Question about Sony KP-51WS500 51" Rear Projection Television
TV turns on then off
I have a sony KP-51WS500 2002 model when i turn it on it stays on for about 30 seconds then the screen turns green then turns off
  • kvmkd Aug 07, 2008
    I have has trace lines for about a year now, the scrn has recently went all green and is going into standby mode every 30 secs or so. Are all of these problems related? I read on how to adjust the POT - in the front o fthe set under the grill for the trace lines, where are the tubes located & accessed from?
  • alfredwenzl May 11, 2010
    what did you do to fix it?
  • Sony Master
  • 8,617 Answers
The green crt is most likely shorted. thats fairly common with that chassis.
Posted on May 04, 2008
My sony kp-51ws510 color rear video projector tv when i turn it on it stays on for abt five seconds and then turns off and also the timer and standby light is flashing red
this model did have problems with bad picture tubes---screen goes bright red,green,blue and set shuts down.
set also does this to protect itself---when fails look to see if specific sequence of blinks
Apr 17, 2012 | Televison & Video
My sony kp-51ws500 tv screen would turn green and stay on for about 30 sec, then trun off. I adjusted the green screen button on the black box in the front of the tv....via info from this site. It fix the...
Doing the adjustment is not actually a fix, all that does is change the drive amount of the green CRT which allows the set to work but the 3 CRts will be out of balance so picture color will be affected. The only way to repair a bad CRT is to replace the CRT itself. You can get replacement Green CRT from www.tvrepairworld.com
Jul 30, 2011 | Sony KP-51WS500 51" Rear Projection...
Sony KP-51WS500: This TV comes on for a few seconds of picture and sound. Then the picture fades to green and then turns off within another 10 seconds. Is this a power supply problem? Or should I look in...
Adjust the Green screen drive,turn it down and see if that corrects the problem.
Remove the Front Bottom Panel on front of Tv and behind it will be the Screen/Focus Control block
It will have 3 controls on Top for Focus to each Tube R/G/B
and under them are the Screen drive controls for R/G/B.
But if adjusting the Green Screen Drive Control does not Fiox It ,then you have a Bad Green Tube.
Jul 03, 2011 | Sony KP-51WS510 51" Rear Projection...
Screen turns red then shuts off
Sounds like a bad red projection tube, disconnect red tube socket and try again if tv stays on reconnect tube soket and adjust screen controls on front of tv under the front panel which you will have to remove to do any of this. There are six adjustment controls 3 are for focus for each color and 3 screen controls for each color. Look close at the black plastic control module should be labled R G B for focus and R G B for screens. Good Luck!
Mike
Apr 14, 2010 | Sony KP-51WS500 51" Rear Projection...
Turns off after 30 seconds
i think the convergence amps are weak, or the akb circut has caused the tubes to go bad, google your model number to see if it is in the tube problem. sony made some projos w/ bad tubes in them. tv lasts only three or four years,no cause i had one
Jul 10, 2009 | Sony KP-65WS500 65" Rear Projection...
Green flashes then tv turns off
or a new lamp. you could first replace the lamp.
the screen might work fine for a couple of seconds, but then it fades away or deteriorates. This means the lamp is going bad.
Aug 23, 2008 | Sony KP-51HW40 51" Rear Projection...
Sony kp-57ws500 green screen then auto shutoff
I have the same tv and it did the same thing only now it has red hues all around the picture as well. The service guy told me it was the green tube and it would be about $500.00 to replace and may not fix the problem. What a p.o.s. I will not be guilty of buying any other Sony products from now on.
Jul 20, 2008 | Sony KP-57WS500 57" Rear Projection...
Orange screen...shuts off after 3-5 seconds
I will tell you in a week... I just dropped mine off to a repair guy. Mine is doing the same thing... probably not the same model though.
Jan 02, 2008 | Sony KP-51WS500 51" Rear Projection...
Sony KP-51WS500 51" Rear Projection Television Logo
232 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
