Question about Garmin Forerunner 305 GPS Receiver
My Garmin 305 will not turn on. Battery will not charge nor indicate anything on screen. Will a replacement battery correct this problem? Where can I get it repaired near zip #23502?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 81 Answers
Probably it's not linked to battery. Try resetting device (see on garmin support how to do holding mode&reset buttons).
Myself I can restart it if applying this, but it restarts only once, always same procedure needed to make it start.
Posted on Aug 23, 2010
  • BigMarkyMark Aug 06, 2011
    Mine too. After 'reset' it's a one shot deal. And it's not talking to the software on my pc. Very frustrating!
Garmin 305 will not power on. When connected to charger screen says "battery charging complete" but will not power on. Advice?
two things... go to www.garmin.com and see if your gps qualifies for the battery recall. and second try powering it on when the power cord is hooked up rather then just on battery. then try it without the power cord
May 14, 2011 | Garmin Forerunner 305 GPS Receiver
Garmin Forerunner 305 won't turn on and won't charge. Is there a fix or is this it for the device?
Look at
"http://www.activesplit.com/my-garmin-forerunner-305-doesnt-power-on-its-just-dead-solutions/"
You can soft reset or hard reset the device. Hard reset deletes all data.
Apr 01, 2010 | Garmin Forerunner 305 GPS Receiver
Garmin only turns on when its on the cradle charging. ONce I remove it, the screen is blank and nothing happens. Is it the battery or connection inside?
Probably the battery. My battery lasts all of 20 seconds since i almost always have it plugged into car charger i guess i killed battery
Mar 15, 2010 | Garmin Forerunner 305 GPS Receiver
GPS unit won't charge when placed on cradle and plugged in wall
You may have to replace your battery, these go faulty often, even though they seem OK.
Feb 07, 2010 | Garmin Forerunner 305 GPS Receiver
Hi All, I replaced the battery of my Garmin with an iPod battery. When I place the watch on the charging station the watch displays "charging" for 3-4 seconds but then displays "Charging process...
Since you used an Ipod battery instead of a Garmin compatible one, I would guess to say that it is not quite compatible. Even within the Ipod family, notwithstanding the physical limitations, the battery are not usually compatible because of variations some of which I would describe below:
- Battery has two wire and the regulator is on the device itself.
- Battery has two wires and has an inbuilt regulator (small circuit board fitted to the battery).
- Battery has three wires of which one is used by the device to control the charging
- Battery has three wires and inbuilt regulator (small circuit board fitted to the battery) of which one is used by the device as status indicator.
Hope it helps you do your own diagnostics but be very careful especially if the rechargeable Lithium battery is bulging as they do explode when not charged correctly! NEVER PIERCE A BULGING LI BATTERY!
Jan 02, 2010 | Garmin Forerunner 305 GPS Receiver
I charged my Garmin 305 and the screen read fully charged. I went to turn it on and there is no power. Now I can't even charge or download anything. It is fully dead.
Attach your unit to your computer and go to garmin.com, download webupdater and then go to my dashboard on garmin and follow the instructions
Oct 04, 2009 | Garmin Edge 305 GPS Receiver
Ive not had my garmin 305 long, it will not charge or turn on.
This might just need a reset. To reset the Forerunner or Edge 205/305:
  1. Connect the device to the computer using the USB cable
  2. Press and hold the mode and reset (lap) buttons together for 10 seconds
  3. Release and wait for 3 seconds
  4. There should be some indication of battery charging (either Finished or In Process)
  5. Power the device on while keeping it connected to the computer
In addition, please make sure that the device has the latest software version available by downloading and running the WebUpdater program. To update the software, please use the following link:
http://www.garmin.com/products/webupdater/
Sep 21, 2009 | Garmin Forerunner 305 GPS Receiver
My Garmin 305 has stopped working. It is 1 1/2
If it won't start, try connecting it to your computer and see if you can get a firmware update to turn it on. Otherwise I would send it into garmin since there aren't replaceable parts for consumers.
Benjamin
Jul 17, 2009 | Garmin Forerunner 305 GPS Receiver
Unit only powers on when attached to base charger
sounds like internal battery is dead, if underwarrenty contact company, if not these batteries are not user changeable u will have to use as is or replace
Jul 07, 2009 | Garmin Forerunner 305 GPS Receiver
Garmin Forerunner 305 GPS Receiver Logo
1,306 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
