Speakers don't have audio output - Audio Players & Recorders
    Novelist:
  • 159 Answers
If they are simple stereo pair, the jack should be plugged into the 'yellow' (center) socket of the 3 on the back of the PC.
You should also check in Settings/Control Panel/Sounds & Audio Devices that it's not set to 'mute'
Posted on Aug 22, 2010
Headphones plugged into TV audio output but speakers don't turn off
use the tv's setup menu to set the audio properties,eg. speakers on or off when headphones are plugged in.
Dec 22, 2012 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
How to connect a samsung soundbar to my tv and sat and dvd
Feed the audio from the audio out on your tv to the receiver. Plug your sound bar into the speaker output of the receiver and you should be up and running. You will have to turn on the receiver and control the audio there. The TV may have a setting for external speakers that you need to turn on in the audio menu. Now this is the straight forward approach but there are many factors to consider. One example would be the amplifier output being compatible with your speaker so you don't blow the speaker or the amp or amp/receiver combo.
Sep 28, 2012 | Samsung Hw-e450 Air Track Soundbar
Speakers don't work
Are the speakers working on any function? radio/cd ect.If not most likely a blown audio output ic,not worth wasting a lot of time on GPX/Grand prix is a bunch of cheaply made low end junk.Will probably cost more to fix then its worth
Sep 23, 2012 | GPX HM3817DT Shelf System
I recently bought a toshiba 40E210 lcd i just would like to ask if there is an additional audio output aside from the digital optical audio output?
Hi well NO I don't think that this unit has any other audio outputs? or "Monitor" as they are called, simply check the rear of the unit and the manual and see if there is any external outputs or "Monitor" Audio out, if there is it will be via Red & White RCA Jacks, these can be used to output to speakers or surround sound decoder. However this shouldn't be a problem as if you simply want to use this output, just obtain a Optical to standard audio output converter, and then you will be able to use this output in the regular way. And hook up to speakers or surround sound decoders as well. If you son;t have a manual, i suggest it will be a good idea to obtain one, approach the manufacturer or go to the website and look for one all info about the set will be in there.
Oct 16, 2011 | Toshiba 40E210U 40 in. LCD TV
Won't do anything! push power protector keeps coming up, what to do?
One of the speaker outputs are burnt,need power board replacment (audio output board, not power supply) don't replace components on board since is very difficult
Aug 23, 2011 | Sony BRAVIA® DAV-HDX277WC Theater System...
BOUGHT NEW FLAT SCREEN NEED HELP HOOKINF UP DVD/VCR
1. Video Output from DVD .. and Video Input in the TV..Used your Yellow cable for Video Output... 2. Audio Output from DVD and Audio Input in DVD (if your TV have a built-in Speaker)
Red & White Cable for Audio Output..
If your DVD has its on Speaker... don't follow the step 2.
if no sound.. please see to it if your speaker of your dvd is connected.. (if not Please connect it)
Aug 19, 2011 | Televison & Video
I need to install it to my compaq presario
Plug it into the audio output jack on the back of your Presario. There are probably 3 jacks that look like headphone jacks; use the green one. Don't forget to power on your speakers and ensure that the audio driver on the Presario is installed correctly.
Jul 18, 2011 | Insignia 2.0 Speaker System (2-Piece)
Radio plays but no sound. Last week or so I would be riding along and the speakers would lose sound, if I switched the radio output switch to either of the radio output to speaker select positions, it...
With the 07, you may have vibration damage to one of the main boards interlayer traces.
There are issues on those bikes that will need to be checked and the radio will need to be repaired
Contact Iron Cross Audio for options
www.ironcrossaudio.com
Jul 03, 2011 | Harley Davidson 426290 AM/FM Radio
I don't know which port in the back of the Pavilion to connect the black wire from the speakers (that connect to the right speaker with red and white ends). Any ideas? They are labeled as side, rear...
To get "surround" sound, when you face the computer, you will have:
* 2 front speakers, one immediately on each side of the computer
* 2 side speakers, one on each side of your head
* 2 rear speakers, one behind each side of your head
Thus, when the sound is of a jet-plane coming towards your face,
you'll first hear the sound in the front speakers,
then in the side speakers,
and finally in the rear speakers,
to produce a sound-effect of the jet passing over your head, and going "behind" you.
Usually, for "front" speakers, one speaker connects to the other speaker, and the second speaker connects to the "FRONT-audio-output" connector on your sound-card.
For side speakers, one speaker will connect to the LEFT-side-audio-output port,
and one speaker will connect to the RIGHT-side-audio-output port.
For rear speakers, one speaker will connect to the LEFT-rear-audio-output port,
and one speaker will connect to the RIGHT-rear-audio-output port.
Jun 01, 2011 | Audio Players & Recorders
Hook up lower level input to the audio source 230 subwoofer but can't get any sound for the speaker that is hook up through the speaker level input or output.
The speaker level connectors on the sub are for use when you DON'T have an AV receiver-style subwoofer output. They only pass-through from YOUR amp to other speakers. You should NOT use both Line level and Speaker Level input to the sub.
What is your electronics? Have you looked at the manuals?
May 02, 2011 | AudioSource System 230 / 235 System
27 people viewed this question
 Grubhead
Grubhead
