1 flashes when there is a primary control failure. Replace the machine control assembly.
See Accessing & Removing the Electronic Assemblies.
Jan 23, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
F1 signal what is the meaning
Pressure Signal Out-of-Range
F then 1 flashes when the control detects an out of range pressure signal.
* Check pressure hose connection from tub to machine/motor control. Is hose pinched or kinked?
* If F then 1 repeats numerous times after POWER is pressed and the pressure hose connection is not pinched or kinked, replace the machine/motor control.
Whirlpool Cabrio F1 error code - NOW A RECALL ISSUE! model # WTW6600SW2 Call Whirlpool or a repair center. The number for Whiripool is 1-800-253-1301
Hope helps.
Jul 12, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
What does the flashing F1 mean?
Hello & Welcome to FixYa
F1 error in your whirlpool cabrio indicates bad control and should be replaced to resolve the error code. However, you can contact Whirlpool as well prior to replacing the control yourself as I have seen whirlpool paying for the parts themselves just because this is known to be a common issue. Please get back to me if you have any other questions.
Kevin
May 29, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
What dose f1 code mean on cabrio washer
F1 usually means a communication or an electrical error.
Unpgug the machine for 1 minute and then power back up. If fault reoccurrs check all connectors.
How long have you had this machine? Has it always been plugged into the same outlet? Is is sharing an outlets with another device?
Dec 30, 2010 | Whirlpool Washing Machines
I have a Whirlpool Cabrio top load washer. When I load the clothes and start the washer and it begins to run I hear an alarm, it stops and a F1 flashes on the display. What does this mean?
F1 (F60-68)
F1 flashing on the display indicates a primary control failure.
"F then 1 flashes when there is a primary control failure. Replace the machine control assembly."
The link below lists Cabrio failre codes.
http://www.advantagesupplyfl.com/WhirlpoolCabrioWasherFaultCodes.html
Dec 16, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
What does f1 mean and can it be fixed?
F1 means Primary Control Failure.F then 1 flashes when there is a
primary control failure.Replace the machine control assembly and
see accessing and removing the Electronic Assemblies.
Apr 10, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
F1 fault is flashing and machine is stoping
Code F1 means the central electrical control unit, i.e. the onboard computer, has fatally failed
Widespread problem, lots of machines have had this issue. I think there is a recall on this machine. Check it out-
Whirlpool Cust Svc. 1-866-698-2538 Have the model & serial off the back handy
Dec 29, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
F1 code whirlpool
whirlpool F1 code - Appliance Repair Forum THERE IS A RECALL ON YOUR WASHER,CALL THE FACTORY AND GET IT FIXED FOR FREE
Dec 11, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Hotpoint ultima
F1 means short circuit motor triac.
You need to call an engineer.
Oct 26, 2008 | Hotpoint Ultima WF860 Front Load Washer
Washing Machines Logo
18 people viewed this question
Top Washing Machines Experts
