Question about Singer 5050 Mechanical Sewing Machine
My machine hasn't been used much lately. It now seems to be overheating & the hand wheel is very tight. After a few minutes of sewing the speed slows down to a crawl. I have taken it aprt & oiled it. This hasn't seem to help. I live in rural Princeton, MN & don't know where to find a tech. near me.
    Genius:
  • 1,788 Answers
Go to www.singerco.com and ask customer service, sounds like you have thread holding it up,
Posted on Aug 24, 2010
Hand piece is very tight to turn and unable to use the machine
Make sure to clean/remove all the lint, thread, dust, etc. that may have built up in the bobbin area, around the feed dogs, and under the needle plate. Sometimes gunk build-up will prevent the hand wheel from turning. Remove the bobbin & bobbin case from the machine and the needle and see if the hand wheel will turn. If not, then it may be time for service.
My hand wheel is hard to move and will not make complete turn unless...
https://answers.yahoo.com/question/index?qid=20100518074139AAeeykz
Help My Needle Hand Wheel are Stuck Sewing Machine Jammed
Apr 20, 2016 | Sewing Machines
Hand wheel will only turn a quarter turn and needle barely moves even though smaller hand wheel is tight.
If this is an older mechanical machine (ie, NOT computerized), sounds like it has not been cleaned and oiled in quite some time and the old oil has solidified. DO THIS ONLY IF IT IS A MECHANICAL MACHINE! Consult your owner's manual, get some good quality sewing machine oil (not your grandmother's oil tin, 3-in-1 oil, WD-40, or cooking oil). Start with 1-2 drops of oil each place as directed by the manual. Gently hand-rotate the wheel (do not try to run the motor until the internal mechanics of the machine are moving freely!). To speed things up, direct heated air from a handheld hairdryer into the interior mechanism. You may need to repeat the process every day for a few days before things loosen.
The machine should be oiled every 8 hours of constant sewing, every time a new bobbin is installed, before its use after it has not been used recently, or at least every 6 months if it is in storage.
Sep 16, 2015 | Sewing Machines
My kenmore model 1318 just "locked up"; was sewing just great & all of a sudden, nothing
it's possible that a part has broken and the motor also could have went out,, it would be a good to have the machine checked
Dec 21, 2014 | Kenmore Sewing Machines
Sewing machine slows to a stop.
When was the last time you oiled it?
Sewing machines need regular oiling as you use them - it sounds like you have or are close to seizing the bearings.
In future, when you smell burning and a machine that should operate at full speed slows down - stop, don't persist in using it.
It clearly has something wrong with it.
Your users manual should cover oiling the machine - there are predetermined points at which you drop the sewing machine or 3-in-1 oil into. Only a few drops are necessary, but you should oil it every few hours of use.
Jan 11, 2014 | Omega 6147 Sewing Machine
Why is the hand wheel of my new consew 206rb-5 so tight? the machines hums when sewing, like beeind forced, is this part of the breaking in?
contact the one you bought the machine from & tell them how
tight the hand wheel is & see what they recommend
Jun 04, 2012 | Consew Sewing Machines
Hand wheel & needle do not move
it's possible that something has come loose or broken on the inside of the machine.
the name & model number of the machine is not shown, if the machine is mechanical it probably has a handwheel clutch,, make sure the smaller inner knob is tight. then try to sew again
if you still can't sew then I suggest you have the machine checked, because it's not reponding like it should
Apr 01, 2012 | Sewing Machines
Brother SE400 Hand wheel is very tight and the needle will not go down
if the machine is brand new then it needs to go back & get another one
Mar 27, 2012 | Brother SE400 Computerized Sewing Machine
Hi i have a brother 3600 machine. the hand wheel
it could be a jam or broken gear & need to be serviced
Nov 03, 2010 | Brother XL3750 Mechanical Sewing Machine
Hand wheel won't turn and machine won't work
  • Sewing machine has been run at a low speed for an extended period of time.
  • To prevent overheating, motor power is automatically turned off.
Turn power off and wait about 20 minutes. Safety device will reset, and machine will be ready to operate, If this by chance doesn't work, Here is a diagram of a typical sewing machine. This fuse should be in the back next to the power box or motor564d4f7.gif
Jan 18, 2009 | Sewing Machines
Singer 5050 Mechanical Sewing Machine Logo
88 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Level 1 Expert
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
